The Machine Uptime Monitor is a device specifically designed to track machine and production uptime in industrial settings. It is a flexible device that can be configure to observe one or more events via different input types – accelerometer, magnetometer, current sensor, break beam sensor, photo eye sensor, reflector sensor, current sensor.
It has long range wireless capabilities utilizing robust Mesh networking protocols with high level of security and network reliability. It is compact, durable and powered by long lasting batteries. Its main feature include:
- Industrial Grade Machine Uptime Monitoring
- Measure Production Uptime
- Measure Number of Cycles
- Dry Contact Closure Input
- Wet Contact Closure Input
- Acceleration Motion Detection based Uptime calculator
- Magnetic Field Detection based Uptime calculator
- Current-based Uptime calculator
- Humidity Range 0-90%
- For Indoor and Outdoor Use
Frame Structure
| 8 | 0x55 | |||
| 9 | 0x4E | |||
| 8 | 0x47 | |||
| 9 | 0x4D | |||
| 8 | 0x55 | |||
| 9 | 0x4D |
Run Mode Power Up Frame
| 7E 00 1E 10 01 00 13 A2 00 42 53 64 53 FF FE 00 00 7A 00 00 00 6C 00 00 52 55 4E 00 00 00 00 00 00 06 | Example frame | |
| 0x7E | 1 | Delimiter |
| 0x1001 | 2 | Length |
| 0x10 | 1 | Frame Type (Power Up) |
| 0xFFFE | 2 | Reserved |
| 0xC2 | 1 | R. Option |
| 0x00 | 1 | Node ID |
| 0x00 | 1 | Separator |
| 0x006C | 2 | Sensor Type |
| 0x0000 | 2 | Separator |
| 0x06 | 1 | Checksum |
Configuration Mode Frame
| 7E 00 1E 10 01 00 13 A2 00 42 53 64 53 FF FE 00 00 7A 00 00 00 6C 00 00 50 47 4D 00 00 00 00 00 00 17 | Example frame | |
| 0x001C | 2 | Length |
| 0x90 | 1 | Frame Type |
| 0x7A | 1 | Header |
| 0x17 | 1 | Checksum |
Factory Reset Mode Frame (PUM)
| 7E 00 1C 90 00 13 A2 00 42 53 64 53 FF FE C2 7A 00 00 00 6C 00 00 50 55 4D 00 00 00 00 00 00 D5 | Example frame | |
| 0x7A | 1 | Header |
| 0x50554D | 3 | Mode Byte for Factory Reset Mode |
| 0xD5 | 1 | Checksum |
OTN Mode Frame
| 7E 00 1C 90 00 13 A2 00 42 53 64 53 FF FE C2 7A 00 00 00 6C 00 00 4F 54 4E 00 00 00 00 00 00 D6 | Example frame | |
| 0x7A | 1 | Header |
| 0x4F544E | 3 | Mode Byte for OTN Mode |
| 0xD6 | 1 | Checksum |
FLY Mode Frame
| 7F 00 0A 00 00 00 00 7B 01 46 4C 59 0000 00 00 00 01 32 01 01 01 00 00 03 E8 00 00 00 00 00 00 00 00 00 02 58 00 0A 63 01 0A 00 00 00 00 00 00 00 00 00 01 31 | Example frame | |
| 0x00 | 1 | R. Option |
| 0x7F | 1 | Header |
| 0x01 | 1 | Firmware Version |
| 0x0000 | 2 | Battery Voltage |
| 0x00 | 1 | Counter |
| 0x00 | 1 | Reserved |
| 0x464C59 | 3 | Mode Byte for FLY Mode |
| 0x00 | 1 | Accelerometer Threshold |
| 0x0000 | 2 | Debouncing Timeout |
| 0x00 | 1 | Accelerometer State |
| 0x00 | 1 | Input 1 Active Edge |
| 0x00 | 1 | Input 2 Active Edge |
| 0x00 | 1 | Input 3 Active Edge |
| 0x00000000 | 4 | Counter Threshold |
| 0x00 | 1 | Transmit on Change Status |
| 0x0000 | 2 | Shift End 1 |
| 0x0000 | 2 | Shift End 2 |
| 0x0000 | 2 | Shift End 3 |
| 0x0000 | 2 | Shift End 4 |
| 0x0000 | 2 | Reset Timeout |
| 0x00 | 1 | Counter Reset Mode |
| 0x00 | 1 | Sampling Interval |
| 0x00 | 1 | Accelerometer ODR |
| 0x00 | 1 | Screen Control |
| 0x00 | 1 | Screen On Time |
| 0x000000 | 3 | Hardware ID |
| 0x00000000 | 4 | Report Rate |
| 0x00000000 | 4 | Tx Life Counter |
| 0x00 | 1 | Checksum |
Sensor Data Frame
Run mode is the default mode of operation of this sensor. In this mode, the Machine Uptime sensor sends periodic packets with the sensor measurement data. During the time it is not sending it enters deep-sleep to conserve power. The sensor’s X-bee module operates in API mode and sends packets to the saved destination address on the network specified by the saved PAN ID. Figure 4 illustrates the API transmission/reception procedure.
