Machine Up Time Monitoring Product Manual
1
  • Industrial Grade Machine Uptime Monitoring
  • Measure Production Uptime
  • Measure Number of Cycles
  • Dry Contact Closure Input
  • Wet Contact Closure Input
  • Acceleration Motion Detection based Uptime calculator
  • Magnetic Field Detection based Uptime calculator
  • Current-based Uptime calculator
  • Encrypted Communication with 2 Mile Wireless Range
  • Operating Temperature Range -40 to +60 °C
  • Humidity Range 0-90%
  • For Indoor and Outdoor Use
  • Many Gateway and Modem Options Available
The Machine Up-Time Monitoring Sensor is an innovative solution designed to track and analyze the operational efficiency of industrial machinery. Leveraging advanced digital inputs, current sensing technology, acceleration detection, and magnetic field measurement capabilities, this sensor provides comprehensive insights into machine performance. With its robust IP65 rating, battery-powered operation, and long-distance communication capabilities through Digimesh Sub GHz radio, the sensor ensures reliable data collection in diverse industrial environments. Moreover, its versatile compatibility allows seamless integration with any cloud platform, local PC, or server for centralized monitoring and analysis.
Key Features:
  1. Multi-Sensor Functionality: Integrates digital inputs, current sensor, acceleration detection, and magnetic field measurement capabilities for comprehensive machine performance monitoring.
  2. IP65 Rating: Designed to withstand harsh industrial environments, ensuring durability and reliability in challenging conditions such as dust, moisture, and vibration.
  3. Battery-Powered Operation: Enables easy installation without the need for external power sources, facilitating flexibility in sensor placement and minimizing downtime during setup.
  4. Digimesh Sub GHz Radio: Utilizes advanced radio technology for long-range communication, allowing seamless transmission of data over extended distances within industrial facilities.
  5. Versatile Connectivity: Compatible with a wide range of cloud platforms, local PCs, and servers, offering flexibility in data management and analysis based on user preferences and existing infrastructure.
  6. Real-Time Monitoring: Provides real-time updates on machine up-time, downtime, and performance metrics, enabling prompt identification of issues and proactive maintenance strategies.
  7. User-Friendly Interface: Offers intuitive dashboards and analytics tools for easy visualization and interpretation of machine performance data, empowering users to make informed decisions.
  8. Scalable Solution: Suitable for deployment in small-scale operations as well as large industrial facilities, with scalability to accommodate varying needs and requirements.
Specifications
Transmission Rating500,000Total Number of Wireless Transmissions When Using 4 AA Batteries
Batteries266May be Powered by 2 or 4 AA Batteries
Battery Life 1 TPD10 YearsTPD Transmissions per Day
Battery Life 3 TPD8 YearsTPD Transmissions per Day
Battery Life 6 TPD4 YearsTPD Transmissions per Day
Battery Life 12 TPD2 YearsTPD Transmissions per Day
Battery Life 24 TPD1 YearTPD Transmissions per Day
Width3.54"
Length4.52"
Height2.16"
Enclosure RatingIP65, NEMA 1,2,4,4X,12,13, UL-508
Temperature Rating-40° C23° C85° CComponent Rating
Tested Temperature0° C23° C40° CAs Tested by NCD Staff
Probe Temperature-40° C23° C105° CAs Tested by NCD Staff
InputsDigital, Acceleration, Magnetic, Current
Notes:
Use Energizer Ultimate Lithium ONLY for Extreme Temperatures
All Ratings are for 6 Batteries
Actual Battery Life is Dependent On Transmission Interval
Battery Shelf Life Does Not Exceed 10 Years Therefore NCD Does Not Rate Battery Life Beyond the Shelf Life of Available Batteries
** Battery life will significantly reduce when time domain mode is enabled
3
  • Manufacturing plants
  • Automotive production lines
  • Food processing facilities
  • Chemical and pharmaceutical industries
  • Mining and heavy machinery operations
Hardware
4
Sensor Hardware
The Machine Uptime Sensor hardware can be divided into two parts.
A. Main Electronics Box
This box ( White Box) contains Electronics such as MCU, Radio Module, Power Circuitry, Power Control unit, Status LED, on/off Switch, Configuration Button etc.
