Lorawan Wireless IoT Sensors Support Map
The following map is meant to provide a summary of support for NCD Long Range Wireless IoT Sensors.  Please feel free to contact us to request additional support resources for NCD long range wireless IoT sensors.  We will do our best to support sensors within the context of this map.
SensorSensor TypeSKU​Default Transmission IntervalNotes
Temperature Humidity Sensor1PR62-1A30min
Contact Closure Sensor2PR62-1CCClass A
Thermocouple Sensor4PR62-1TCClass A
One Channel AC Current Sensor13PR62-1CTClass A
Activity Sensor24PR62-1IClass A
Pressure Sensor26PR62-1PClass A
Dust Temp Humidity Sensor32PR62-1MClass A
Tank Level Sensor34PR62-1TClass A
RTD Temperature Sensor39PR62-3PClass A
1 Channel Digital Counter35PR62-1CClass A
Water Detect Sensor41PR62-1WSClass A
One Channel 0-24VDC Input Transmitter 42PR62-1DCClass A
CO2 Temp Humidity Sensor44PR62-1QClass A
One Channel 4-20mA Input Transmitter 45PR62-1FClass A
Tilt Sensor47PR62-1TSClass A
One Channel 0-10VDC Input Transmitter 48PR62-1GClass A
One Channel 4-20mA Output Transmitter 49PR62-1HClass C
One Channel 0-10VDC Output Transmitter 50PR62-1IClass C
One Channel Relay Output59PR62-2RClass C
Vibration Sensor80PR62-1EClass A
predictive maintenance sensor82PR62-1PMClass A
Yes – Sensor is Supported
Untested – Sensor Support has Been Added, but Not Tested
Blank – Sensor is Not Yet Supported
Please note this chart indicates our best estimation for sensor support.  This in no way guarantees bug free operation within gateway firmware or software support. Support for indicated sensors assumes the latest release version, which may not yet be available to the public.  This chart was last audited on July 10th, 2024.
      Â
