Introducing NCD’s One Channel Vibration Sensor Gen4. Lightweight rugged and reliable for accurate asset monitoring and boasting up to a 2-mile range using a wireless mesh networking architecture & Incorporating a 16-bit Vibration and integrated Temperature sensor.
This sensor combines these data with temperature data in a data packet, and transmits the result to modems and gateways within wireless range. Once transmission is complete, the vibration sensor goes back to sleep, thus minimizing power consumption.
Features:
- Small & lightweight for ease of installation.
- IP65 rated sealed enclosure for dust &
moisture protection. - Metal probe housing for durability in harsh industrial environments.
- A versatile user-configurable sample rate for slow or fast-running machines
- Integrated temperature sensor in base.
- In-Built Machine Learning optimizes power consumption.
- Asset On-Time Calculator automatically tracks operational status.
- Hardware Accelerator enhances vibration sampling accuracy.
- Configurable Sample Rate – 100Hz to 25.6KHz
- Available Frequencies – 900Mhz, 868Mhz, and 2.4Ghz
- Supports MESH networking via DigiMesh
- Fully open Node-RED library for configuration and data ingestion
Figure 1: Device Overview
Wireless Technology
- Long range – up to 1000 feet in urban environments and 2 miles+ in open areas with the included antennas
Battery Life
The Truth About Battery Life
Applications & Use-cases
This sensor is designed to monitor vibration, frequency, and temperature in industrial environments. It provides valuable data that can be used for predictive maintenance, equipment monitoring, and overall operational efficiency.Â
One Channel Vibration Sensor Gen4 Applications
Advanced Predictive Maintenance for Rotating Equipment
The sensor can be strategically integrated into the maintenance programs for critical rotating machinery, including motors, pumps, compressors, and turbines. By continuously monitoring vibration, frequency, and temperature data, the sensor provides insights into the health of the equipment, detecting early signs of issues such as misalignment, imbalance, or bearing wear. This data-driven approach enables the scheduling of maintenance activities before the equipment fails, reducing unexpected downtime, minimizing repair costs, and extending the operational lifespan of machinery.
Comprehensive Structural Health Monitoring
The sensor can be deployed on infrastructure like bridges, buildings, towers, and dams to detect abnormal vibrations that may signal structural deficiencies or damage. For example, in a bridge, the sensor can track changes in vibration patterns caused by material fatigue, loose joints, or foundation shifts. With continuous monitoring, it is possible to identify and address potential risks well before they escalate into safety hazards, ensuring the long-term integrity and reliability of critical infrastructure.
Process Automation and Quality Control in Manufacturing
In manufacturing environments, the sensor can be installed on key equipment such as conveyors, CNC machines, or robotic arms. By monitoring vibration data in real-time, the sensor can detect when machinery is operating outside its optimal conditions, which may indicate tool wear, imbalance, or other mechanical issues. Integrating this data with a manufacturing execution system (MES) allows for automatic adjustments, immediate alerts, or even shutdowns to prevent defects in products, enhance process efficiency, and maintain consistent product quality.
Optimization of Energy Efficiency in Industrial Systems
The sensor can be applied to monitor vibration levels in energy-intensive equipment such as HVAC systems, large fans, generators, and industrial chillers. Abnormal vibration often correlates with inefficiencies like misalignment, unbalanced loads, or mechanical wear, leading to increased energy consumption and operational costs. By detecting these issues early, the sensor supports proactive maintenance that reduces energy waste, improves the performance of systems, and contributes to the overall sustainability goals of the organization.
One Channel Vibration Sensor Gen4 Use-cases
Air Compressor Motor Monitoring
Installed on the motors powering air compressors, the vibration sensors continuously track motor performance to detect issues such as bearing wear, rotor imbalance, or misalignment. When abnormal vibration patterns are identified, the system automatically triggers alerts to the maintenance team, allowing them to address potential failures before they disrupt operations. This proactive approach ensures a steady supply of compressed air, which is vital for powering pneumatic tools and automated machinery, thereby minimizing downtime, reducing repair costs, and maintaining peak production efficiency.
Industrial Pumps Monitoring
In a large-scale manufacturing plant, industrial pumps play a critical role in circulating cooling fluids and transferring raw materials. To ensure continuous operation, vibration sensors are installed on pump motors to monitor their performance in real-time. These sensors track vibration patterns and detect early signs of issues such as bearing wear, shaft misalignment, or pump cavitation.
When abnormal patterns are identified, the system automatically sends alerts to the maintenance team, allowing them to schedule repairs before a breakdown occurs. This predictive approach prevents costly downtime, reduces maintenance expenses, and extends the lifespan of the equipment. Additionally, the collected vibration data is analyzed over time to identify trends, helping the plant optimize maintenance schedules and improve overall system reliability.
Industrial Fan and Blower Performance Monitoring
In a large-scale industrial facility, the sensor is used to monitor the vibration of high-capacity fans, blowers, and ventilation systems. By detecting early indicators of imbalance, misalignment, or bearing failure, the sensor allows maintenance teams to intervene before minor issues escalate into major problems. Ensuring the optimal performance of these systems is crucial for maintaining air quality, temperature control, and overall operational efficiency in the facility, preventing costly downtime and ensuring regulatory compliance.
Conveyer Belt Monitoring
Industrial conveyer belt installation especially those of large size like for example at dig sites have multiple rotational components that are under a heavy load. Stress to these installation is high and so are vibrational levels. It is essential they are monitored in real time, as a fault could be very dangerous. Furthermore as these are often off-site from cities, it is difficult to perform maintenance if it is unexpected. Monitoring vibrations in real time for example at crucial bearings along the line or at the driver/gear box at multiple points could give insights on potential issues before they occur. This would essentially enable the implementation of a solid predictive maintenances strategy and increase reliability and operational efficiency (by reducing downtime).
