IoT Wireless Temperature Humidity Current Detect Sensor Product Manual
  • Two Industrial Grade Sensor  Probes with Range 0 to 100% RH / -25°C [-13°F] to 85°C [185°F])
  • 0-100Amp AC Current Detection Sensor
  • Resolution 0.01% RH/0.01°C
  • Accuracy 2% RH/ 0.2°C
  • 256 Sensor Node per Network
  • Improved reliability incorporating Retry feature in case of packet loss
  • Real time battery status
  • In House Temperature Humidity monitoring
  • Machine On/Off State Detection
  • HVAC System Efficiency Monitoring
  • Industrial Air Handler Monitoring
  • Warehouse Temperature Humidity Monitoring System
  • Wireless Temperature Humidity Sensor For Crawl Space
  • Temperature Humidity Sensor For Device Control Application
  • Wireless Temperature Humidity Monitoring For Raspberry Pi/Arduino
Introducing NCD’s long-range wireless Dual temperature humidity Current Detect sensor, boasting up to a 28 Mile range using a wireless mesh networking architecture.  Incorporating the Honeywell temperature humidity sensor, transmits highly accurate temperature and humidity samples at user-defined intervals. AC Current Detection sensor transmitters makes it easy to receive alerts when the AC current value exceeds the preset limits. This current limit can be set us a on-board Potentiometer.  This IoT long range wireless AC Current Detection sensor transmitter includes one 0-100Amp AC Current Sensor. This input can be used to detect if there is any current flowing through the sensor.  The input current range is 0-100A AC.
The on-board temperature sensor is rated for -25°C to 85°C or -13°F to 185°F and the humidity sensor is rated for 0 to 100% RH.  Powered by just 4 AA batteries and an operational lifetime of 500,000 wireless transmissions, a 10 years battery life can be expected depending on environmental conditions and the data transmission interval.  Optionally, this sensor may be externally powered.
With an open communication protocol this IoT wireless temperature humidity product can be integrated with just about any control system or gateway.  Data can be transmitted to a PC, a Raspberry Pi, to Microsoft Azure® IoT, or Arduino. Sensor parameters and wireless transmission settings can be changed on the go using the open communication protocol providing maximum configurability depending on the intended application.
The long range, price, accuracy, battery life and security features of Long Range Wireless Temperature Humidity Current Detect Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
This Sensor Sends data When
A. AC current Exceeds the pre defined limit
B. After pre defined sleep interval
  1. Power-up the Wireless Sensor and make sure its antenna is installed
Figure 3: LabVIEW Utility for Temp Humidity Sensor
Figure 4: LabVIEW Utility for Temp Humidity sensor showing incoming data
Modes of Operation
  • Run Mode
  • Configuration Mode
Table : 3
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2–
Battery VoltageMSB 3–
LSB 4–
Packet Counter5–
Sensor TypeMSB 60x00
MSB 70x2B
Reserved80x00
For future use
Sensors Data9/ Data[0]0x00
Current Above set limit == 1
Current Below Set limit ==0
10/ Data[1]0x00RES
11/ Data[2]
Humidity data Sensor One
    Humidity(usigned) = ((data[2] x 256) + data[3])/100
12/Data[2]
13/ Data[3]
Temperature data Sensor One
    Temperature(signed) = (((data[3] x 256) + data[4])/100)°C
14/ Data[4]
15/ Data[5]
Humidity data Sensor Two
    Humidity(usigned) = ((data[5] x 256) + data[6])/100
16/ Data[6]
17/Data[7]
Temperature data Sensor Two
18/Data[8]
Appendix A
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0001 FB
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0001 0000 0004 F6
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0001 1234 5678 E5
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0001 02F6
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0001 03F3
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0001 E4
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0001 E3
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0001 00
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0001 FF
Appendix B
  2. Keep only the last 8 bits
  • Industrial Grade Sensor with µs latency
  • Sleeps when no push input detected
  • Two modes of Operation
Introducing NCD’s IoT Wireless Push Notification Sensor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture.  It transmits highly accurate frames with low latency for every push input or at user-defined intervals.
The range, price, accuracy, battery life and security features of Wireless Push Notification Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
Note: This manual is shared with IoT Long Range Wireless 24V AC/DC Voltage Detection Sensor as well.
  • Push Notification
  • Wireless input change detection
  • Digital signal monitoring
  • Home Automation
battery powered iot push notification
  • Push Notification Type Iot Wireless Sensor (with power source Battery Or External DC)
  • Zigmo/Router for PC (One Router will work with Multiple Sensors)
  • ·         PC/Laptop with an OS installed or Any IoT Embedded Device
  • ·         LabVIEW Utility for displaying sensor data (available on our website for free)
  • Run Mode
(if any)
Header00x7FHeader to differentiate various type of packets
Firmware2–
LSB 4–
Packet Counter5–
MSB 70x02
Reserved80x00
For future use
Sensors Data9/Data[0]–Input 1 – High Input: 1, Low Input: 0
Sensors Data10/Data[1]–Input 2 – High Input: 1, Low Input: 0
Reserved110x00
120x00
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0002 FA
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0002 0000 0004 F5
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0002 1234 5678 E4
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0002 02F5
Command For COPY:  7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0002 7CDE 9C
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0002 03F2
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0002 E6
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0002 E5
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0002 E4
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0002 E3
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0002 E2
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0002 FF
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0002 FE
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0002 0011 2211 2211 2211 2233 4433 4433 4433 4455
B. Appendix
