Node-RED Dashboard Flow
The examples in this series are for use with Node-RED and our NCD IoT line of products. If you haven’t already, check out this post, which will provide the resources required to get your environment set up.
Usage
From the command line (Power Shell for Windows users), navigate to the Node-RED directory and type npm i ncd-red-ams5812
, then start Node-RED.
Double click on the AMS5812 node and set up the “I2C Connection” field.
You also need to update your sensor type, the info tab has more information.
Deploy the flow and you will begin receiving telemetry at the interval indicated by the sensor node settings.
The Flow
[{"id":"d8b15eb0.fbad","type":"ncd-ams5812","z":"13754c0b.dca3a4","name":"","connection":"","interval":"500","range":"150","sType":"d","pScale":1,"tempScale":"f","x":160,"y":260,"wires":[["4f759e4d.a8b1","be16cc6f.47a6"],["b084cf2d.b73b6","966d9f8d.a3776"]]},{"id":"b084cf2d.b73b6","type":"ui_gauge","z":"13754c0b.dca3a4","name":"","group":"d79de0e4.bda58","order":0,"width":0,"height":0,"gtype":"gage","title":"Temperature (Current)","label":"Fahrenheit","format":"{{value | number:2}}","min":0,"max":"100","colors":["#4288ff","#0de617","#ff312d"],"seg1":"","seg2":"","x":470,"y":360,"wires":[]},{"id":"966d9f8d.a3776","type":"ui_chart","z":"13754c0b.dca3a4","name":"","group":"e42b58e2.7254b8","order":0,"width":"8","height":"5","label":"Temperature (Historic)","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#0eb417","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":470,"y":320,"wires":[[],[]]},{"id":"4f759e4d.a8b1","type":"ui_chart","z":"13754c0b.dca3a4","name":"","group":"e42b58e2.7254b8","order":0,"width":"8","height":"5","label":"Pressure (Historic)","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":470,"y":160,"wires":[[],[]]},{"id":"be16cc6f.47a6","type":"ui_gauge","z":"13754c0b.dca3a4","name":"","group":"d79de0e4.bda58","order":0,"width":0,"height":0,"gtype":"gage","title":"Pressure (Current)","label":"mBar","format":"{{value | number:2}}","min":"-1.5","max":"1.5","colors":["#ff151a","#e6e600","#18ca10"],"seg1":"","seg2":"","x":470,"y":200,"wires":[]},{"id":"d79de0e4.bda58","type":"ui_group","z":"","name":"Default","tab":"104ce52d.cc60bb","disp":false,"width":"12","collapse":false},{"id":"e42b58e2.7254b8","type":"ui_group","z":"","name":"Default","tab":"459c002f.aa916","disp":false,"width":"16","collapse":false},{"id":"104ce52d.cc60bb","type":"ui_tab","z":"","name":"Current","icon":"dashboard"},{"id":"459c002f.aa916","type":"ui_tab","z":"","name":"History","icon":"dashboard"}]
Check out a full list of AMS5812 products on our store!
