Industrial Wireless RS485 Modbus Transmitter User Manual
Explore the Industrial Wireless RS485 Modbus Transmitter Capabilities
The NCD Industrial Wireless RS485 Modbus Transmitter (PR55-88F) transforms Modbus devices into seamless wireless nodes, enabling effortless integration into the NCD wireless network and eliminating the need for cumbersome wired connections. .
Instead of relying on a central gateway to constantly request data, the Industrial Wireless RS485 Modbus Transmitter operates as the “Master” of its own RS485 loop. It bridges the gap between legacy hardware and modern wireless networks by operating autonomously on a user-defined schedule.
  • Industrial Grade IoT Modbus RS485 To Wireless Converter
  • Works With VFD, PLC, SCADA systems
  • Works With HVAC Control Systems
  • Ideal For MODBUS-RTU Communication Over Wireless
  • Convert any RS485 Sensor/Device into a Wireless Sensor/Device
  • API communication over Wireless for Robust Reliability
  • 5V-24VDC Input Voltage Range
Hardware Controls
RESET Button
The RESET (R) button will power cycle the sensor. When the sensor first powers up it will send a sensor_mode message with the mode of RUN.
CONFIGURATION Button
The CONFIGURATION (C) button serves two functions.
Hardware Mode Selection
Run Mode is the default state of the sensor when powered up. No hardware interaction is necessary to enter this state other than power. Pressing the Reset (R) button will restart the sensor and put it in the RUN Mode state if no other buttons are pressed.
Configuration Mode is the state in which the sensor enters in order to change the sensor’s configurable parameters such as; Baud Rate, Stop bit, Modbus Function Code, Reporting Interval, Transmission Power, Network ID,etc.
You can enter in this mode manually by pressing and releasing the RESET button, device will enters RUN mode, then it will transmit sensor data and finally enters into configuration mode (sync mode). Sensor enters into configuration mode automatically every 1 hour.
This is a temporary mode that is not intended for long-term operation. device will returns automatically to Run mode after a successful configuration in order to resume normal operations.
Factory Default/Reset
  • Wait for 3-5 seconds
Default Factory Configuration
ParameterDefault ValueUnitNote
Baud Rate9600bps
Stop Bit1bit
Parity BitNone
RS485 Rx Timeout2000milliseconds
Bootup Time0 (Disabled)seconds
Slave ID (Address)1
Sub Device Type0
Number of Read Retries0
Read Parameter (FC)0x03 (Read Holding Register)It support:
Read Input Register
Read RegistersDisabledMax. 32 Registers
Modbus Register Address (1-32)0Max. 32 Registers
For more information and a general introduction on what Node-Red is and how it works you can view Node-Red’s official web site at https://nodered.org/.
All Enterprise Gateway we offer will come with Node-Red and our library running as a service by default to allow quick and easy access to Node-Red and the sensor data from our sensors. If you are using your own gateway or computer you will need a USB or Ethernet Modem, Node-Red, and our library @ncd-io/node-red-enterprise-sensors.
You can find our library on Node-Red with the name: @ncd-io/node-red-enterprise-sensors
Wireless Gateway Nodes
Wireless Gateway Ready State
When the Wireless Gateway Node’s status indicates “Ready”, as shown in the picture on the right, it means that the wireless network is successfully connected to Node-Red and is ready to receive data from the sensor(s). Sensors that support SYNC messages can be automatically configured while in this mode if a corresponding Wireless Device node is configured to do so. See section Sensor Configuration Processes for more information.
Wireless Gateway in the Ready State
Wireless Gateway Configuring State
Wireless Gateway in Configuration Mode
Wireless Gateway Failed to Connect State
Wireless Gateway node Failed to Connect State
Wireless Gateway Connecting State
Wireless Gateway Node Connecting State
Wireless Gateway No State
modem_mac Message
A modem_mac message indicates the unique address of the wireless module connected to the Wireless Gateway Node. This message is sent when Node-RED is deployed and when the Wireless Gateway is put into Configuration Mode or Ready Mode by using the embedded Wireless Gateway node button. An example modem_mac message can be found on the right.
