- Device Overview
- Frame Structure
- Read Sleep Duration
- Read Sensor Network ID
- Appendix
Feature
Frame Structure
| 8 | 0x55 | |||
| 9 | 0x4E | |||
| 8 | 0x47 | |||
| 9 | 0x4D | |||
| 8 | 0x55 | |||
| 9 | 0x4D |
Run Mode Power Up Frame
| 0x7E | 1 | Delimiter |
| 0x001C | 2 | Length |
| 0xFFFE | 2 | Reserved |
| 0x00 | 1 | R. Option |
| 0x01 | 1 | Node ID |
| 0x00 | 1 | Separator |
| 0x0001 | 2 | Sensor Type |
| 0x0000 | 2 | Separator |
| 0x0B | 1 | Checksum |
| 0x0E | 1 | Checksum |
Sensor Data Frame
Data Payload
| Field | Offset (Payload Section) | Value ( or Default ) | Length | Description |
| Header | 0 | 7F | 1 | Header to differentiate various type of packets |
| Node ID | 1 | 00 | 1 | User Defined ID |
| Firmware Version | 2 | 01 | 1 | Device Firmware Version |
| Battery Level | MSB 3, LSB 4 | - | 2 | Sampled battery voltage of the device. Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V |
| Packet Counter | 5 | - | 1 | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets. |
| Sensor Type | MSB 6, MSB 7 | 00, 0x04 | 2 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
| Error/Reserve Byte | 8 | 0x00 | 1 | error code = 1 ( data was not ready) |
| Sensor Data | MSB 9/ Data[0] | - | 4 | Temperature data |
| 10/ Data[1] | - | Temperature(signed) = ((data[0]<<24)+(data[1]<<16)+(data[2]<<8)+(data[3]))/100 | ||
| 11/ Data[2] | - | |||
| 12/ Data[3] | - |
Configuration Mode Frame
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep. But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data. If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep. The Machine Uptime sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Complete Payload
F7 06 00 00 00 05
Complete Payload
Appendix
Configuration Commands
Command Acknowledgement Data
| 14 | Set Encryption Key | 1 | 8 | 0xFF (OK) |
Application Specific Commands
| No. | Command description | Command | Sub command | Reserve byte | Command code | Argument | Description |
| 1 | Set Thermocouple Type | 0XF4 | 0x53 | - | 0x00 -- K Type 0x10 -- J Type 0x20 -- T Type 0x30 -- N Type 0x40 -- S Type 0x50 -- E Type 0x60 -- B Type 0x70 -- R Type | This command allows you to set the type of thermocouple sensor probe connected. Thermocouples are available in different metal combinations and calibrations, offering a variety of temperature measurement options. | |
| 2 | Read Thermocouple Type | 0XF4 | 0x54 | - | - | Read the Type of Thermocouple sensor probe connected. | |
| 3 | Set Filter Level | 0XF4 | 0x55 | - | - | 0x00 -- Level 0 0x01 -- Level 1 0x02 -- Level 2 0x03 -- Level 3 0x04 -- Level 4 0x05 -- Level 5 0x06 -- Level 6 0x07 -- Level 7 | This command allows you to set the filter level applied to the sensor data. Note: This feature is available only for firmware versions 9 and above. |
| 4 | Read Filter Level | 0XF4 | 0x56 | Read the Filter Level | |||
| 5 | Set Cold Junction Resolution | 0XF4 | 0x57 | 0x00 -- 0.0625⁰C 0x80 – 0.25⁰C | This command allows you to set the resolution for cold junction compensation. Cold junction compensation adjusts for the thermoelectric voltage missing due to the fact that the thermocouple’s cold end at the instrument is not at the reference temperature of 0°C (32°F). This feature is available only for firmware versions 9 and above. | ||
| 6 | Read Cold Junction Resolution | 0XF4 | 0x58 | Read the Cold Junction resolution | |||
| 7 | Set ADC Resolution | 0XF4 | 0x59 | 0x00 -- 18 Bits 0x20 -- 16 Bits 0x40 -- 14 Bits 0x60 -- 12 Bits | This command allows you to set the ADC (Analog-to-Digital Converter) resolution for the thermocouple. The available resolution options are 12, 14, 16, and 18 bits. This feature is only available for firmware versions 9 and above. | ||
| 8 | Read ADC Resolution | 0XF4 | 0x60 | Read the ADC Resolution | |||
| 9 | Set Number of Samples | 0XF4 | 0x5B | 0x00 -- 1 Sample 0x04 -- 2 Samples 0x08 -- 4 Samples 0x0C -- 8 Samples 0x10 -- 16 Samples 0x14 -- 32 Samples 0x18 -- 64 Samples 0x1C -- 128 Samples | This command allows you to set the number of samples the sensor will take before sending the data. This feature is available only for firmware versions 9 and above. | ||
| 10 | Read Number of Samples | 0XF4 | 0x5C | Read the Number of Samples | |||
| 11 | Set Measurement Type | 0XF4 | 0x5F | 0x00 -- Cold Junction 0x01 -- Hot Junction 0x02 -- Delta | This command allows you to set the measurement type for the probe. The available options are: Cold Junction, Hot Junction, and Delta. This feature is available only for firmware versions 9 and above. | ||
| 12 | Read Measurement Type | 0XF4 | 0x60 | Read the Measurement Type |
Error Code Descriptions
| 0x01 | Invalid command |
| 0x03 | Node ID mismatch |
Calculation for transmission
0x04
0xFF-0x04=0xFB
Calculation for reception
2. Keep only the last 8 bits
0xFF
