- Industrial Grade 2 Channel Analog to Digital Converter
- 10 bit Resolution
- ±2 LSB Absolute Accuracy
- Auto ADC sample transmission or on analog voltage change detection periodically (configurable duration in both cases)
- Configurable Analog voltage change detection percentage
- 256 Sensor Node per Network
- Two modes of Operation
- Power efficient Built-in Sleep mode- User Configurable Sleep duration
- Real time battery status
- Description
- Getting Started
- Modes of Operation
Introducing NCD’s IoT Wireless Analog to Digital Converter (ADC), boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. It incorporates a 2 channel 10 bit ADC that samples analog inputs at user defined intervals while sleeping during the time it is not sending data to minimize power consumption. It has an additional feature of detecting change in voltage at user defined detection time intervals and sending out ADC samples if the change in voltage on any channel is greater than user defined detection change percentage. This change detection feature can be enabled or disabled by user. To minimize power consumption, it sleeps during the time it is not checking for change in analog voltage. Both of these features work in parallel to support multiple application areas in one package.
The range, price, accuracy, battery life and security features of IoT Wireless Analog to Digital Converter makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
Note: This manual is shared with IoT Long Range Wireless DC Voltage Monitor(0-10V),IoT Long Range Wireless 0-24VDC Voltage Monitor, and IoT Long Range Wireless 4-20mA Current Receiver as well.
- Analog Voltage monitoring
- Analog voltage change Alarm
- Home Automation
- ADC type NCD IoT Wireless Sensor (with power source Battery Or External DC)
- Run Mode
- Configuration Mode
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| Packet Counter | 5 | – |
| MSB 7 | 0x03 | ||||
| Reserved | 8 | 0x00 |
| Sensor Data | 9/ Data[0] | – | ADC 1 Counts ADC Counts = (Data[0] x 256) + Data[1] | ||
| 10/ Data[1] | – | ||||
| 11/ Data[2] | – | ADC 2 Counts ADC Counts = (Data[2] x 256) + Data[3] | |||
| 12/ Data[3] | – |
Dual Probe Soil Moisture Sensor
Dual Soil Moisture Data Format
| Header | 0 | 7F | Header to differentiate various type of packets |
| Node ID | 1 | 0x00 Factory Default | Node ID to differentiate up to 256 nodes in a network. User configurable values |
| Firmware | 2 | – | Used to determine firmware version programmed in the device |
| Battery Voltage | MSB 3, LSB 4 | – | Sampled battery voltage of the device. Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V Use this equation to calculate battery %. Battery % = 0.537*ADC – 449.9 |
| Packet Counter | 5 | – | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets. |
| Sensor Type | MSB 6, LSB 7 | 0x44 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
| Reserved | 8 | – | For future use |
| Sensor Data/ Soil Probe 1 Raw | 9/Data[0], 10/Data[1] | – | ADC 1 Counts Soil Probe 1 ADC Counts = (Data[0] x 256) + Data[1] |
| Sensor Data/ Soil Probe 2 Raw | 11/Data[2], 12/Data[3] | – | ADC 2 Counts Soil Probe 2 ADC Counts = (Data[2] x 256) + Data[3] |
| Sensor Data/ Soil Probe 1 VWC | 13/Data[4], 14/Data[5] | – | VWC1= ((Data[4] x 256) + Data[5])/100.00 |
| Sensor Data/ Soil Probe 2 VWC | 15/Data[6], 16/Data[7] | – | VWC2= ((Data[6] x 256) + Data[7])/100.00 |
Soil Moisture Temperature and EC Sensor
Soil Moisture Temperature and EC sensor Data Format
| Byte | Function | Value | Description | |
| 1 | Header | 0 | 7F | Header to differentiate various type of packets |
| 2 | Node ID | 1 | 0x00 Factory Default | Node ID to differentiate up to 256 nodes in a network. User configurable values |
| 3 | Firmware | 2 | – | Used to determine firmware version programmed in the device |
| 4 | Battery Voltage MSB | |||