  • topic
  • payload
  • time
    • Timestamp of the message
  "topic": "modem_mac",
  "time": 1721424259706,
  "_msgid": "83ad39df1328dea7"
Wireless Gateway Processed Sensor Data Message
Sensor data is the primary message that will come from a Wireless Gateway Node. These messages can be discerned from other message types by the topic which will always be “sensor_data
  • nodeID
  • firmware
  • battery
  • battery_percent
  • counter
  • sensor_type
  • sensor_data
    • See section msg.payload.sensor_data Breakdown for more information
  • sensor_name
  • type
  • addr
  • received
  • original
  • modem_mac
  "topic": "sensor_data",
  "payload": {
    "nodeId": 0,
    "firmware": 7,
    "battery": "3.28",
    "battery_percent": "98.56",
    "counter": 26,
    "sensor_type": 539,
    "sensor_data": {
      "subdevice_type": 0,
      "number_of_registers": 0,
      "status_24_31": 0,
      "status_16_23": 0,
      "status_8_15": 0,
      "status_0_7": 0,
      "data": [
          0: 0,
          1: 0,
          2: 0,
          3: 0,
          4: 0,
          5: 0,
          6: 0,
          7: 0,
          9: 0,
          10: 0
    "sensor_name": "RS-485 Modbus Wireless Converter",
    "type": "sensor_data",
    "received": 1721424191583,
    "original": {...},
  "time": 1721424191584,
  "_msgid": "d7f3341ef39225df"
Wireless Gateway Processed Sensor Data Breakdown
  • sub_device_type
    • Byte to indicate what kind of User-defined Modbus RTU device it’s connected to.
  • number_of_registers
    • The number of registers read, up to a maximum of 32 registers in one operation.
  • status_0_to_31
    This property indicates the status of the registry query:
    • 1: Indicates a successful response (no error).
    • 0: Indicates that an error occurred.
      Data Parsing Instructions:
      The value is provided as a decimal (DEC) integer. To verify individual status bits, you can convert the decimal or hexadecimal representation into its binary format to evaluate the status of each specific bit.
  • data
    • A variable-length array, it contains the value obtained from the Modbus-RTU registers as requested by the user.
Wireless Gateway RUN Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "topic": "sensor_mode",
  "payload": {
    "type": 539,
    "nodeId": 0,
    "mode": "RUN",
    "lastHeard": 1721424191056
  "time": 1721424191056,
  "_msgid": "f41dad7923ece27c"
Wireless Gateway PUM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 539,
    "nodeId": 0,
    "mode": "PUM",
Wireless Gateway Sync Check In Message
This sync_check_in message reports sensor information and allows for sync initialization if configuration changes are necessary.
sync_check_in message indicates that the sensor is in RUN mode, but is entering a temporary state where it can be configured. The sensor will send the sync_check_in message on boot (after RUN and sensor_data messages) and once an hour after boot to check in. Once the sensor sends a sync_check_in message Node-RED has 2 seconds to respond with a configuration Master Command.
If Node-RED has a Wireless Device node with Mac Address, Auto Config and OTF Config selected corresponding to the sensor that sent the sync_check_in message then Node-RED will begin to configure that sensor.
An example sync check-in message can be found on the right.
  • topic
    • Indicates the message is a sync message
  • payload
  • payload.type
    • Indicates the type of sync message.
  • payload.address
    • Indicates the unique address of the sensor sending the sync message
  •  payload.sensor_type
  • payload.human_readable object
    • It contains the human readable data, display configuration set up on the sensor at the time of the sync transmission.
  • payload.human_readable.core_version
  • payload.human_readable.firmware_version
    • The actual firmware version running on device.
  • payload.human_readable.sensor_type
    • Displays the sensor type.
  • payload.human_readable.tx_lifetime_counter
    • Tracks the total number of data packets transmitted by the CPU since the device first booted
  • payload.human_readable.hardware_id
    • This value indicates the hardware version of the device
  • payload.human_readable.network_id
    • This value indicates the network Id configured on the device, by default all ncd devices uses 0x7FFF.
