Water leaks in a server room or any type of data center can lead to detrimental outcomes in a very short matter of time. Water in a facility such as this is one of the greatest hazards that could be introduced due to the risk of flood, fire, and loss of infrastructure. NCD’s IoT Water Detect Sensor can help prevent serious damage from happening to your server room or data center by quickly monitoring, identifying and notifying you of the presence of water, as well as dry conditions so you can always be in the know.
NCD’s IoT Water Detect Sensor can help prevent serious damage from happening to your server room or data center with condition based monitoring, identifying and notifying you of the presence of water, as well as dry conditions so you can always be in the know.Â
Many contributing factors come into play when considering water damage to your server room or IT facility.Â
With NCD’s IoT Water Detect Sensor, you can be notified immediately of any dangerous situations when it comes to water leaks within your data center or server room. Subsequently, you can also keep up to date and have peace of mind with dry condition monitoring using the IoT Water Detect Sensor knowing your equipment is safe from water damage at any given time.
