Node-RED Dashboard Flow
Usage
The Flow
[{"id":"128499f8.93e056","type":"ncd-gateway-node","z":"95b1ec27.9fae5","name":"","connection":"","x":230,"y":480,"wires":[["c46e88b2.17d308"]]},{"id":"b8b2f766.dcbb48","type":"switch","z":"95b1ec27.9fae5","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"input_1","vt":"str"},{"t":"eq","v":"input_2","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":790,"y":660,"wires":[["3eef1d3b.4a4d52"],["84b7717b.36328"]]},{"id":"a092304c.8edce","type":"split","z":"95b1ec27.9fae5","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":470,"y":660,"wires":[["a595e2f8.33b25","4a2f8cd1.664784"]]},{"id":"f4cbd0e4.11b03","type":"ncd-wireless-node","z":"95b1ec27.9fae5","name":"","connection":"","config_comm":"","addr":"","sensor_type":"2","auto_config":false,"node_id":0,"delay":300,"destination":"0000FFFF","power":4,"retries":10,"pan_id":"7FFF","change_enabled":"","change_pr":"0","change_interval":"0","cm_calibration":"60.6","bp_altitude":"0","bp_pressure":"0","bp_temp_prec":"0","bp_press_prec":"0","amgt_accel":"0","amgt_mag":"0","amgt_gyro":"0","impact_accel":"0","impact_data_rate":"4","impact_threshold":25,"impact_duration":1,"activ_interr_x":1,"activ_interr_y":2,"activ_interr_z":4,"activ_interr_op":8,"x":240,"y":660,"wires":[["a092304c.8edce","d5c92f84.b9e07"]]},{"id":"542cdc32.ad6d24","type":"ui_chart","z":"95b1ec27.9fae5","name":"","group":"8f08e849.547418","order":0,"width":0,"height":0,"label":"Input History","chartType":"bar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"100","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":810,"y":540,"wires":[[],[]]},{"id":"a595e2f8.33b25","type":"change","z":"95b1ec27.9fae5","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"On","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"0","fromt":"num","to":"Off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":660,"wires":[["b8b2f766.dcbb48"]]},{"id":"3eef1d3b.4a4d52","type":"ui_text","z":"95b1ec27.9fae5","group":"b8a7bc9b.086d6","order":0,"width":0,"height":0,"name":"","label":"Input 1","format":"{{msg.payload}}","layout":"row-center","x":1000,"y":600,"wires":[]},{"id":"84b7717b.36328","type":"ui_text","z":"95b1ec27.9fae5","group":"b8a7bc9b.086d6","order":0,"width":0,"height":0,"name":"","label":"Input 2","format":"{{msg.payload}}","layout":"row-center","x":1000,"y":680,"wires":[]},{"id":"c46e88b2.17d308","type":"debug","z":"95b1ec27.9fae5","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":510,"y":440,"wires":[]},{"id":"4a2f8cd1.664784","type":"function","z":"95b1ec27.9fae5","name":"","func":"var total = flow.get(msg.topic) || 0;\nvar last = flow.get(msg.topic+'_last');\nflow.set(msg.topic+'_last', msg.payload);\nif(!last && msg.payload){\n msg.payload = total + msg.payload;\n flow.set(msg.topic, msg.payload);\n}else{\n msg.payload = total;\n}\nreturn msg;","outputs":1,"noerr":0,"x":650,"y":540,"wires":[["542cdc32.ad6d24"]]},{"id":"2daa15.908a15ec","type":"ui_gauge","z":"95b1ec27.9fae5","name":"","group":"b8a7bc9b.086d6","order":0,"width":0,"height":0,"gtype":"gage","title":"Battery","label":"V","format":"{{value | number:2}}","min":0,"max":"3.3","colors":["#ff0011","#e6e600","#09ca00"],"seg1":"","seg2":"","x":800,"y":760,"wires":[]},{"id":"d5c92f84.b9e07","type":"change","z":"95b1ec27.9fae5","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"data.battery","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":760,"wires":[["2daa15.908a15ec"]]},{"id":"8f08e849.547418","type":"ui_group","z":"","name":"Default","tab":"c4f82725.5cb928","disp":false,"width":"8","collapse":false},{"id":"b8a7bc9b.086d6","type":"ui_group","z":"","name":"Status","tab":"104ce52d.cc60bb","order":1,"disp":true,"width":"8","collapse":false},{"id":"c4f82725.5cb928","type":"ui_tab","z":"","name":"History","icon":"dashboard","order":4},{"id":"104ce52d.cc60bb","type":"ui_tab","z":"","name":"Current","icon":"dashboard","order":1}]