Production Uptime Monitoring
B. The Probe
There are 4 Types of probes.
  1. Bare Wire for Digital Inputs
  2. Current Sensor
  3. Accelerometer
  4. Magnetometer
Internal Components
  • Inside NCD sensors, you will find a high-power radio communications module, 6-AA batteries (included when possible), a sensor element (if applicable) or a connector (for external functionality).
  • NCD sensors consume less than 20µA in standby with an operational life estimated at 500,000 transmissions using 6-AA batteries.
Sensor Diagram
Digital Inputs
The Industrial Digital Input and Sensor Reader is a compact and robust device tailored to interpret signals from various digital inputs and sensors prevalent in industrial settings, including brake sensors, photo reflectors, and on/off signals. With high accuracy and reliability, it offers real-time data acquisition and monitoring, seamlessly integrating into existing industrial automation systems. Its user-friendly interface and flexible configuration options ensure easy setup and compatibility with diverse applications, enhancing operational efficiency, equipment reliability, and production optimization. Ideal for conveyor systems, packaging machinery, and robotic systems, it empowers industrial operators with streamlined data interpretation and control capabilities, minimizing downtime and maximizing productivity.
Accelerometer Sensor
The Cycle and Uptime Tracker is an innovative device engineered to monitor and record the number of cycles and total uptime of machinery or equipment in industrial environments. Leveraging advanced acceleration sensing technology, users can set customizable acceleration thresholds to precisely detect cycle initiations. This allows for accurate tracking of machine activity while minimizing false readings. The device captures and stores data, providing insights into equipment usage patterns and overall uptime. With its user-friendly interface and customizable settings, operators can easily configure acceleration thresholds to suit specific machinery requirements. Ideal for diverse industrial applications, the Cycle and Uptime Tracker enhances maintenance planning, optimizes production scheduling, and improves operational efficiency.
Magnetometer Sensor
Magnetic Field-Based Machine On/Off Detection System is meticulously engineered to precisely discern the operational status of machinery that emits magnetic fields during operation. Employing cutting-edge magnetic field sensors, this system offers unparalleled accuracy in identifying whether the machine is active or inactive. With its robust design and reliable performance, there’s no need for user adjustments, ensuring hassle-free operation. Real-time monitoring capabilities enable proactive maintenance planning and energy conservation, enhancing operational efficiency. Seamlessly integrating into various industrial setups, this system represents a pinnacle of reliability and professionalism in machine monitoring solutions.
Current Sensor
Industrial Machine Uptime and Cycle Counter, a cutting-edge solution that accurately measures total machine uptime and cycle counts using advanced current sensor technology. With real-time monitoring and seamless integration, our device enables proactive maintenance planning, enhances operational efficiency, and provides valuable insights for informed decision-making. Upgrade your industrial operations with precise tracking and analysis capabilities for optimized performance and cost savings.
Sensor Power
This Sensor has two power options.
  1. Powered by AA batteries ( NCD recommends Energizer L91 batteries)
  2. External Power Supply ( 5-12VDC) Current Requirement 250mA
The L91 Batteries are non-rechargeable Li-Ion batteries.
While changing the batteries
  1. Turn off  The sensor
  2. Only use new L91 batteries
  3. Checkout the Polarity marking on the Battery Holder and Batteries
  4. Replace All six batteries with new L91 batteries. Do not mix old and new batteries
  5. Batteries should not be replaced in fire-risky areas
  6. Do NOT install rechargeable batteries
    Note — If these Devices are being used with photo eye or any other sensors needing power, use an external power supply.
Gateway
In Order to receive the sensor data, A gateway or Modem is required. The receiver can receive data from multiple sensors.
ncd Gateways comes with node red pre installed. To know more about node red dashboard check this article
Sensor Radio Technology
NCD Long Range Wireless Sensors are available with many radio options, which should be carefully chosen based on the country of installation. NCD uses Digi radios exclusively because of their best-in-class range, reliability, wide operating temperature, and low power operation. Please note that not all options are legal for use in all areas, so it’s important to make the right selection during purchase.  NCD manufactures sensors based on the radio options chosen, we do not typically restrict radios to certain countries so please check local laws BEFORE purchase.  Here, we will explain the radio options in greater detail to help guide users into the correct radio based on installation country.
