- Industrial Grade Ultrasonic Tank Level Sensor
- Reading-to-reading stability of 1-mm at 1-meter is typical
- Sensor features 1-mm resolution
- Target size compensation provides greater consistency and accuracy
- Detection Range upto 5 meter ( 10 meter also available on request)
- Internal Temperature compensation
- Free run operation with superior noise rejection
- Excellent clutter rejection
- Send IoT Data to PCs, Amazon AWS, Microsft Azure, and MQTT Servers
- A range value of 5000 or 9999 corresponds to no target being detected in the field of view.
- Wireless Tank Level Measurement
- Bin Level Measurement
- Long Range Object Detection
- Proximity Zone Detection
- Component of a Low Power IoT System
- Industrial Automation
- Wireless TankLevel Monitoring for AWS® and Azure®
Introducing NCD’s Long Range Industrial IoT Wireless Ultrasonic Tank Level Sensor, boasting up to a 2 Mile range using a wireless mesh networking architecture. Incorporating the Ultrasonic proximity detection sensor sensors, this wireless IoT Ultrasonic Tank Level Sensor transmits highly accurate tank level or distance values at user-defined intervals. The Ultrasonic sensor features 1mm resolution.
With an open communication protocol, this IoT wireless Ultrasonic Tank Level Sensor for distance, Level measurement can be integrated with just about any control system or gateway. Data can be transmitted to a PC, a Raspberry Pi, to Microsoft Azure® IoT, Amazon AWS, Losant, and MQTT servers or to local Arduino processors for special handling. Sensor parameters and wireless transmission settings can be changed using an open communication protocol providing maximum configurability depending on the intended application.
Applications requiring 100% reading-to-reading reliability should not use Ultrasonic Tank Level Sensor at a distance closer than 50cm. Although most users find Ultrasonic Tank Level Sensor to work reliably from 0 to 50cm for detecting objects in many applications, although its not guaranteed operational reliability for objects closer than the minimum reported distance. Because of ultrasonic physics, these sensors are unable to achieve 100% reliability at close distances.
The long range, price, accuracy, battery life and security features of Long Range Wireless Ultrasonic Tank Level Sensor for Air Quality Monitoring makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
The Ultrasonic Tank Level sensor line provides high accuracy and high resolution ultrasonic proximity detection and ranging in air. This sensor line features 1-mm resolution, target-size and operating-voltage compensation for improved accuracy, superior rejection of outside noise sources, internal speed-of-sound temperature compensation and optional external speed-of-sound temperature compensation. The Ultrasonic Tank Level sensor models are available
in 1.5-meter, 5-meter, or 10-meter models. This ultrasonic sensor detects objects from 1-mm and ranges to objects from 30-cm* to maximum range. Objects closer than 30-cm* are typically reported as 30-cm*.
- Tank Level Sensor Ultrasonic Long Range Wireless(with power source Battery Or External DC)
- Alpha Station PC utility
Modes of Operation
- Run Mode
- Configuration Mode
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| Packet Counter | 5 | – |
| MSB 7 | 0x22 | ||||
| Reserved | 8 | error code |
Sensor Data | MSB 9/ Data[0] | – | Tank Level in mm Level(usigned) = ((Data[0]<<8)+(Data[1])) | ||
| 10/ Data[1] | – | ||||
| 11/ Data[2] | not used | ||||
| 12/ Data[3] | not used |
Appendix A
Configuration Commands
15. Set Sensor Change Detection Parameter
Command For Copy — 7E 00 18 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 07 00 00 00 01 0A 00 00 0A CB
Sensor Payload — F7 07 00 00 00 01 0A 00 00 0A
F7 — Header
0x07 — Set change detection Sub command
0x00,0x00,0x00 — Reserved
0x01 – Enable/Disable Change Detection ( in this command we are enabling the change detection)
0x0A — Percentage change detection at which sensor will send the data packet. Sensor sends data when two consecutive readings differ by set percent.
0x00(MSB) — The is the detection time after which sensor periodically checks the sensor value
0x00 — The is the detection time after which sensor periodically checks the sensor value
0x0A(LSB) — The is the detection time after which sensor periodically checks the sensor value
In above command we enabled the percentage detection and the percent value was set to 10% and the time after which sensor will check sensor values for percent change is 10 seconds.
16. Read Sensor Change Detection Parameter
Command For COPY: 7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 1A 00 00 22 C1
Above command can be used to read following info
A. If the % change detection is enable or disable
B. Whats the % change percent value
C. Whats the percent change detection delay after which sensor checks for percent change
The sensor will respond with this
7E 00 1C 90 00 13 A2 00 41 A2 70 EA FF FE C1 7C 00 09 00 22 00 00 01 0A 00 00 08 00 00 00 00 05
Sensor Payload —
7C — Header
00 — Node ID
0x09 — Packet Counter
0x00,0x22– Sensor type ( this sensor type is 34)
0x00, 0x00 — Reserve
0x01 — Change Detection Enable/ Disable state
0x0A — Percent change detection value
0x00,0x00,0x08 — Percent Detection Time
Appendix B
- Keep only the last 8 bits