There are two type of packets, with different payloads depending on the Firmware version. The following subsections show each of these.
Payload for Firmware version 4 and below
| LSB 7 | 0x6C | Sensor Type 108 | ||
| Error/Reserved byte | 8 | 0x00 | 1 | Reserved |
| Digital Input 1 Counter | 9/ Data[0] | - | 4 | Counter 1 = Data[0] << 24 | Data[1] << 16 | << Data[2] << 8 | Data[3] |
| 10/ Data[1] | ||||
| 11/ Data[2] | ||||
| 12/ Data[3] | ||||
| Digital Input 1 Uptime | 13/ Data[0] | - | 4 | Uptime 1 = Data[0] << 24 | Data[1] << 16 | << Data[2] << 8 | Data[3] |
| 14/ Data[1] | ||||
| 15/ Data[2] | ||||
| 16/ Data[3] | ||||
| CT Input Counter | 17/ Data[0] | - | 4 | CT Input Counter = Data[0] << 24 | Data[1] << 16 | << Data[2] << 8 | Data[3] |
| 18/ Data[1] | ||||
| 19/ Data[2] | ||||
| 20/ Data[3] | ||||
| CT Input Uptime | 21/ Data[0] | - | 4 | CT Input Uptime = Data[0] << 24 | Data[1] << 16 | << Data[2] << 8 | Data[3] |
| 22/ Data[1] | ||||
| 23/ Data[2] | ||||
| 24/ Data[3] | ||||
| Opto Input Counter | 25/ Data[0] | - | 4 | Opto Input Counter = Data[0] << 24 | Data[1] << 16 | << Data[2] << 8 | Data[3] |
| 26/ Data[1] | ||||
| 27/ Data[2] | ||||
| 28/ Data[3] | ||||
| Opto Input Uptime | 29/ Data[0] | - | 4 | Opto Input Uptime = Data[0] << 24 | Data[1] << 16 | << Data[2] << 8 | Data[3] |
| 30/ Data[1] | ||||
| 31/ Data[2] | ||||
| 32/ Data[3] | ||||
| Accelerometer Input Counter | 33/ Data[0] | - | 4 | Accelerometer Input Counter = Data[0] << 24 | Data[1] << 16 | << Data[2] << 8 | Data[3] |
| 34/ Data[1] | ||||
| 35/ Data[2] | ||||
| 36/ Data[3] | ||||
| Accelerometer Input Uptime | 37/ Data[0] | - | 4 | Accelerometer Input Uptime = Data[0] << 24 | Data[1] << 16 | << Data[2] << 8 | Data[3] |
| 38/ Data[1] | ||||
| 39/ Data[2] | ||||
| 40/ Data[3] | ||||
| Magnetometer Input Counter | 33/ Data[0] | - | 4 | Magnetometer Input Counter = Data[0] << 24 | Data[1] << 16 | << Data[2] << 8 | Data[3] |
| 34/ Data[1] | ||||
| 35/ Data[2] | ||||
| 36/ Data[3] | ||||
| Magnetometer Input Uptime | 37/ Data[0] | - | 4 | Magnetometer Input Uptime = Data[0] << 24 | Data[1] << 16 | << Data[2] << 8 | Data[3] |
| 38/ Data[1] | ||||
| 39/ Data[2] | ||||
| 40/ Data[3] | ||||
| Input Logic State | 41/ Data[0] | - | 1 | Bit 1: Logic Status Digital Input Bit 2: Logic Status CT current Input Bit 3: Logic Status Opto Input Bit 4: Logic Status Accelerometer Input Bit 5: Logic Status Magnetometer Input |
Payload for Firmware version 5 and above
| 10/ Data[1] | ||||
| 11/ Data[2] | ||||
| 12/ Data[3] | ||||
| 14/ Data[1] | ||||
| 15/ Data[2] | ||||
| 16/ Data[3] | ||||
| 18/ Data[1] | ||||
| 19/ Data[2] | ||||
| 20/ Data[3] | ||||
| 22/ Data[1] | ||||
| 23/ Data[2] | ||||
| 24/ Data[3] | ||||
| 26/ Data[1] | ||||
| 27/ Data[2] | ||||
| 28/ Data[3] | ||||
| 30/ Data[1] | ||||
| 31/ Data[2] | ||||
| 32/ Data[3] | ||||
| 34/ Data[1] | ||||
| 35/ Data[2] | ||||
| 36/ Data[3] | ||||
| 38/ Data[1] | ||||
| 39/ Data[2] | ||||
| 40/ Data[3] | ||||
| 34/ Data[1] | ||||
| 35/ Data[2] | ||||
| 36/ Data[3] | ||||
| 38/ Data[1] | ||||
| 39/ Data[2] | ||||
| 40/ Data[3] | ||||
| Report Type | 42/ Data[0] | - | 1 | 0x00 -- Regular 0x01 -- Shift End 0x02 -- Interrrupt 0x03 -- Threshold |
| Real-Time Clock | 35/ Data[0] 36/ Data[1] 36/ Data[2] | - | 3 | Data[0] -- Hour Data[1] -- Minute Data[2] -- Second |