  • payload.human_readable.destination_address
    • Shows the current destination address configured on the sensor. The default setting is broadcast mode “00:00:FF:FF”
  • payload.human_readable.node_id
  • payload.human_readable.report_rate
    • Specifies the data transmission interval in seconds.
  • payload.human_readable.register_to_read
    • Specifies the total number of registers to read on interval in the Register Reads field.
  • payload.human_readable.modbus_register_x
    • Specifies the Modbus Register Address (0-based offset) to read (1-32 Registers).
  • payload.human_readable.baud_rate
    • Specifies the baud rate value configured.
  • payload.human_readable.bootup_time
    • Specifies the delay interval (in seconds) that the transmitter waits after powering on the connected Modbus device before issuing the first command.
  • payload.human_readable.slave_address
    • Specifies the unique Slave Modbus device address (Slave ID) for the transmitter.
  • payload.human_readable.rs485_rx_timeout
    • Specifies the maximum time (in milliseconds) that the device will wait to receive a response from the RS485 field device via the serial port after it sends command.
  • payload.human_readable.sub_device_type
    • Specifies the user-defined byte used to identify the specific type of Modbus RTU device connected.
  • payload.human_readable.read_retries
    • Specifies the maximum number of attempts the device will make to perform a Modbus RTU register query.
  • payload.human_readable.modbus_command
    • Specifies the the Modbus Function Code configured.
  • payload.human_readable.parity_bit
    • Specifies the parity bit configured.
  • payload.human_readable.stop_bits
    • Specifies the stop bits configured.
  • payload.machine_values
    • The Raw data the sensor reports
  • description
    • Indicates information about the current sync message.
  "topic": "sync",
  "payload": {
    "type": "sync_check_in",
    "address": "00:13:a2:00:42:35:89:86",
    "sensor_type": 536,
    "human_readable": {
      "core_version": 23,
      "firmware_version": 7,
      "sensor_type": 127,
      "tx_lifetime_counter": 13,
      "hardware_id": {
        "data": [ 99, 61, 0]
     "network_id": "7fff",
     "destination_address": "0000ffff",
     "node_id": 0,
     "report_rate": 900,
     "register_to_read": "0",
     "modbus_register_1": 0,
     "modbus_register_2": 0,
     "modbus_register_3": 0,
     "modbus_register_4": 0,
     "modbus_register_5": 0,
     "modbus_register_6": 0,
     "modbus_register_7": 0,
     "modbus_register_8": 0,
     "modbus_register_9": 0,
     "modbus_register_10": 0,
     "modbus_register_11": 0,
     "modbus_register_12": 0,
     "modbus_register_13": 0,
     "modbus_register_14": 0,
     "modbus_register_15": 0,
     "modbus_register_16": 0,
     "modbus_register_17": 0,
     "modbus_register_18": 0,
     "modbus_register_19": 0,
     "modbus_register_20": 0,
     "modbus_register_21": 0,
     "modbus_register_22": 0,
     "modbus_register_23": 0,
     "modbus_register_24": 0,
     "modbus_register_25": 0,
     "modbus_register_26": 0,
     "modbus_register_27": 0,
     "modbus_register_28": 0,
     "modbus_register_29": 0,
     "modbus_register_30": 0,
     "modbus_register_31": 0,
     "modbus_register_32": 0,
     "baud_rate": "9600",
     "bootup_time": 0,
     "slave_address": 1,
     "rs485_rx_timeout": "2000 msec",
     "sub_device_type": 0,
     "read_retries": 0,
     "modbus_command": "Read Holding Register 0x03",
     "parity_bit": "None",
     "stop_bits": "1 bit",
    "machine_values": { ... }
  "description" : "...",
  "packet_info": {
      "ack": 0,
      "broadcast": 0,
      "type": ""
  "time": 1781217138869,
  "_msgid": "33fd88e3ea54492c"
Wireless Gateway Assertion Reason Message
A Assertion Reason message will be used for debugging purpose, It will show the code line number and function name.
