Long Range IoT Wireless Temperature Barometric Pressure Sensor Product Manual
  • Industrial Grade Sensor
  • Operating Range 10 to 14000 mbar, -40°C [-40 °F] to +85 °C [185 °F]
  • Configurable Internal Calculation Pressure Resolution 0.2 to 1 mbar
  • Configurable Internal Calculation Temperature Resolution 0.002 to 0.012 °C
  • Accuracy ±20 mbar, ±0.8 °C
  • Absolute Pressure, Relative Pressure and Relative Altitude Change outputs
  • Two modes of Operation
  • Real time battery status
Introducing NCD’s Long Range IoT Wireless Temperature Barometric Pressure Sensor, boasting up to a 28 Mile range using a wireless mesh networking architecture. Incorporating a MS5803 pressure sensor, transmits highly accurate data at user-defined intervals. It measures pressure and temperature with user configurable resolution at user defined intervals while sleeping during the time when it is not measuring or sending data.
Moreover, it takes baseline pressure input from user to determine subsequent change in altitude. It also takes baseline altitude from user to determine relative pressure with respect to that altitude. Default resolution, sleep time, baseline pressure and baseline altitude are shown in Table 1.
The long range, price, accuracy, battery life and security features of Wireless Temperature Barometric Pressure Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
  • Wireless Mobile Altimeter/Barometer
  • Home Automation
wireless pressure temperature sensor
  • Run Mode
  • Configuration Mode
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2–
Battery VoltageMSB 3–
LSB 4–
Packet Counter5–
Sensor TypeMSB 60x00
MSB 70x06
Reserved80x00for future use
Sensors Data9/ Data[0]–
Temperature Data (Resolution 1°C)
          Temperature(°C) = (Data[0]<<8)+Data[1]
10/ Data[1]
11/ Data[0]
Absolute Pressure (Resolution 1 mbar)
   Absolute Pressure (unsigned) = ((Data[0]<<8)+Data[1])/1000
12/ Data[1]
13/Data[0]
Relative Pressure (Resolution 1 mbar)
     Relative Pressure (signed) = ((Data[0]<<8)+Data[1])/1000
this pressure is calculated with respect to the baseline altitude provided by the user/default baseline altitude
14/Data[1]
15/Data[0]–
Altitude Change (meters)
      Altitude change (signed) = ((Data[0]<<8)+Data[1])/100
This change in altitude is calculated with respect to the baseline pressure provided by the user. If the user does not provide it or sets it to a 0 value, the device will use the pressure read at power up as baseline pressure
16/Data[1]–
Reserved17,18,19,20–
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0006 F6
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0006 0000 0004 F1
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0006 1234 5678 E0
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0006 02F1
Command For COPY: 7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0006 7CDE 98
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0006 03EE
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0006 E2
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0006 E1
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0006 E0
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0006 DF
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0006 DE
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0006 FB
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0006 FA
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0006 0011 2211 2211 2211 2233 4433 4433 4433 4451
15. Set Baseline/Current Altitude
Command For COPY: 7E00 1510 0000 0000 0000 00FF FFFF FE00 00F4 0100 0006 00EF 0A
16. Set Temperature Precision
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0200 0006 08F0
17. Set Pressure Precision
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0300 0006 08EF
18. Set Baseline Pressure
Command For COPY: 7E00 1510 0000 0000 0000 00FF FFFF FE00 00F4 0400 0006 0000 F6
19. Read Baseline Altitude
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0500 0006 F5
20. Read Temperature Precision
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0600 0006 F4
21. Read Pressure Precision
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0700 0006 F3
22. Read Baseline Pressure
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0800 0006 F2
B. Appendix
  2. Keep only the last 8 bits
