Long Range IoT Wireless 7 Channel Push Notification Sensor Product Manual
  • Industrial Grade Sensor with µs latency
  • Sleeps when no push input detected
  • Detects up to 7 Inputs in parallel
  • Can be used as Push Notification or Digital Input
  • 2 Analog Inputs measurement
  • Two modes of Operation
  • Real time battery status
Introducing NCD’s Long Range IoT Wireless 7 Channel Push Notification Sensor, boasting up to a 28 Mile range using a wireless mesh networking architecture.  It detects up to 7 push inputs with low latency and sends out a frame, while sleeping rest of the time to minimize power consumption. Optionally, user can also set a sleep duration which will make sure that the sensor wakes up after a certain time and sends out a frame even when no push input is detected. Additionally, it also measures 2 analog inputs. This device can be used for Push notification as well as for digital input.
The long range, price, accuracy, battery life and security features of Wireless 7 Channel Push Notification Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
  • Multiple Input Push Notification
  • Wireless Analog Input Measurement
  • Digital Signal Monitoring
  • Home Automation
wireless digital input controller
  • Run Mode
  • Configuration Mode
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2
Battery VoltageMSB 3
LSB 4
Packet Counter5
Sensor TypeMSB 60x00
MSB 70x25
Reserved80x00
For future use
Sensors Data9/Push Input
Push Input
MSB      LSB
Bit 76543210
XI7I6I5I4I3I2I1
10/ Data[0]
ADC 1 Counts/Battery Voltage
          ADC Counts = (Data[0] x 256)+Data[1]
11/ Data[1]
12/ Data[0]
ADC 2 Counts/Battery Voltage
13/ Data[1]
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0025 D7
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0025 0000 0004 D2
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0025 1234 5678 C1
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0025 02D2
Command For COPY: 7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0025 7CDE 79
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0025 03CF
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0025 C3
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0025 C2
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0025 C1
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0025 C0
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0025 BF
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0025 DC
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0025 DB
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0025 0011 2211 2211 2211 2233 4433 4433 4433 4432
B. Appendix
  2. Keep only the last 8 bits
