Explore the IoT Wireless Machine Run Time Hour Meter Capabilities
The IoT Wireless Machine Run Time Hour Meter is a device specifically designed to track machine and production run time in industrial settings. It is a flexible device that observes the behavior of the machine it is attached to via its built-in accelerometer and magnetometer.
It has long range wireless capabilities utilizing robust Mesh networking protocols with high level of security and network reliability. It is compact, durable and powered by long lasting batteries.
- Industrial Grade Machine Runtime Monitoring
- Measure Production Runtime
- Measure Number of Cycles
- Acceleration Motion Detection based Runtime calculator
- Magnetic Field Detection based Runtime calculator
- Humidity Range 0-90%
- Magnet Mounted IP67 Rated Enclosure
- For Indoor and Outdoor Use
| Height | 85mm | |||
| Base diameter | 48mm | |||
| Weight | 225g | |||
| Enclosure Rating | IP67 | |||
| Mounting | ¼-28 UNF thread Magnetic mount | |||
| Temperature Rating | -40° C | 23° C | 70° C | Component Rating |
| Accelerometer Sampling Rate | 25.6 kHz | Vibration Sensor Data Rate | ||
| Accelerometer Full-Scale Range | -16g | +16g | ||
| Accelerometer Noise | 70 μg/ √Hz | |||
| Magnetometer Bandwidth | 1000 Hz | |||
| Magnetometer Full-Scale Range | -4, -8, -16 gauss | +4, +8, +16 gauss | ||
| Magnetometer Noise | 6,842 LSB/gauss | |||
| Magnetometer Temperature Compensation | Enabled | Ensures reliable readings across varied conditions. | ||
| Sample Duration | 1sec | 1sec | 10sec | Device will take readings for the set time and then send over wireless. Max numbers 8100. |
RF Module Specifications
- This device is Powered by a single D-cell (LR20) battery
While changing the batteries:
- Turn off the sensor
- Only use a new D-cell battery (obtain one from NCD, as it has a built in supercapacitor, this is not a regular battery).
- Make sure to align the connector in the proper orientation (this will assure you match the polarity)
- The battery should not be replaced in fire-risky areas
- Do NOT install a rechargeable battery
Head to the NCD store if you want to purchase the IoT Wireless Machine Run Time Hour Meter.