| 5 | Battery Voltage LSB | MSB 3, LSB 4 | – | Sampled battery voltage of the device. Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V Use this equation to calculate battery %. Battery % = 0.537*ADC – 449.9 |
| 6 | Packet Counter | 5 | – | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets. |
| 7 | ||||
| 8 | Sensor Type | MSB 6, LSB 7 | 0x45 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
| 9 | Reserved | 8 | – | For future use |
| 14 | Sensor Data/ Soil Moisture | 9/Data[0], 10/Data[1],11/Data[2], 12/Data[3] | – | Soil Moisture % Soil Moisture = ( Data[0]<<24+Data[1]<<16+Data[2]<<8+ Data[3])/100.00 |
| 15 | Sensor Data/ Soil Temperature | 13/Data[4], 14/Data[5],15/Data[6], 16/Data[7] | – | Soil Temperature in C Soil Temp = ( Data[4]<<24+Data[5]<<16+Data[6]<<8+ Data[7])/100.00 |
| 16 | Sensor Data/ Soil EC | 17/Data[8], 18/Data[9],19/Data[10], 20/Data[11] | – | Soil  Electrical Conductivity Soil EC = ( Data[8]<<24+Data[9]<<16+Data[10]<<8+ Data[11])/100.00 |
| 17 | Sensor Data/ Soil Salinity | 21/Data[12], 22/Data[13],23/Data[14], 24/Data[15] | – | Soil  Salinity Soil SAL = ( Data[12]<<24+Data[13]<<16+Data[14]<<8+ Data[15])/100.00 |
3 Channel Soil Moisture Temperature and EC Sensor
| 7 | ||||
| 8 | Sensor Type | MSB 6, LSB 7 | 0x47 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
| 18 | Sensor Data/ Soil Moisture 2 | 25/Data[0], 26/Data[1],27/Data[2], 28/Data[3] | – | Soil Moisture % Soil Moisture = ( Data[0]<<24+Data[1]<<16+Data[2]<<8+ Data[3])/100.00 |
| 19 | Sensor Data/ Soil Temperature | 29/Data[4], 30/Data[5],31/Data[6], 32/Data[7] | – | Soil Temperature in C Soil Temp = ( Data[4]<<24+Data[5]<<16+Data[6]<<8+ Data[7])/100.00 |
| 20 | Sensor Data/ Soil EC | 31/Data[8], 32/Data[9],33/Data[10], 34/Data[11] | – | Soil  Electrical Conductivity Soil EC = ( Data[8]<<24+Data[9]<<16+Data[10]<<8+ Data[11])/100.00 |
| 21 | Sensor Data/ Soil Salinity | 35/Data[12], 36/Data[13],37/Data[14], 38/Data[15] | – | Soil  Salinity Soil SAL = ( Data[12]<<24+Data[13]<<16+Data[14]<<8+ Data[15])/100.00 |
| 22 | Sensor Data/ Soil Moisture 3 | 39/Data[0], 40/Data[1],41/Data[2], 42/Data[3] | – | Soil Moisture % Soil Moisture = ( Data[0]<<24+Data[1]<<16+Data[2]<<8+ Data[3])/100.00 |
| 23 | Sensor Data/ Soil Temperature | 43/Data[4], 44/Data[5],45/Data[6], 46/Data[7] | – | Soil Temperature in C Soil Temp = ( Data[4]<<24+Data[5]<<16+Data[6]<<8+ Data[7])/100.00 |
| 24 | Sensor Data/ Soil EC | 47/Data[8], 48/Data[9],49/Data[10], 50/Data[11] | – | Soil  Electrical Conductivity Soil EC = ( Data[8]<<24+Data[9]<<16+Data[10]<<8+ Data[11])/100.00 |
| 25 | Sensor Data/ Soil Salinity | 51/Data[12], 52/Data[13],53/Data[14], 54/Data[15] | – | Soil  Salinity Soil SAL = ( Data[12]<<24+Data[13]<<16+Data[14]<<8+ Data[15])/100.00 |
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0003 F9
															Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0003 0000 0004 F4
															Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0003 1234 5678 E3
															Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0003 02F4
															Command For COPY: 7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0003 7CDE 9B
															Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0003 03F1
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0003 E5
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0003 E4
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0003 E3
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0003 E2
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0003 E1
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0003 FE
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0003 FD
															Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0003 0011 2211 2211 2211 2233 4433 4433 4433 4454
															Command For COPY: 7E00 1810 0000 0000 0000 00FF FFFF FE00 00F7 0700 0003 0014 0000 0AD5
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1A00 0003 E0
B. Appendix
- Keep only the last 8 bits
