- Industrial Grade Wireless Frequency Meter
- 24-bit Frequency pre-processed output in milli Hz
- Frequency Range 2 Hz to 10k Hz
- Internal processor Frequency Resolution
- 2 to 12 Hz : 0.0004 Hz/count
- 12 to 100 Hz : 0.002 Hz/count
- 100 to 10000 Hz : 0.25 Hz/count
- Max Frequency Error ±1 %
- 16-bit Duty Cycle pre-processed output rounded to 2 decimal places
- Duty Cycle Range 5% to 95%
- Internal processor Duty Cycle Resolution
- 2 to 100 Hz : 0.02 %
- 100 to 10000 Hz : 0.25 %
- Max Duty Cycle Error ±0.25 %
- Auto Time Delay based transmission
- Frequency and duty cycle change detection transmission
- Configurable frequency and duty cycle change detection bounds
- Wireless Mesh Networking utilizing DigiMesh®
- 256 Sensor Node per Network
- Improved reliability incorporating Retry in case of packet loss
- Encrypted mode for secure and reliable communication
- Real time battery status
- Configuration mode Wireless Settings
- Factory Default Reset Option
- Description
- Getting Started
- Modes of Operation
Introducing NCD’s IoT Wireless Frequency Meter, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. It samples frequency and duty cycle and internally adjusts its time base to maximize output resolution and minimize error. However, the above complexities are abstracted from the user and the output comes out pre-processed. This process is repeated at user defined intervals while sleeping in between to minimize power consumption.
It has an additional feature of detecting change in frequency and duty cycle at user defined detection time intervals and sending out data if the change is greater than user defined detection change percentage. This change detection feature can be enabled/disabled by the user and works for both frequency and duty cycle against a single change percentage and detection time configuration. To minimize power consumption, the sensor sleeps during the time it is not detecting a change. Both of these features work in parallel to support multiple application areas in one package.
The range, price, accuracy, battery life and security features of the IoT Wireless Frequency Meter makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
- Industrial Monitoring
- Wireless Frequency Metering
- PWM Pulse width measurement
- Home Automation
- Wireless Frequency meter (with power source Battery Or External DC)
- Run Mode
- Configuration Mode
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| Packet Counter | 5 | – |
| MSB 7 | 0x12 | ||||
| Reserved | 8 | 0x00 |
| Frequency Data | 9/F[0] | – | Frequency (unsigned)-Hz Frequency (Hz) = ((F[0]<<16)+(F[1]<<8)+F[2])/1000 Use float variable to save frequency in milli Hz | ||
| 10/F[1] | – | ||||
| 11/F[2] | – | ||||
| Duty Cycle Data | 12/D[0] | – | Duty Cycle (unsigned) – % Duty Cycle (%) = ((D[0]<<8)+D[1])/100 Use float variable to save duty cycle in 2 decimal point resolution | ||
| 13/D[1] | – |
Figure 13: Run mode packet being received in a terminal along with power up packet along with run mode power up packet (Hex mode)
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0012 EA
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0012 0000 0004 E5
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0012 1234 5678 D4
Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0012 02E5
Command For COPY:
7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 000D 7CDE 91
Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0012 0BDA
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0012 D6
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0012 D5
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0012 D4
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0012 D3
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0012 D2
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0012 EF
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0012 EE
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0012 0011 2211 2211 2211 2233 4433 4433 4433 4445
Command For COPY:
7E00 1810 0000 0000 0000 00FF FFFF FE00 00F7 0700 0012 0014 0000 0AC6
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1A00 0012 D1
B. Appendix
- Keep only the last 8 bits
