- Industrial Grade Sensor with 3-axis Accelerometer for Asset Monitoring
- Configurable Asset Monitoring Parameters
- Uses Interrupts to keep track of Assets with little power consumption
- Configurable Acceleration Range ±2g to ±16g
- Configurable Interrupt Threshold ±16mg to ±15.3g
- Configurable Data Rate 1Hz to 5.37KHz
- Configurable Interrupt Duration 200us to 1sec
- Customizable Interrupt Types and Combinations for generating Monitoring condition
- Configurable In-built Interrupt disable time for maximizing battery life time
- Two modes of Operation
- Up to 300,000 Transmissions from 2 AA Batteries
- Real time battery status
- Description
- Getting Started
- Modes of Operation
Introducing NCD’s IoT Wireless Asset Monitor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. It incorporates a STMicro LIS3DH acceleration sensor for measuring acceleration changes. Utilizing the interrupt feature of this sensor, it is able to minimize power consumption by making most of the components go to sleep while waiting for the interrupt from the sensor.
User can configure the Asset Monitoring condition (interrupt settings) using the configuration mode. User can configure acceleration range, data rate, interrupt duration and interrupt threshold. Interrupt duration is dependent upon data rate. It is the duration for which an interrupt condition has to hold to generate a system interrupt and initiate data transmission to a nearby receiver. Interrupt threshold is dependent upon acceleration range and it is the acceleration in g which if exceeded causes interrupt to fire. Note that the absolute value of actual g reading is compared with it therefore it works for both positive and negative acceleration exceeding threshold.
User can also setup interrupt settings. Interrupt settings also user to setup whether an acceleration above or below threshold will fire interrupt. This can be configured separately for all the axis. Moreover, the user can setup OR/AND gates between the interrupts. This allows monitoring (system interrupt) if any single axis interrupt fires (OR condition) or if all axis interrupts fire (AND condition). User can also configure a delay time in seconds which disables the interrupt for that amount of time after a successful interrupt. This enables a user to make sure that the sensor does not drain its battery(with continuous transmissions) if an interrupt condition persists or a wrong condition is accidently programmed.
Powered by just 2 AA batteries and an operational lifetime of 300,000 wireless transmissions, a 4 years battery life can be expected depending on environmental conditions and the data transmission interval. Optionally, this sensor may be externally powered.
The range, price, accuracy, battery life and security features of Wireless Asset Monitor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
- Wireless Asset Monitoring
- Security Systems
- Home Automation
- IoT Long Range Wireless Asset Monitor Sensor (with power source Battery Or External DC)
- Run Mode
- Configuration Mode
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| Packet Counter | 5 | – |
| MSB 7 | 0x02 | ||||
| Reserved | 8 | 0x00 |
| Acceleration Data | 9/X[0] | – | Accelerometer X-axis Data (16 bit Signed Output) Acceleration (mg) = X[0]<<8) + X[1] | ||
| 10/X[1] | – | ||||
| 11/Y[0] | – | Accelerometer Y-axis Data (16 bit Signed Output) Acceleration (mg) = Y[0]<<8) + Y[1] | |||
| 12/Y[1] | – | ||||
| 13/Z[0] | – | Accelerometer Z-axis Data (16 bit Signed Output) Acceleration (mg) = Z[0]<<8) + Z[1] | |||
| 14/Z[1] | – | ||||
| Temperature Data | 15/T[0] | – | Temperature data (16 bit Signed Output) Temperature (°C) = (T[0]<<8) + T[1] Note: The temperature output gives the change in temperature between two readings and does not provide temperature of the sensor or environment. | ||
| 16/T[1] | – |
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0019 E3
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0019 0000 0004 DE
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0019 1234 5678 CD
Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0019 02DE
Command For COPY:
7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0019 7CDE 85
Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0019 03DB
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0019 CF
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0019 CE
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0019 CD
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0019 CC
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0019 CB
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0019 E8
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0019 E7
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0019 0011 2211 2211 2211 2233 4433 4433 4433 443E
15. Set Acceleration Range
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0100 0019 00E6
16. Set Data Rate
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0200 0019 07DE
17. Set Threshold
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0300 0019 01E3
18. Set Duration
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0400 0019 01E2
19. Set Interrupt Settings
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0900 0019 07D7
20. Read Acceleration Range
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0500 0019 E2
21. Read Data Rate
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0600 0019 E1
22. Read Threshold
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0700 0019 E0
23. Read Duration
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0800 0019 DF
24. Read Interrupt Settings
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0A00 0019 DD
B. Appendix
- Keep only the last 8 bits