An example Assertion Reason message can be found on the right.
  "topic": "assert_rsn",
  "payload": {
    "type": 539,
    "nodeId": 0,
    "line_number": 1435,
    "function_name": "app_start_fly_timer"
  "time": 1721424191767,
  "_msgid": "5f6f01b6651b2f82"
Wireless Node Configuration
Wireless Gateway Edit Pane
  1. Name
  2. Serial Device*
  3. Serial Device Edit Icon
    • For More information on the submenu this icon bring up see section ncd-gateway-config Nodes​
Wireless Device Nodes
Wireless Device Node Statuses
Running Mode
Wireless Device in Run Mode
No Mode
Wireless Device node with no status
FLY Mode
When the Wireless Sensor Node’s status indicates “FLY,” as shown in the picture to the right, it means the sensor has sent a sync message to check in for an Over-the-Air (OTA) configuration, and the synchronization process has been successfully completed.
Config Mode
Wireless Device Node Messages
Wireless Device Sensor Data Message
  • topic
  • data
  • data.nodeID
  • data.firmware
  • data.battery
  • data.battery_percentage
  • data.counter
  • data.sensor_type
  • data.sensor_data
  • data.sensor_name
  • data.type
  • data.addr
  • data.received
  • data.original
  • data.modem_mac
  • payload
    • See msg.payload Breakdown for more information
  • time
  "data": {
    "nodeId": 0,
    "firmware": 10,
    "battery": "3.28",
    "counter": 26,
    "sensor_type": 539,
    "sensor_data": {
      "status_24_31": 0,
      "status_16_23": 0,
      "status_8_15": 0,
      "status_0_7": 0,
      "data": [
          0: 0,
          1: 0,
          2: 0,
          3: 0,
          4: 0,
          5: 0,
          6: 0,
          7: 0,
          9: 0,
          10: 0
    "original": {...},
  "payload": {
      "status_24_31": 0,
      "status_16_23": 0,
      "status_8_15": 0,
      "status_0_7": 0,
      "data": [
          0: 0,
          1: 0,
          2: 0,
          3: 0,
          4: 0,
          5: 0,
          6: 0,
          7: 0,
          9: 0,
          10: 0
  "_msgid": "48e99332fc104565"
Wireless Device Sensor Data Breakdown
  • sub_device_type
  • status_0_to_31
  • data
A sync_check_in message indicates that the sensor is in RUN mode, but is entering a temporary state where it can be configured. The sensor will send the sync_check_in message on boot (after RUN and sensor_data messages) and once an hour after boot to check in. Once the sensor sends a sync_check_in message Node-RED has 2 seconds to respond with a configuration Master Command.
  "topic": "sync",
  "sensor_type": 536,
    "human_readable": {
      "core_version": 23,
      "sensor_type": 127,
      "hardware_id": {
     "node_id": 0,
     "report_rate": 900,
     "bootup_time": 0,
     "slave_address": 1,
     "read_retries": 0,
  "packet_info": {
      "ack": 0,
      "broadcast": 0,
      "type": ""
Sync Acknowledgment Message
A sync acknowledgment is received from the sensor in response to a configuration command. This message provides the current sensor status or reports any errors encountered during the configuration process. You may verify the current sensor configuration by examining the human_readable property within the message.
An example of a Sync Acknowledgment message is provided for your reference on the right.
  "topic": "sync",
  "type": "sync_acknowledgment",
  "sensor_type": 539,
  "payload": {
    "sensor_type": 539,
    "response_bytes": [ ... ],
    "human_readable": { ... },
  "sent": [...],
  "packet_info": {
      "ack": 0,
      "broadcast": 0,
      "type": ""
Sync End Message
Sync process finished. Sensor is reporting its new values after Sync and resuming normal operations.
User can find the new settings after sync into “human_readable” property.
