- Device Overview
- Frame Structure
- Read Sleep Duration
- Read Sensor Network ID
- Appendix
NCD IoT Wireless AC Current Detection sensor transmitters makes it easy to receive alerts when the AC current value exceeds the preset limits. This current limit can be set up via an on-board Potentiometer. This IoT long range wireless AC Current Detection sensor transmitter includes one 0-100Amp AC current clamp, that is used to detect if there is any current flowing through the sensor. The input current range is 0-100A, sending a transmission if the measured value is over the set threshold. The sensor also sends packets periodically, indicating the input status as well as the battery level, just to let you know it’s alive and well.
Receive an alert when AC current value exceeds the preset value, receive another alert when the AC current drops below preset value. This IoT long range wireless AC Current Detection sensor is ideally used in Automation applications that need a reliable long-range wireless AC current detect transmission. Powered by two AA batteries, it has up to 10 years of battery life depending on environmental conditions and the transmission interval required for your application. Optionally, this sensor may be externally powered.
This AC Current Detection sensor transmitter will send wireless push notifications over a distance of up to 2 miles using the included antennas (line of sight) or up to 28 miles using high-gain antennas.
Feature
- Industrial Long Range Wireless AC Current Detection Sensor
- Selectable Current Sensor:
- 100 amp CT
- 200 amp CT
- 600 amp CT
- 1000 amp CT
- Easy configuration and management via an open Node-RED library
- Power-Efficient Sleep Mode, Up to 10 Year Battery Life – User Configurable Sleep duration
Frame Structure
| 8 | 0x55 | |||
| 9 | 0x4E | |||
| 8 | 0x47 | |||
| 9 | 0x4D | |||
| 8 | 0x55 | |||
| 9 | 0x4D |
Run Mode Power Up Frame
| 0x7E | 1 | Delimiter |
| 0x001C | 2 | Length |
| 0xFFFE | 2 | Reserved |
| 0x00 | 1 | R. Option |
| 0x01 | 1 | Node ID |
| 0x00 | 1 | Separator |
| 0x0001 | 2 | Sensor Type |
| 0x0000 | 2 | Separator |
| 0x0B | 1 | Checksum |
| 0x0E | 1 | Checksum |
| 7E 00 1C 90 00 13 A1 00 41 58 1C CB FF FE 00 7A 01 00 00 01 00 00 50 55 4D 00 00 00 00 00 00 0E | Example frame | |
| 0x50554D | 3 | Mode Byte for Factory Default Mode |
Sensor Data Frame
Data Payload
| Field | Offset (Payload Section) | Value ( or Default ) | Length | Description |
| Header | 0 | 0F | 1 | Header to differentiate various type of packets |
| Node ID | 1 | 00 | 1 | User Defined ID |
| Firmware Version | 2 | 01 | 1 | Device Firmware Version |
| Battery Level | MSB 3, LSB 4 | - | 2 | Sampled battery voltage of the device. Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V |
| Packet Counter | 5 | - | 1 | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets. |
| Sensor Type | MSB 6, MSB 7 | 00, 0x21 | 2 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
| Error/Reserve Byte | 8 | 00 | 1 | error code = 1 ( data was not ready) |
| Sensor Data | 9/Data[0] | - | 1 | Current Detect – Current High: 1, Current Low: 0 |
| Total Uptime | 10/Data[1], 11/Data[2], 12/Data[3], 13/Data[4] | - | 4 | Total Uptime: Amount of time the Current Transducer detected activity since last reset in seconds. Uptime: D10 << 24 | D11 << 16 | << D12 << 8 | D13 |
| Total Cycle Counter | 14/Data[5], 5/Data[6], 16/Data[7], 17/Data[8] | - | 4 | Total Cycle Counter: number of times the Current Transducer detected activity since last reset of the device. Counter: D14 << 24 | D15 << 16 | << D16 << 8 | D17 |
Configuration Mode Frame
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2CÂ Â
A. Node ID
0x01 (Byte 23)
B. New Delay Value
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78Â
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor PayloadÂ
C. Power Level
0x04 (data byte 23)
B. Complete Sensor PayloadÂ
C. Retries Number
0x0A (data byte 23)
Complete Payload
F7 06 00 00 00 05Â
Complete Payload
Appendix
Configuration Commands
Application Specific Commands
| No. | Command | Sub Command | Parameter Field | Default Value | Description |
| Clear Counter | F4 | 24 | Clear | 0x00 | Clears the event counter. |
| Set Input Debounce Time | F4 | 27 | Debouce Time | Sets the debounce time in milliseconds on inputs. | |
| Read Input Debounce Time | F4 | 28 | - | Read the debounce time in milliseconds on inputs. | |
| Set Contact Closure Detection | 29 | Contact Closure Detection | Select whether the trigger is from low to high state (Rising Edge Trigger), or high to low state (Falling Edge Trigger). | ||
| Enable Push Notification | F4 | 2B | Push Notification | Set a Push notification in the event of crossing the Current threshold. | |
| Set Counter Threshold | F4 | 2C | Counter Threshold | Device will send data when any counters reaches multiple of the Threshold. | |
| Read Counter Threshold | F4 | 2D | - | Read the Counter Threshold Value. |
Command Acknowledgement Data
| 14 | Set Encryption Key | 1 | 8 | 0xFF (OK) |
Error Code Descriptions
| 0x01 | Invalid command |
| 0x03 | Node ID mismatch |
Calculation for transmission
0x04
0xFF-0x04=0xFB
Calculation for reception
0xFF