XBee PRO 538 External Module without Antenna
900MHz for Use in the United States
If NCD sensors will be installed within the United States, the 900MHz (North America) option is the best choice, offering the longest possible range of up to 2 Miles Line of Sight and up to 28 Miles using High-Gain Antennas.  This option can typically work up to 1,000 feet indoors (depending on building materials, concrete and steel building typically reduce the operational range significantly).  This option is typically not legal for use outside North America.
868MHz Module
868MHz for Use in Europe
If NCD sensors will be installed in Europe, the 868MHz (Europe Only) option is the best choice, offering the longest possible range of up to 14.5km Line of Sight.  This option is typically not legal for use outside of Europe.
2.4GHz Module
2.4GHz for Worldwide Use
The 2.4GHz Option is generally legal for use in most countries, including Europe and the United States and offers a range of up to 2 Miles (3200 Meters) Line of Sight or up to 300 feet (about 90 Meters) indoors.  Because of the widespread use of 2.4GHz, the rated ranges are rarely achieved.  The 900MHz and 868MHz communication modules are a far better choice for users in the United States and Europe respectively.  Users who may require worldwide compliance should use the 2.4GHz option, but this option should be considered if the above options are not legal for use.
Sensor Internal Overview
Status LED – The status led is used to indicate errors or other sensor diagnostics.
LED Blink Once – Message was sent successfully and no error in last sensor read as well in data transmission
LED Blink Twice and then One more time —  Message was sent successfully but there was an error in last sensor read
LED blink Thrice — MCU is having issue communicating with Radio Module
Software API Structure
6
Machine Uptime Monitoring Sensor Payload Structure
Field Description Comment
Header7FAPI Data Header ( its not the API Header)
Node ID00User Defined ID
Firmware Version01Device Firmware Version
Battery Level03,FEBattery Voltage = 0.00322*(03*FF+FE)
Packet CounterDEWireless Transmission Counter
Sensor Type00,0x51Sensor Type 80
Error/Reserve Byte00
Current Value in A (x100)D0,D1Current = (D0<< 8 | D1)/100
Digital Input 1 CounterD2,D3,D4,D5Counter 1 = D2 << 24 | D3 << 16 | << D4 << 8 | D5
Digital Input 1 UptimerD6,D7,D8,D9Uptimer 1 = D6 << 24 | D7 << 16 | << D8 << 8 | D9
Digital Input 2 CounterD10,D11,D12,D13Counter 2 = D10 << 24 | D11 << 16 | << D12 << 8 | D13
Digital Input 2 UptimerD14,D15,D16,D17Uptimer 2 = D14 << 24 | D15 << 16 | << D16 << 8 | D17
Digital Input 3 CounterD18,D19,D20,D21Counter 3 = D18 << 24 | D19 << 16 | << D20 << 8 | D21
Digital Input 3 UptimerD22,D23,D24,D25Uptimer 3 = D22 << 24 | D23 << 16 | << D24 << 8 | D25
Accelerometer CounterD26,D27,D28,D29Accelero Counter = D26 << 24 | D27<< 16 | << D28 << 8 | D29
Accelerometer UptimerD30,D31,D32,D33Accelero Uptimer = D30 << 24 | D31 << 16 | << D32 << 8 | D33
Magnetometer CounterD34,D35,D36,D37Magneto Counter = D34 << 24 | D35<< 16 | << D36 << 8 | D37
Magnetometer UptimerD38,D39,D40,D41Magneto Uptimer = D38<< 24 | D39 << 16 | << D40 << 8 | D41
Sensor Configuration Structure
The following guide demonstrates the fundamental configuration commands required to configure NCD Enterprise Low-Power Long Range Wireless Sensors.  A Wireless USB Modem will be required to configure NCD wireless sensors over a wireless connection.  The examples shown below assume prior knowledge of DigiMesh® API Packet Structure, including MAC addresses and checksum calculations.
Please note the MAC address MUST be changed (shown in the API frames below as 00 13 A2 00 41 91 1B 83) to match the MAC address of a remote sensor.  The checksum must also be re-calculated (the last byte of the API frame) to include the new MAC address.  Additionally, the PAN ID must be set to 0x7BCD.   This PAN ID is reserved for configuration ONLY, and may not be used for daily operation.