  "topic": "sync",
  "type": "sync_end",
  "sensor_type": 539,
  "payload": {
    "type": "sync_end",
    "sensor_type": 539,
  "sent": [...],
  "packet_info": {
      "ack": 0,
      "broadcast": 0,
      "type": ""
Sync Response Success Message
Indicates that the sync configuration is complete and displays the specific values and properties applied to the settings.
  "topic": "sync",
  "type": "sync_response",
  "sensor_type": 539,
  "payload": {
    "sensor_type": 539,
    "values": { ... },
    "pass": { ... },
    "status": "Success",
    "exit_otn_mode": { ... }
Sync Response Skip Message​
A “Sync Response Skip” message indicates that the settings currently active within the corresponding Wireless Device node already match the sensor’s actual configuration. Consequently, the library bypasses the synchronization process. This functionality allows the library to verify if the sensor’s reported configuration aligns with the desired parameters, thereby optimizing the process by skipping redundant updates.
If you encounter this message, it confirms that the sensor is already configured with the desired settings as defined in the sync message.
  "topic": "sync",
  "sensor_type": 539,
  "payload": {
    "sensor_type": 539,
    "info": "Reported configurations match desired configurations. Skipping Sync."
Configuration Options
Our Node-Red library lets you configure any of sensor easily, simply by adjusting a few fields in your Node-RED flow and triggering a configuration update either through the CFG button on the sensor or waiting for a FLY (sync) message sent every hour during normal operations (or when the device is reset).
Primary Configurations
  • Name
    • Arbitrary name of this node
  • Serial Device*
    • For More information on the submenu the edit icon brings up see section ncd-gateway-config Nodes
  • Serial Device for Config
  • Mac Address*
  • Sensor Type*
  • Auto Config
  • OTF Config
    • Checking the box next to this field AND having Auto Config checked tells Node-Red that the sensor(s) corresponding to this Wireless Device node should be configured when a FLY message is detected
NCD Wireless Device node Modbus Transmitter
  • Wait for Network Formation
  • Destination Address
    • For more information on how to get the Address of the receiver module connected to Node-Red see section Wireless Gateway modem_mac Message
  • Network ID
  • Node ID
  • Power
  • Retries
Set Baud Rate
Configure the communication speed for the RS485 port
NCD Modbus RTU Node-RED Configuration example 1
Set Stop Bit
Configure the cthe stop bit signals the end of a data byte.
NCD 539 Set Stop Bit
Set Parity Bit
Configure the the Parity bit.
NCD 539 Set Parity
Set RS485 Rx Timeout
Sets the maximum time (in milliseconds) that the device will wait to receive a response from the RS485 field device via the serial port after it sends command.
NCD 539 Set rs485 Rx Timeout
Set Boot Time
Sets the delay interval (in seconds) that the NCD transmitter waits after powering on the connected Modbus device before issuing the first command. This delay ensures the external Modbus device has sufficient time to complete its internal initialization sequence before the transmitter begins polling.
NCD 539 Set Bootup Time
Set Slave ID
Configures the unique Slave Modbus device address (Slave ID) for the transmitter.
Set Sub Device Type
A user-defined byte used to identify the specific type of Modbus RTU device connected. This parameter is essential for correctly decoding incoming messages and distinguishing between different devices on the network.
NCD 539 Set Sub device Type
Set Number of Read Retries
Sets the maximum number of attempts the device will make to perform a Modbus RTU register query.
NCD 539 Set Number of Read Retries
Set Read Parameter
Sets the Modbus Function Code.
NCD Modbus RTU Node-RED Configuration example 3
Set Read Registers
Set the total number of registers to read on interval in the Register Reads field. Set the individual Registers to read below in the correspond Register field.
Register Read Field: Set the individual Modbus Register to read.
NCD Modbus RTU Node-RED Configuration example 4
NCD Register to Read Address Example PR55-88F
OTF Automatic Configuration
This sensor supports configuration while in Run Mode. We call this configuration OTF or On the Fly. This configuration is initiated by a SYNC message from the Sensor with the topic of sync. These messages are sent over the standard Run Mode wireless network so there is no need to change the Wireless Gateway nodes mode or manually manipulate the buttons on the sensor.
