- Industrial Grade Sensor with 3-axis Accelerometer for Activity Detection
- Configurable Activity Detection Parameters
- Uses Interrupts for Activity detection with little power consumption
- Configurable Acceleration Range ±2g to ±16g
- Configurable Interrupt Threshold ±16mg to ±15.3g
- Configurable Data Rate 1Hz to 5.37KHz
- Configurable Interrupt Duration 200us to 1sec
- Customizable Interrupt Types and Combinations for generating Activity condition
- Configurable In-built Interrupt disable time for maximizing battery life time (sends a packet after this interval to show activity detection enabled)
- 256 Sensor Node per Network
- Two modes of Operation
- Up to 300,000 Transmissions from 2 AA Batteries
- Real time battery status
- Description
- Getting Started
- Modes of Operation
Introducing NCD’s IoT Wireless Activity Detection Sensor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. It incorporates a STMicro LIS3DH acceleration sensor for measuring acceleration changes. Utilizing the interrupt feature of this sensor, it is able to minimize power consumption by making most of the components go to sleep while waiting for the interrupt from the sensor.
User can configure the Activity Detection condition (interrupt settings) using the configuration mode. User can configure acceleration range, data rate, interrupt duration and interrupt threshold. Interrupt duration is dependent upon data rate. It is the duration for which an interrupt condition has to hold to generate a system interrupt and initiate data transmission to a nearby receiver. Interrupt threshold is dependent upon acceleration range and it is the acceleration in g which if exceeded causes interrupt to fire. Note that the absolute value of actual g reading is compared with it therefore it works for both positive and negative acceleration exceeding threshold.
User can also setup interrupt settings. Interrupt settings also user to setup whether an acceleration above or below threshold will fire interrupt. This can be configured separately for all the axis. Moreover, the user can setup OR/AND gates between the interrupts. This allows activity detection (system interrupt) if any single axis interrupt fires (OR condition) or if all axis interrupts fire (AND condition). User can also configure a delay time in seconds which disables the interrupt for that amount of time after a successful interrupt. This enables a user to make sure that the sensor does not drain its battery (with continuous transmissions) if an interrupt condition persists or a wrong condition is accidently programmed. This time is also used to send a periodic packet to a receiver with latest available data.
The long range, price, accuracy, battery life and security features of Wireless Activity Detection Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
- Wireless Activity Detection
- Security Systems
- Home Automation
- IoT Long Range Wireless Activity Detection Sensor (with power source Battery Or External DC)
- Run Mode
- Configuration Mode
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| Battery Voltage | MSB 3 | – |
| LSB 4 | – | ||||
| Packet Counter | 5 | – |
| MSB 7 | 0x18 | ||||
| Reserved | 8 | 0x00 |
| Acceleration Data | 9/X[0] | – | Accelerometer X-axis Data (16 bit Signed Output) Acceleration (mg) = X[0]<<8)+X[1] | ||
| 10/X[1] | – | ||||
| 11/Y[0] | – | Accelerometer Y-axis Data (16 bit Signed Output) Acceleration (mg) = Y[0]<<8)+Y[1] | |||
| 12/Y[1] | – | ||||
| 13/Z[0] | – | Accelerometer Z-axis Data (16 bit Signed Output) Acceleration (mg) = Z[0]<<8)+Z[1] | |||
| 14/Z[1] | – | ||||
| Temperature Data | 15/T[0] | – | Temperature data (16 bit Signed Output) Temperature (°C) = (T[0]<<8)+T[1] Note: The temperature output gives the change in temperature between two readings and does not provide temperature of the sensor or environment. | ||
| 16/T[1] | – |
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0018 E4
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0018 0000 0004 DF
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0018 1234 5678 CE
Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0018 02DF
Command For COPY:
7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0018 7CDE 86
Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0018 03DC
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0018 D0
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0018 CF
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0018 CE
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0018 CD
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0018 CC
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0018 E9
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0018 E8
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0018 0011 2211 2211 2211 2233 4433 4433 4433 443F
15. Set Acceleration Range
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0100 0018 00E7
16. Set Data Rate
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0200 0018 07DF
17. Set Threshold
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0300 0018 01E4
18. Set Duration
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0900 0018 07D8
19. Set Interrupt Settings
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0900 0019 07D7
20. Read Acceleration Range
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0500 0018 E3
21. Read Data Rate
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0600 0018 E2
22. Read Threshold
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0700 0018 E1
23. Read Duration
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0800 0018 E0
24. Read Interrupt Settings
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0A00 0018 DE
B. Appendix
- Keep only the last 8 bits
