- Industrial Grade 2 Channel Counter
- 16 bit counters
- Minimum detectable pulse width 100 msec
- Highly Accurate Pulse Counting
- Low Latency Transmission
- Adjustable Counting Threshold for transmission (factory configurable)
- Two modes of Operation
- Real time battery status
- Description
- Getting Started
- Modes of Operation
Introducing NCD’s Long Range IoT Wireless Two Channel Counter, boasting up to a 28 Mile range using a wireless mesh networking architecture. It incorporates two low latency counters that never miss a pulse even during sleep. The device normally sleeps during no activity. If a pulse arrives at either input, it wakes up, counts it and if the number of pulses counted is a multiple of Counting Threshold then it sends a packets with the total number of pulses detected on both channels until then.
Afterwards it goes back to sleep. It also wakes up periodically after user defined delay and sends latest number of pulse counts on both channels. Thus with both functions it maximizes power efficiency.
The long range, price, accuracy, battery life and security features of Long Range IoT Wireless Two Channel Counter with Reset makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
- Pulse counting
- Relay on/off counting
- Home Automation
- IoT Long Range Wireless Two Channel Counter Transmitter (with power source Battery Or External DC)
- Run Mode
- Configuration Mode
Header | 0 | 0x7F |
Firmware | 2 | – |
LSB 4 | – | ||||
Packet Counter | 5 | – |
Sensor Type | MSB 6 | 0x00 |
MSB 7 | 0x24 | ||||
Reserved | 8 | 0x00 |
Sensor Data | 9/ Data[0] | – |
10/ Data[1] | – | ||||
11/ Data[0] | – | Counter 2 Counts Counts = (Data[0]<<8)+Data[1] | |||
12/ Data[1] | – |
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0024 D8
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0024 0000 0004 D3
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0024 1234 5678 C2
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0024 02D3
Command For COPY: 7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0024 7CDE 7A
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0024 03D0
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0024 C4
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0024 C3
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0024 C2
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0024 C1
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0024 C0
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0024 DD
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0024 DC
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0024 0011 2211 2211 2211 2233 4433 4433 4433 4433
B. Appendix
- Keep only the last 8 bits
Set Counter Delay
- Set counter One Value
7E 00 15 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 01 00 00 00 13 88 64
In this command we are setting counter one Value to 5000.
2. Read counter one Value
7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 02 00 00 00 FE
3. Set counter Two Value
7E 00 15 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 03 00 00 00 13 88 62
In this command we are setting counter Two Value to 5000.
4. Read counter Two Value
7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 04 00 00 00 FC
