Node-RED Dashboard Flow
Usage
The Flow
[{"id":"47d1a7c3.ae2358","type":"ncd-wireless-node","z":"13754c0b.dca3a4","name":"","connection":"","config_comm":"","addr":"","sensor_type":"13","auto_config":true,"node_id":0,"delay":"5","destination":"0000FFFF","power":"1","retries":10,"pan_id":"7FFF","change_enabled":false,"change_pr":"0","change_interval":"0","cm_calibration":"60.6","bp_altitude":"0","bp_pressure":"0","bp_temp_prec":"0","bp_press_prec":"0","amgt_accel":"0","amgt_mag":"0","amgt_gyro":"0","x":160,"y":320,"wires":[["48815e1.4a654a","c97b7299.a1ff"]]},{"id":"3b49bbb1.7d7b64","type":"ui_chart","z":"13754c0b.dca3a4","name":"","group":"8f08e849.547418","order":1,"width":"0","height":"0","label":"Current","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#00e40f","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":760,"y":220,"wires":[[],[]]},{"id":"48815e1.4a654a","type":"change","z":"13754c0b.dca3a4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"data.battery","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":420,"wires":[["b604b0e9.515f9"]]},{"id":"3ee4cb0d.c46c74","type":"ncd-gateway-node","z":"13754c0b.dca3a4","name":"","connection":"","x":250,"y":140,"wires":[["5fc4b3bf.ccaabc"]]},{"id":"5fc4b3bf.ccaabc","type":"debug","z":"13754c0b.dca3a4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":510,"y":80,"wires":[]},{"id":"b604b0e9.515f9","type":"ui_gauge","z":"13754c0b.dca3a4","name":"","group":"a2478662.b4c238","order":2,"width":"12","height":"4","gtype":"gage","title":"Battery","label":"V","format":"{{value | number:2}}","min":0,"max":"3.3","colors":["#e00600","#e6e600","#07ca00"],"seg1":"","seg2":"","x":600,"y":420,"wires":[]},{"id":"c97b7299.a1ff","type":"split","z":"13754c0b.dca3a4","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":370,"y":300,"wires":[["3b49bbb1.7d7b64","fe7e0bea.c7ddb8"]]},{"id":"fe7e0bea.c7ddb8","type":"ui_gauge","z":"13754c0b.dca3a4","name":"","group":"a2478662.b4c238","order":1,"width":"12","height":"4","gtype":"gage","title":"Current","label":"Amps","format":"{{value | number:2}}","min":"0","max":"100","colors":["#403600","#d9ca00","#ffeb00"],"seg1":"","seg2":"","x":760,"y":300,"wires":[]},{"id":"8f08e849.547418","type":"ui_group","z":"","name":"Default","tab":"c4f82725.5cb928","disp":false,"width":"24","collapse":false},{"id":"a2478662.b4c238","type":"ui_group","z":"","name":"Thermocouple","tab":"298badf6.a6a0a2","disp":false,"width":"12","collapse":false},{"id":"c4f82725.5cb928","type":"ui_tab","z":"","name":"History","icon":"dashboard"},{"id":"298badf6.a6a0a2","type":"ui_tab","z":"","name":"Current","icon":"dashboard"}]