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
Read Sensor Network ID
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Set Sensor Destination to Broadcast
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Read Wireless Sensor Retries
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep. But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data. If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep. The Machine Uptime sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Set Wireless Sensor number of Retries
Complete Payload
F7 06 00 00 00 05
Complete Payload
Appendix
Configuration Commands
| 15 | Set Change Detection Parameters | 0XF7 | 0x07 | E, PR, T0 MSB, T1, T2 LSB | Enable or disable the percentage change detection. E=1 (Enable), E=0 (Disable) PR is the percentage change detection at which the sensor will send a packet. The sensor sends a packet when two consecutive readings differ by PR percent T0, T1, T2 - This is the detection time after which the sensor periodically checks for PR percent change in sensor data from last sample |
| 16 | Read Change Detection Parameters | 0XF7 | 0x1A | - | Refer to Command 15 above for the explanation. |
Command Acknowledgement Data
| 14 | Set Encryption Key | 1 | 8 | 0xFF (OK) | |
| 15 | Set Change Detection Parameters | 1 | 8 | 0xFF (OK) | |
| 16 | Read Change Detection Parameters | 5 | 4 | E, PR, T0, T1, T2 | Detection time = (T0 x 65536) + (T1 x 256) + T2 |
Application Specific Commands
| No. | Command | Header | Sub Command | Reserve Byte | Command Code / Argument | Description |
| 1 | Set Clear Counters | 0xF4 | 0x24 | 0x00, 0x00, 0x00 | 0x07 -- Digital 1 0x08 -- Digital 2 0x08 -- Digital 3 | Clear the counters on specific digital input. |
| 2 | Read Clear Counters | 0xF4 | 0x25 | 0x00, 0x00, 0x00 | 0x07 -- Digital 1 0x08 -- Digital 2 0x08 -- Digital 3 | Read the counters on specific digital input. |
| 3 | Set Debounce Time | 0xF4 | 0x27 | 0x00, 0x00, 0x00 | Valid Range: 0x000A -- 0xFDE8 | Sets the debounce time in milliseconds on inputs. State changes to the input during this debounce time will be ignored. Generally recommended for mechanically triggered state changes such as button or relay/contactor outputs. |
| 4 | Read Debounce Time | 0xF4 | 0x28 | 0x00, 0x00, 0x00 | Read the debounce time in milliseconds on inputs. | |
| 5 | Set Digital Input Detection | 0xF4 | 0x29 | 0x00, 0x00, 0x00, 0x01 | 0x01 -- Rising Edge Trigger 0x00 -- Falling Edge Trigger | Sets whether to count the time that the input is pulled up as uptime (Rising Edge) or when the input is pulled low as uptime (Falling Edge). |
| 6 | Set Current Transducer Detection | 0xF4 | 0x29 | 0x00, 0x00, 0x00, 0x02 | 0x01 -- Rising Edge Trigger 0x00 -- Falling Edge Trigger | Sets whether to count the time that the input is pulled up as uptime (Rising Edge) or when the input is pulled low as uptime (Falling Edge). |
| 7 | Set Contact/Optical Input Detection | 0xF4 | 0x29 | 0x00, 0x00, 0x00, 0x03 | 0x01 -- Rising Edge Trigger 0x00 -- Falling Edge Trigger | Sets whether to count the time that the input is pulled up as uptime (Rising Edge) or when the input is pulled low as uptime (Falling Edge). |
