IoT Wireless Vibration Sensor Product Manual
  • Industrial Grade 3-axis Vibration Sensor with RMS, MAX and MIN acceleration in g
  • Vibration Range ±16g
  • Noise Removal using Low pass filter
  • Frequency Range 0.1 to 408 Hz (Bandwidth: 408 Hz)
  • Sampling Rate up to 952 Hz
  • Builtin Offset and Gravity vector removal filters
  • Up to 256 Sensor Nodes per Network
  • Small Form Factor (3×3 inch)
  • Multiple Modes of Operation (Configuration and Run mode)
  • Wireless Sensor and Radio Configuration feature
  • Default Factory settings Restore option
  • Power Efficient Built-in Sleep mode
  • Reliable Transmission incorporating packet Retries
  • Secure Transmission using AES-128 Encryption
  • Real time battery status
  • Wireless Industrial Machine Health Analysis
  • Machine fault detection
  • Building and structural monitoring
  • Home Automation
Introducing NCD’s IoT Wireless Vibration Sensor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. Incorporating a 3 Axis Vibration sensor, transmits highly accurate data at user-defined intervals.
This Vibration Sensor samples 3-axis of Accelerometer for vibration for 500 msec and then calculates RMS, Maximum and Minimum Vibration in this interval. It then combines this data with temperature samples in a packet to be sent to one or multiple receivers. At power up, it reads multiple samples and takes their average as an offset value. This value is subtracted from every sample taken afterwards. Therefore, make sure to power off the device under test during sensor power up. Once the sensor stabilizes and starts sending data, the device/machinery under test can be powered on. After it sends data for the 500msec interval, it goes back to sleep for a user defined interval, thus minimizing power consumption.
The range, price, accuracy, battery life and security features of Wireless Vibration Sensor make it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
The Vibration Sensor  and Zigmo/Router come pre-programmed and work out of the box. In this section we will setup a sensor and Zigmo link and start receiving data on our PC. Though this guide shows how to visualize data on LabVIEW utility, you can also use a simple serial terminal to see raw data by following these steps.
Note: The Wireless Sensor comes with external power enabled, for battery conservation during shipping. To enable battery power, open the enclosure and set the PS (power select) jumper which is parallel to the marking line on the board.
  1. Press the Run button to visualize incoming data.
Modes of Operation
  • Run Mode
  • Configuration Mode
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2–
Battery VoltageMSB 3–
LSB 4–
Packet Counter5–
Sensor TypeMSB 60x00
MSB 70x08
Reserved80x00
For future use
Vibration RMS 9/X[0]–
Vibration RMS X-axis Data (24 bit Signed Output)
        Vibration (mg) = ((X[0]<<16)+(X[1]<<8)+X[2])/100
(Saving directly to 32 bit integer will give wrong result
 10/X[1]–
 11/X[2]–
 12/Y[0]–
Vibration RMS Y-axis Data (24 bit Signed Output)
        Vibration (mg) = ((Y[0]<<16)+(Y[1]<<8)+Y[2])/100
 13/Y[1]–
 14/Y[2]–
 15/Z[0]–
Vibration RMS Z-axis Data (24 bit Signed Output)
        Vibration (mg) = ((Z[0]<<16)+(Z[1]<<8)+Z[2])/100
 16/Z[1]–
 17/Z[2]–
Vibration Max 18/X[0]–
Vibration Max X-axis Data (24 bit Signed Output)
 19/X[1]–
 20/X[2]–
 21/Y[0]–
Vibration Max Y-axis Data (24 bit Signed Output)
 22/Y[1]–
 23/Y[2]–
 24/Z[0]–
Vibration Max Z-axis Data (24 bit Signed Output)
 25/Z[1]–
 26/Z[2]–
Vibration Min 27/X[0]–
Vibration Min X-axis Data (24 bit Signed Output)
 28/X[1]–
 29/X[2]–
 30/Y[0]–
Vibration Min Y-axis Data (24 bit Signed Output)
 31/Y[1]–
 32/Y[2]–
 33/Z[0]–
Vibration Min Z-axis Data (24 bit Signed Output)
 34/Z[1]–
 35/Z[2]–
Temperature Data 36/T[0]–
 Temperature data (16 bit Signed Output)
        Temperature (°C) = (T[0]<<8)+T[1]
 37/T[1]–
The UI, shown in Figure 16, can be used to configure the wireless sensor. At startup, it automatically changes the Zigmo PANID so that it can communicate with a sensor in configuration mode (indicated by the Led on the top right). Upon exit, the PANID of the Zigmo is restored to old value.
Individual settings can be programmed using the single command column.
The AUTO PROGRAMMING check option allows the user to setup multiple sensors with the same settings. In such a scenario, the user will be required to enable each check box for enabling a setting, enter the value for each setting if required and then check the auto programming check box. Afterwards, when a sensor is powered up and enters configuration mode, the PGM MODE DETECTED Led will flash and automatically program the checked settings. User can also program multiple settings by clicking the APPLY SELECTED button. Moreover, settings can be read using the individual buttons or all settings can be read using the READ ALL button.
Figure 16: Configuration mode User Interface
Appendix A
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0008 F4
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0008 0000 0004 EF
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0008 1234 5678 DE
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0008 02EF
Command For COPY: 7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0008 7CDE 96
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0008 03EC
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0008 E0
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0008 DF
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0008 DE
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0008 DD
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0008 DC
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0008 F9
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0008 F8
Command For COPY: 7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0008 0011 2211 2211 2211 2233 4433 4433 4433 444F
Appendix B
  1. Add all the bytes and keep the lower 8 bits of result (Excluding the frame delimiter and length)
  4. Append this byte at the end of the original packet for sending
  1. Add all the bytes including the received checksum (Exclude the frame delimiter and length)
  2. Keep only the last 8 bits
