Water leaks in a residential property can wreak havoc on you, family and roommates. NCD’s Iot Water Detect Sensor can quickly notify you if your home or homes have a water leak of any kind. A water leak can happen from any pipe or water system in your home; hot water heaters, general plumbing pipes, toilet facilities, and faucets.
As they say, the greatest force on earth is water.
Water leaks in a residential property can wreak havoc on you, family and roommates. NCD’s IoT Water Detect Sensor can quickly notify you if your home or homes have a water leak of any kind. A water leak can happen from any pipe or water system in your home; hot water heaters, general plumbing pipes, toilet facilities, and faucets.
A water leak in your home can lead to catastrophic outcomes. If there is a leak in your home, it can affect floors, walls, framing, furniture, electronics and electrical components of your home, which could potentially lead to a fire hazard. A time frame of as little as 24 hours could lead to serious damage. Beyond structural damage, water can also destroy personal property and possessions such as photos, paint (or paintings) on walls, bookshelves, and much more.
If water leaks persist, or cause pooling in your home, the effects could be extremely costly, and dangerous. Water damage can cause corrosion to metal in the home, cause warping on ceiling beams, and begin to develop rot and mold, which is an obvious health hazard. Not all home insurance covers water and/or mold damage, and water damage restoration can be costly – which could all lead to unexpected out-of-pocket expenses. NCD can help provide you and your home with a quality preventative maintenance device in the IoT Water Detect Sensor.
