NCD IoT Wireless AC Current Detection sensor transmitters makes it easy to receive alerts when the AC current value exceeds the preset limits. This current limit can be set up via an on-board Potentiometer. This IoT long range wireless AC Current Detection sensor transmitter includes one 0-100Amp AC current clamp, that is used to detect if there is any current flowing through the sensor. The input current range is 0-100A, sending a transmission if the measured value is over the set threshold. The sensor also sends packets periodically, indicating the input status as well as the battery level, just to let you know it’s alive and well.
Receive an alert when AC current value exceeds the preset value, receive another alert when the AC current drops below preset value. This IoT long range wireless AC Current Detection sensor is ideally used in Automation applications that need a reliable long-range wireless AC current detect transmission. Powered by two AA batteries, it has up to 10 years of battery life depending on environmental conditions and the transmission interval required for your application. Optionally, this sensor may be externally powered.
This AC Current Detection sensor transmitter will send wireless push notifications over a distance of up to 2 miles using the included antennas (line of sight) or up to 28 miles using high-gain antennas.
Feature
- Industrial Long Range Wireless AC Current Detection Sensor
- Selectable Current Sensor:
- 100 amp CT
- 200 amp CT
- 600 amp CT
- 1000 amp CT
- Easy configuration and management via an open Node-RED library
- Power-Efficient Sleep Mode, Up to 10 Year Battery Life – User Configurable Sleep duration
| Width | 3.54" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
| Current probe specs [Max current range / Resolution / Minimum detectable current | 100A / 50mA / 2A | |||
| 200A / 100mA / 4A | ||||
| 600A / 300mA / 12A | ||||
| 1000A / 500mA / 20A |
RF Module Specifications
Can also be powered by an External Power supply.
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
| Battery Life 1 TPD (TPD Transmissions per Day) | 10 Years | Battery estimation is based on a 30 min interval | ||
| Battery Life 12 TPD (TPD Transmissions per Day) | 8 Years | Battery estimation is based on a 30 min interval | ||
| Battery Life 24 TPD (TPD Transmissions per Day) | 5 Year | Battery estimation is based on a 30 min interval | ||
| Battery Life 96 TPD (TPD Transmissions per Day) | 3 Year | Battery estimation is based on a 30 min interval |
IoT Long Range Wireless AC Current Detection Sensor.