The commands shown below are explained in greater detail within product manuals, this guide is a summary overview of all configuration command samples.  Also note that configuration commands cannot be sent to NCD wireless sensors while in run mode.  Each sensor must be placed in configuration mode, which will drain the battery very quickly.  Be SURE to execute these commands quickly and return each sensor to RUN mode to preserve battery life.  Optionally, select NCD wireless sensors may be powered from a external power supply during configuration.
Enter Configuration Mode
To configure Gen 2 sensors, two distinct approaches are available:
Method 1: Manual Configuration In this method, we employ both the config and reset buttons to initiate configure mode. To start, press and release the reset button, wait for 1 second, then press and hold the config button for 6 to 10 seconds before releasing it. This action puts the device into configure mode. Once in this mode, Node-RED can be used to adjust the sensor’s settings.
Method 2: Over The Air (OTA) Configuration Gen 2 devices are capable of OTA configuration, which allows for remote adjustments. In this mode, the device broadcasts a “FLY” message approximately every hour, signaling its readiness to receive new configurations. The “FLY” message essentially indicates, “I am awake; send me commands or configuration settings.” Node-RED can capture this message and transmit the desired settings to the sensor. This approach enables users to configure the sensors without physical interaction. Additionally, activating the reset button prompts the device to emit the “FLY” message immediately, facilitating quicker configuration.
Factory Resetting the Device To perform a factory reset, press and release the reset button, wait for 1 second, and then press and hold the config button for 20 seconds. After releasing the config button, wait for 2 seconds, then press and release the reset button again. This sequence will effectively factory reset the device.
Step 1 : Power up the sensor.
Step 2: Every sensor has 2 buttons: Reset and Configuration (RST and CFG).  Enter configuration mode by holding both buttons down.  Next, release the reset button.  Wait 6 seconds and release the CFG button.  The sensor will send a Configuration API frame, indicating configuration mode is active.  The API frame will look similar to this:
7E 00 1C 90 00 13 A2 00 41 91 1B 83 FF FE C2 7A 00 00 00 23 00 00 50 47 4D 00 00 00 00 00 00 0A
Above command contains the sensor MAC address. This MAC address may be used to send future targeted commands to this particular sensor.
In the above case, the MAC address is:
Note: Throughout this guide we will be sending data in broadcast mode and sensors ID and node ID will be set to 0. This is done to make these commands work with all the sensors and all the nodes. These commands may be used with all the sensors without any change.
For optimal performance keep only one sensor in config mode at a time.
Reminder: During configuration mode, the sensor PAN id needs to be set as 0x7BCD.
Warning: Batteries will drain quickly in configuration mode.  Be sure to exit configuration mode as soon as possible by pressing and releasing the Reset (RST) Button on the sensor once configuration changes have been completed.
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
Read Sensor Network ID
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Set Sensor Destination to Broadcast
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Read Wireless Sensor Retries
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep.  But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data.  If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep.  The sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Set Wireless Sensor number of Retries
Complete Payload
F7 06 00 00 00 05
Complete Payload
Configuration Commands Table
1Set Broadcast Transmission 0XF70x010000FFFFThis will set the address to Broadcast mode. All the receiver with same ENY key and PAN ID will get the data packets
7Read Sleep Interval0XF70x150x00,0x02,0x58Reads the stored Sleep Interval value from the sensor
8Read Power0XF70x160x04Reads the stored RF Power value from the sensor
9Read Retries0XF70x170x0AReads the stored Retries value from the sensor
10Read Destination Address0XF70x1800,00,FF,FFReads the stored Destination value from the sensor
11Read PAN ID aka Network ID0XF70x190x7FFFReads the PAN ID aka Network ID
12Enable Encryption 0XF20x010x01Enables the Encryption of the Frame Transmitted from the Sensor
13Disable Encryption 0XF20x02Disables the Encryption of the Frame Transmitted from the Sensor
Sensor App Specific Configuration Commands Table
COMMANDCOMMANDSUB COMMANDCOMMAND CODEARGUMENT
SET Acceleration Threshold0xF40x200x14This example command will set the acceleration threshold to 20*32mg = 640mg
GET Acceleration Threshold0xF40x21
Clear all counters0xF40x240x1FReset all counter values to 0
Clear Accelerometer Counter 0xF40x240x08Reset Acc counter values to 0
Clear Magneto Counter 0xF40x240x10Reset AMag counter values to 0
Set Current Calibration 0xF40x250xC, 0xE4This will set calib value to 3300
Get Current Calibration 0xF40x26read stored calibration Value
Device Inputs and Working Principle
7
  1. NPN and PNP Sensor Basics: These sensors operate within a voltage range of 9 to 24 volts. The output voltage can either match the input voltage or typically be around 5 volts, depending on the sensor type. For instance, a beam break sensor, when its beam is interrupted, outputs 5 volts, and when the beam is intact, it outputs 0 volts.
