IoT CO2 Temperature Humidity Sensor for Air Quality Monitoring Product Manual
  • CO2 Measurement Accuracy ± (60 ppm + + 5% of reading)(25 °C, 400 – 2’000 ppm)
  • Repeatability 10 ppm And Temperature stability
  • NDIR measurement principle
  • Temperature compensation of CO2 sensor signal
  • Fully calibrated and linearized
  • Built-in reference channel
  • Superior long-term stability
  • Industrial Grade Sensor with 0 to 90% RH / -25°C [-13°F] to 85°C [185°F])
  • Resolution 0.4% RH/0.1°C Accuracy 6% RH/ 0.8°C
  • Includes Battery Level with Every Transmission
  • Encrypted Wireless Communications up to 2 Mile Range
  • Send IoT Data to PCs, Amazon AWS, Microsft Azure, and MQTT Servers
  • Operating temp range -40’C to 80′
  • In House Temperature Humidity monitoring
  • Hospital Air quality monitoring
  • HVAC application
  • Storage Unit Weather Monitoring System
  • Warehouse Health Monitoring System
  • Home Automation
Introducing NCD’s Long Range Industrial IoT Wireless CO2 Temperature Humidity Sensor for Air Quality Monitoring with an integrated temperature humidity sensor, boasting up to a 2 Mile range using a wireless mesh networking architecture. Incorporating the SCD30 and SHT30 temperature humidity sensors, this wireless IoT sensor transmits highly accurate CO2 Concentration, temperature and humidity samples at user-defined intervals.
CMOSens® Technology for IR detection enables highly accurate carbon dioxide measurement at a competitive price. Along with the NDIR measurement technology for CO2 detection, a best-in-class humidity and temperature sensor is also integrated on the same sensor module. Ambient humidity and temperature can be outputted by Sensors’s algorithm expertise through modeling and compensating of external heat sources without the requirement for any additional components.
Thanks to the dual-channel principle for the measurement of carbon dioxide concentration, the sensor compensates for long-term drifts automatically by design. The very small module height allows easy integration into different applications.
The on-board temperature sensor is rated for -25°C to 85°C or -13°F to 185°F and the humidity sensor is rated for 0 to 100% RH (non condensing).  Powered by just 4 AA batteries and an operational lifetime of 300,000 wireless transmissions, a 10 years battery life can be expected depending on environmental conditions and the data transmission interval.  An external power supply is supported by special request.
With an open communication protocol, this IoT wireless CO2 Temperature Humidity Sensor for Air Quality Monitoring can be integrated with just about any control system or gateway.  Data can be transmitted to a PC, a Raspberry Pi, to Microsoft Azure® IoT, Amazon AWS, Losant, and MQTT servers or to local Arduino processors for special handling. Sensor parameters and wireless transmission settings can be changed using an open communication protocol providing maximum configurability depending on the intended application.
  1. Power-up the Wireless Sensor and make sure its antenna is installed
Modes of Operation
  • Run Mode
  • Configuration Mode
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2–
Battery VoltageMSB 3–
LSB 4–
Packet Counter5–
Sensor TypeMSB 60x00
MSB 70x2C
Reserved8error code
error code = 1 ( data was not ready)
CO2 Concentration in ppm
MSB 9/ Data[0]–
    CO2(usigned) = (((Data[0]<<24)+(Data[1]<<16)+(Data[2]<<8)+Data[3])/100.0)
10/ Data[1]–
11/ Data[2]–
LSB 12/ Data[3]–
Sensor DataMSB 13/ Data[4]–
Humidity data
    Humidity(usigned) = ((data[0] x 256) + data[1])/100
14/ Data[5]–
15/ Data[6]–
Temperature data
    Temperature(signed) = (((data[2] x 256) + data[3])/100)°C
LSB 16/ Data[7]–
Appendix A
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0001 FB
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0001 1234 5678 E5
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0001 02F6
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0001 03F3
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0001 E4
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0001 E3
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0001 00
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0001 FF
14. Set Sensor Temperature Offset Coefficient
Command For COPY: 7E 00 15 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 1E 00 00 35 00 04 A
Above command is setting the temp Offset value to 4
The on-board RH/T sensor is influenced by thermal self-heating of SCD30 and other electrical components. Design-in alters the
thermal properties of SCD30 such that temperature and humidity offsets may occur when operating the sensor in end-customer
devices. Compensation of those effects is achievable by writing the temperature offset found in continuous operation of the
device into the sensor.
Temperature offset value is saved in non-volatile memory. The last set value will be used for temperature offset compensation
after repowering.
15. Set Sensor Altitude Value
Command For COPY: 7E 00 17 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 1C 00 00 00 00 03 F6 00 E8
Above command is setting the Altitude value to 1014
Starts continuous measurement of the SCD30 to measure CO2 concentration, humidity and temperature. Measurement data
which is not read from the sensor will be overwritten. The measurement interval  is 2s.
Continuous measurement status is saved in non-volatile memory. When the sensor is powered down while continuous
measurement mode is active SCD30 will measure continuously after repowering without sending the measurement command.
The CO2 measurement value can be compensated for ambient pressure by feeding the pressure value in mBar to the sensor.
Setting the ambient pressure will overwrite previous settings of altitude compensation. Setting the argument to zero will
deactivate the ambient pressure compensation (default ambient pressure = 1013.25 mBar). For setting a new ambient pressure
when continuous measurement is running the whole command has to be written to SCD30.
Measurements of CO2 concentration based on the NDIR principle are influenced by altitude. SCD30 offers to compensate
deviations due to altitude by using the following command. Setting altitude is disregarded when an ambient pressure is given to
the sensor.
16. Set Sensor Forced Calibration Value
Command For COPY: 7E 00 15 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 1F 00 00 00 01 BD 22
Above command is setting the force calib value to 445 ( 01 BD)
Forced recalibration (FRC) is used to compensate for sensor drifts when a reference value of the CO2 concentration in close
proximity to the SCD30 is available. For best results, the sensor has to be run in a stable environment in continuous mode at a
measurement rate of 2s for at least two minutes before applying the FRC command and sending the reference value. Setting a
reference CO2 concentration by the method described here will always supersede corrections from the ASC.
and vice-versa. The reference CO2 concentration has to be within the range 400 ppm ≤ cref(CO2) ≤ 2000 ppm.
The FRC method imposes a permanent update of the CO2 calibration curve which persists after repowering the sensor.
Command support — Firmware version 3 or above.
Appendix B
  2. Keep only the last 8 bits
