IoT Wireless TVOC CO2eq Temperature Humidity Sensor Product Manual
  • Industrial Grade Gas and Temperature Humidity Sensor
  • High Resolution TVOC and CO2eq output
  • TVOC output range 0 to 60,000 ppb
  • CO2eq Output range 400 to 60,000 ppm
  • Low long term drift ( 1.3% of measurement value)
  • Industrial Grade Sensor with Range 0 to 100% RH / -25°C [-13°F] to 85°C [185°F])
  • Resolution 0.04% RH/0.025°C
  • Accuracy 2% RH/ 0.3°C
  • 256 Sensor Node per Network
    • Up to 300,000 Transmissions from 4 AA Batteries
  • Improved reliability incorporating Retry feature in case of packet loss
  • Real time battery status
  • In House Temperature Humidity monitoring
  • Hospital Air quality monitoring
  • Indoor Gas monitoring
  • HVAC application
  • Storage Unit Weather Monitoring System
  • Warehouse Health Monitoring System
  • Home Automation
Introducing NCD’s long-range wireless TVOC and CO2eq Gas Sensor With temperature humidity sensor, boasting up to a 28 Mile range using a wireless mesh networking architecture.  Incorporating the SGPS30 and SHT30 temperature humidity sensor, transmits highly accurate TVOC, Co2eq, Raw Ethanol, H2, temperature and humidity samples at user-defined intervals.
The on-board temperature sensor is rated for -25°C to 85°C or -13°F to 185°F and the humidity sensor is rated for 0 to 100% RH.  Powered by just 4 AA batteries and an operational lifetime of 300,000 wireless transmissions, a 10 years battery life can be expected depending on environmental conditions and the data transmission interval.  Optionally, this sensor may be externally powered.
OutputRangeResolution
TVOC0 ppb – 2008 ppb1 ppb
 2008 ppb – 11110 ppb6 ppb
 11110 ppb – 60000 ppb32 ppb
CO2eq400 ppm – 1479 ppm1 ppm
 1479 ppm – 5144 ppm3 ppm
 5144 ppm – 17597 ppm9 ppm
 17597 ppm – 60000 ppm31 ppm
The Minimum data transmission interval for this TVOC and CO2eq Gas Sensor  1 min .
Sensor calibration / initial start up routine
Place the sensor in a cleanest possible area for first 60 seconds
  1. After the first boot
  2. After reset
  3. After changing batteries
  4. After power cycle
During the first 60 seconds sensor will self calibrate and will use these environment condition as base condition.
With an open communication protocol this IoT wireless TVOC and CO2eq Gas Sensor for Air Quality Monitoring product can be integrated with just about any control system or gateway.  Data can be transmitted to a PC, a Raspberry Pi, to Microsoft Azure® IoT, or Arduino. Sensor parameters and wireless transmission settings can be changed on the go using the open communication protocol providing maximum configurability depending on the intended application.
The long range, price, accuracy, battery life and security features of Long Range Wireless TVOC and CO2eq Gas Sensor for Air Quality Monitoring makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
Sensor Type – 31
  1. Power-up the Wireless Sensor and make sure its antenna is installed
Figure 3: LabVIEW Utility for Temp Humidity Sensor
Figure 4: LabVIEW Utility for Temp Humidity sensor showing incoming data
Modes of Operation
  • Run Mode
  • Configuration Mode
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2–
Battery VoltageMSB 3–
LSB 4–
Packet Counter5–
Sensor TypeMSB 60x00
MSB 70x1F
Reserved8error code
error code = 1 ( data was not ready)
Humidity
MSB 9/ Data[0]–
Humidity data
    Humidity(usigned) = ((data[0] x 256) + data[1])/100
LSB 10/ Data[1]–
TemperatureMSB 11/ Data[2]–
Temperature data
    Temperature(signed) = (((data[2] x 256) + data[3])/100)°C
LSB 12/ Data[3]–
CO2eq in ppmMSB 13/ Data[4]–
CO2 eq (signed) = (((data[4] x 256) + data[5])) ppm
LSB 14/ Data[5]–
TVOC in ppbMSB 15/ Data[6]–
TVOC (signed) = (((data[6] x 256) + data[7])) ppb
LSB 16/ Data[7]–
Raw H2MSB 17/ Data[8]–
H2 (signed) = (((data[8] x 256) + data[9]))
LSB 18/ Data[9]–
Raw Ethanol MSB 19/ Data[10]–
Ethanol (signed) = (((data[10] x 256) + data[11]))
LSB20/ Data[11]–
Appendix A
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0001 FB
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0001 0000 0004 F6
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0001 1234 5678 E5
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0001 02F6
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0001 03F3
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0001 E4
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0001 E3
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0001 00
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0001 FF
15. Force Sensor Clean
Command For Copy — 7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 1A 00 00 00 E4
Appendix B
  2. Keep only the last 8 bits