| 8 | Read Digital Input Detection | 0xF4 | 0x30 | 0x00, 0x00, 0x00, 0x03 | ||
| 9 | Set Counter Threshold | 0xF4 | 0x2B | 0x00, 0x00, 0x00, 0x00, 0x00 | Valid Range: 0x0000 -- 0xFFFE | Device will send data when any counters reaches multiple of the Threshold. Note: The range for this value is from 0 to 65534 and must be multiple of 100. |
| 10 | Read Counter Threshold | 0xF4 | 0x2C | 0x00, 0x00, 0x00, 0x00, 0x00 | ||
| 11 | Enable Push Notification | 0xF4 | 0x2D | 0x00, 0x00, 0x00 | 0x00 -- Disable All 0x01 -- Enable on IO1 0x02 -- Enable on IO2 0x03 -- Enable on IO1 and IO2 0x04 -- Enable on IO3 0x05 -- Enable on IO1 and IO3 0x06 -- Enable on IO2 and IO3 0x07 -- Enable on IO1, IO2 and IO3 | Enable the push notification, sensor will transmit data immediatelly when the selected input is enabled. The Message Type will be 'Interrput' in sensor data |
| 12 | Read Push Notification | 0xF4 | 0x2E | 0x00, 0x00, 0x00 | 0x00 -- Disable All 0x01 -- Enable on IO1 0x02 -- Enable on IO2 0x03 -- Enable on IO1 and IO2 0x04 -- Enable on IO3 0x05 -- Enable on IO1 and IO3 0x06 -- Enable on IO2 and IO3 0x07 -- Enable on IO1, IO2 and IO3 | Read the push notification. |
| 13 | Set Data Transmission Interval | 0xF4 | 0x37 | 0x00, 0x00, 0x00 | 0x00 -- 1 Minute 0x01 -- 5 Minutes 0x02 -- 15 Minutes 0x03 -- 30 Minutes 0x04 -- 1 Hour 0x05 -- 2 Hours 0x06 -- 3 Hours 0x07 -- 6 Hours 0x08 -- 12 Hours 0x09 -- 5 Seconds 0x0A -- 10 Seconds 0x0B -- 15 Seconds 0x0C -- 30 Seconds | This setting dictates the interval at which the sensor will wake up and transmit its data. This interval works independently from any configured interrupt driven messages. |
| 14 | Read Data Transmission Interval | 0xF4 | 0x38 | 0x00, 0x00, 0x00 | 0x00 -- 1 Minute 0x01 -- 5 Minutes 0x02 -- 15 Minutes 0x03 -- 30 Minutes 0x04 -- 1 Hour 0x05 -- 2 Hours 0x06 -- 3 Hours 0x07 -- 6 Hours 0x08 -- 12 Hours 0x09 -- 5 Seconds 0x0A -- 10 Seconds 0x0B -- 15 Seconds 0x0C -- 30 Seconds | Read the interval at which the sensor will wake up and transmit its data. |
| 15 | Reset Timeout | 0xF4 | 0x31 | 0x00, 0x00, 0x00 | Valid Range: 0x0000 -- 0xFFFE | Sensor will reset after this time and before reset it will set it data value. |
| 16 | Read Reset Timeout | 0xF4 | 0x32 | 0x00, 0x00, 0x00 | ||
| 17 | Set Shift Time 1 | 0xF4 | 0x2F | 0x00, 0x00, 0x00, 0x00 | 0x00 -- Hour, 0x00 -- Minute | Based on the RTC (Real-Time Clock). Set 1 of 4 specific times (24-hour time format) in which the sensor will apply a reset. |
| 18 | Set Shift Time 2 | 0xF4 | 0x2F | 0x00, 0x00, 0x00, 0x01 | 0x00 -- Hour, 0x00 -- Minute | Based on the RTC (Real-Time Clock). Set 2 of 4 specific times (24-hour time format) in which the sensor will apply a reset. |
| 19 | Set Shift Time 3 | 0xF4 | 0x2F | 0x00, 0x00, 0x00, 0x02 | 0x00 -- Hour, 0x00 -- Minute | Based on the RTC (Real-Time Clock). Set 3 of 4 specific times (24-hour time format) in which the sensor will apply a reset. |
| 20 | Set Shift Time 4 | 0xF4 | 0x2F | 0x00, 0x00, 0x00, 0x03 | 0x00 -- Hour, 0x00 -- Minute | Based on the RTC (Real-Time Clock). Set 4 of 4 specific times (24-hour time format) in which the sensor will apply a reset. |
| 21 | Set Reset Mode | 0xF4 | 0x33 | 0x00, 0x00, 0x00 | 0x00 -- Do not reset counters 0x01 -- Based on Shift Ends 0x02 -- Based on the Timeout Provided | This works in conjunction with Reset Timeout and Shift Time commands. It specifies which reset option the sensor will apply. Default value: Disabled |
