- Industrial Long Range Wireless AC Current Detection Sensor
- One 0-100A AC Current Sensor
- Interface to Raspberry Pi, Microsoft® Azure®, AWS and More
- Small 3″ x 3″ Form Factor Wireless AC Current Detection Push Notification
- Description
- Getting Started
- Modes of Operation
Introducing NCD’s IoT Wireless AC Current Detection Push Notification Sensor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. It transmits highly accurate frames with low latency for every push input or at user-defined intervals.
The range, price, accuracy, battery life and security features of Wireless AC Current Detection Push Notification Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
AC Current Detection Sensor Type — 33
- AC Current Detection Push Notification
- Wireless AC Current change detection
- Automation Application
- Home Automation
- AC Current Detection Push Notification Sensor (with power source Battery Or External DC)
- Install the Alpha Station utility for the sensor you are working with. Run this utility.
- Run Mode
- Configuration Mode
The detail for API packet received at PC end can be read from the S3B manual available from Digi. The detail of Payload section of packet is shown in Table 3.
| Frame Field | Offset (Payload Section) | Fixed Value (if any) | Description | |
| Header | 0 | 0x7F | Header to differentiate various type of packets | |
| Firmware | 2 | – |
| Battery Voltage | MSB 3 | – | Sampled battery voltage of the device. Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V | |
| LSB 4 | – | |||
| Packet Counter | 5 | – |
| MSB 7 | 0x21 | |||
| Reserved | 8 | 0x00 |
| Sensors Data | 9/Data[0] | – | Input 1 – Current High: 1, Current Low: 0 | |
| Reserved | 10 | -0x00 | Reserve | |
| 11 | 0x00 | |||
| 12 | 0x00 |
How to Set Current Threshold/Limits --
The current threshold can be set by changing the potentiometer value. Use the “SET” test points to measure potentiometer value.
| Resistance Between SET Points | Trigger Current |
| 3.12K or above | 1A |
| 1.4K or above | 2A |
| 700Ohm or above | 3A |
For example if the Resistance between “SET” point it 3.12K. The sensor will send a push notification message as soon as the current value exceeds 1A. If will send next messages when the current drops 1A.
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0002 FA
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0002 0000 0004 F5
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0002 1234 5678 E4
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0002 02F5
Command For COPY: 7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0002 7CDE 9C
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0002 03F2
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0002 E6
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0002 E5
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0002 E4
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0002 E3
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0002 E2
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0002 FF
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0002 FE
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0002 0011 2211 2211 2211 2233 4433 4433 4433 4455
B. Appendix
- Keep only the last 8 bits