  2. Connection via the M1 Connector: This involves ensuring the internal cable connects from M1 to the opto-coupler (opto). The M1 connector has specific pins for various connections: Pin 1 for input positive, Pin 2 for 3.3 volts, Pin 3 for input negative, Pin 4 for ground, and Pin 5 for VIN (Voltage Input).
  3. Beam Break Sensor Connection: The positive lead of the beam break sensor (or power supply positive) connects to Pin 5, the ground to Pin 4, and the sensor’s signal output to Pin 3. This setup allows the system to detect beam interruptions, count their occurrences and durations, and send this data to a receiver or gateway based on predefined intervals.
  4. 24 Volt AC or DC Signal Reading: The same M1 connector setup can read 24V signals from machinery or devices like PLCs or SCADA systems. Connections for these signals are similar to the beam break sensor, with the primary difference being the connection of 24V positive and negative signals between Pin 1 and Pin 3.
  5. Current Sensor Connection: The current sensor also connects to the M1 connector. Users must ensure the Molex cable runs from M1 to the current sensor. The sensor, designated as 100 MCT, allows for threshold setting via an onboard potentiometer. This setup is designed to monitor current flow, triggering the system when current exceeds a predetermined threshold (e.g., 5 amps).
  6. Digital Input Pin Connection: Alongside the current sensor, a digital input pin for contact closure inputs (e.g., from relay boards or read switches) can be connected. This allows the device to count cycles and monitor on-time based on the state of these inputs.
  7. Open Collector Inputs: Some sensors provide open collector outputs when active. To use these, the sensor’s output needs to be pulled high or low using onboard switches. The system counts on-time and cycles based on the sensor’s state, with connections similar to those for the opto-coupler.
  8. Uptime Calculation via Acceleration and Magnetic Field Detection: Beyond electrical signals, the system can calculate uptime through vibration (acceleration) and magnetic field detection. Users set thresholds for these parameters, enabling the device to start or stop counting based on the presence of vibrations or a magnetic field, respectively.
This comprehensive approach ensures versatile and accurate monitoring of machine uptime, accommodating a wide range of sensor types and signals.
Installation Guidelines
8
Vibration Sensor installation is an extremely critical step; in order to ensure the best results, sensor mounting guidelines should be followed.
A. Sensor Main Body Mount — The sensor main body has four magnets. These magnets make it easy to mount. During mounting, make sure
  1. The sensor is Powered on ( the switch should be positioned towards the wall of the enclosure if using battery and on the other side if using with external power)
  2. The antenna is installed and pointed vertically to the ground
  3. Install the main sensor box as high as possible to avoid any object that might come in between the sensor and modem/gateway
  4. Antenna should not be installed inside any metal box
B. Sensor Probe — Mounting will depend on the probe type.
Troubleshooting Guide
9
ncd vibration sensor V3 can be used with any ncd modems and gateway and from there data can be pushed to any cloud or local server.
If there is no data on the gateway side, here are few things users can check
  1. Sensor is powered on
  2. Batteries are in good condition ( Leaving the sensor in cfg mode for a long time will drain batteries)
  3. Antenna is connected and pig tail is secured
  4. Press the reset button and sensor will send a welcome message followed by a sensor data packet.
  5. Check the LED status. if the LED is blinking as expected, means sensor is working
On the Receiver side —
  1. If you are using a modem make sure correct port settings are selected
  2. Sensor radio module and Modem/gateway radio module are of same frequency
  3. Gateway is connected to WiFi
  4. Gateway and Sensor are atleast 3 feet apart