| 22 | Enable Quality of Service | 0xF4 | 0x34 | 0x00, 0x00, 0x00 | 0x00 -- Disable 0x01 -- Enable | This setting only functions when a Destination Address is also configured into the sensor. If QoS is enabled the sensor will wait for a receipt acknowledgement from the intended receiver before resuming sleep. If no receipt acknowledgement is received the sensor will one more time to transmit the data. |
| 23 | Set Internal Real Time Clock | 0xF4 | 0x35 | 0x00, 0x00, 0x00 | 0x00 -- Hour, 0x00 -- Minute, 0x00 -- Second | Sets the internal Real Time Clock |
| 24 | Set FLY Interval | 0xF7 | 0x38 | 0x00, 0x00, 0x00 | 0x3C -- 1 Hour 0x78 -- 2 Hours 0xF0 -- 4 Hours 0x01E0 -- 8 Hours 0x02D0 -- 12 Hours 0x0438 -- 18 Hours 0x05A0 -- 24 Hours | This setting dictates the interval at which the sensor will wake up and transmit the FLY message. FLY Message is used to trigger Automatic Sensor configuration and Firmware Update. |
| 25 | Enable Accelerometer | 0xF4 | 0x25 | 0x00, 0x00, 0x00 | 0x00 -- Disable 0x01 -- Enable | This setting toggles the accelerometer sensor on or off. Disabling it is recommended for applications that does not require accelerometer. |
| 26 | Enable Accelerometer Error Reporting | 0xF4 | 0x25 | 0x00, 0x00, 0x00,0x07 | 0x00 -- Disable 0x01 -- Enable | Enables the sensor to report errors if the accelerometer probe becomes non-functional. These errors will be included in the sensor data. |
| 27 | Set Accelerometer Threshold | 0xF4 | 0x20 | 0x00, 0x00, 0x00 | Valid Range: 0x00 -- 0xFF | Sets the threshold in multiples of 32mg in which an uptime will be detected. A value of 1 = 32mg, a value of 2 = 64mg etc. |
| 28 | Set Accelerometer Sample Rate | 0xF4 | 0x30 | 0x00, 0x00, 0x00 | 0x00 -- 10 Hz 0x01 -- 20 Hz 0x02 -- 50Hz 0x03 -- 100Hz 0x04 -- 200Hz 0x05 -- 400Hz | This setting defines the number of measurements the sensor takes per second, measured in Hertz (Hz). **Only applies to sensor with firmware version 8 and above. |
| 29 | Set Interrupt Timeout | 0xF4 | 0x41 | 0x00, 0x00, 0x00 | Valid Range: 0x0000 -- 0xFFFE | Set the sensor to detect an initial IO (input/output) change and not transmit subsequent IO changes for a specified duration; set the duration value to control how long changes are ignored in milliseconds, set it to 0 to disable ignoring. **Only applies to sensor with firmware version 11 and above. Valid range: 0 - 65000 milliseconds. |
| 30 | Set Screen On Time | 0xF4 | 0x43 | 0x00, 0x00, 0x00 | Valid Range: 0x00 -- 0xFF | Set the duration, in seconds, that the screen will remain active after a sensor transmission. Once this time elapses, the screen will automatically turn off. **Only applies to screen version |
| 31 | Set Screen Control | 0xF4 | 0x45 | 0x00, 0x00, 0x00 | 0x00 -- IO1 0x01 -- IO2 0x02 -- IO3 0x03 -- Accelerometer 0x04 -- Magnetometer | Selects the type of input or data that will be displayed on the screen. **Only applies to screen version |
Error Code Descriptions
| 0x01 | Invalid command |
| 0x03 | Node ID mismatch |
Calculation for transmission
0x04
0xFF-0x04=0xFB
Calculation for reception
2. Keep only the last 8 bits
0xFF