Sync messages are sent once an hour and on boot and tell Node-RED that the sensor is ready for configuration changes. Node-RED has two seconds to respond with a configuration command or extend this temporary configuration mode.
If you have a Wireless Device node with Mac address, Auto Config and OTF Config corresponding to the sensor that sent the sync message then Node-Red will begin configuring that sensor according to the settings entered on the Wireless Device node.
Example Auto Configuration Process​
If you have entered the sensor Mac Address, selected the Auto Config and OTF Config boxes, your sensor will pick up any configuration changes you have made to the Sensor Specific parameters and automatically apply them.
This process is not immediate and requires the device send a sync Message to the Gateway (this happens once every hour or when the device is reset).
Once the sync message has been received the device will enter OTN mode (indicated by a corresponding message) and update any parameters that have been changed.
Once done the device will continue its normal operating with the updated parameter values.
Let us look at an example to better illustrate how the process should work out.
Step 1
Draw and drop a Wireless Device node and connect a debug node at the Wireless Device node, then double click on Wireless Device node to access its properties. Enter the Mac Address of the target sensor, check the two boxes, the one next to “Auto Config” and the one next to “OTF Config”. This will allow the device to work in a mode where it will Automatically pick up the configuration changes.
Step 2
Select the parameter you want to modify.
Let’s go to the “Baud Rate” and change its value. This parameter determines the baud rate value for the RS485 Serial Communication.
The default value is 9600 baud rate, let’s change it to 115200 baud rate.
Make sure you check the “Active” check box, this will let the sensor know that it needs to update this parameter.
Select the value from the drop down menu, in this case 115200.
Press the “Done” button to close the Wireless Device node.
Press the “Deploy” button so you can update the flow.
NCD type 539 Baud Rate configuration Example
Step 3
Reset the sensor in order to trigger a sync message (configuration mode).
(this will speed things up so you don’t need to wait for the 1 hour automatic sync message time).
You will receive a series of messages into debug window, which are normally sent after deploy and the sensor starts (modem_macRUNsensor_data, then sync_check_in).
NCD Node-RED Flow Configuration Example
NCD 539 Sync Process Example
The most important element here is the sync_check_in message, which reports the device’s current configuration at the moment it is transmitted. You can view an example of this message on the right for your reference.
Once the sensor sends a sync_check_in message, Node-RED receives it and compares the sensor’s current settings with your newly desired settings. If they do not match, Node-RED recognizes that an update is needed and automatically sends a master command to apply the new configuration.
For example, in this specific case, the sensor’s current baud_rate is set to 9600, but we want to update it to 115200. Because Node-RED detects this difference, it will automatically initiate the sync configuration process to update your device.
  "topic": "sync",
  "sensor_type": 536,
    "human_readable": {
      "core_version": 23,
      "sensor_type": 539,
      "hardware_id": {
     "node_id": 0,
     "report_rate": 900,
     // This is the setting we want to to set in this example
     "bootup_time": 0,
     "slave_address": 1,
     "read_retries": 0,
  "packet_info": {
      "ack": 0,
      "broadcast": 0,
      "type": ""
  "topic": "sync",
  "sensor_type": 539,
  "payload": {
    "sensor_type": 539,
Once Node-RED sends the master command with the new desired settings, the sensor will respond with a sync_acknowledgment message, followed by a sync_end message, and finally a sync message with a “success” status. This sequence indicates that the configuration process is complete.
NCD Type 127 Configuration Example
After the sync configuration has finished, you can verify the new sensor settings by expanding the sync_end message in the debug window. There, you can review the human-readable properties to see the actual configurations applied to the sensor. In this example, the baud_rate will now show as 115200.
  "topic": "sync",
  "type": "sync_end",
  "sensor_type": 536,
  "payload": {
    "type": "sync_end",
    "sensor_type": 127,
    "human_readable": {
      "core_version": 23,
      "firmware_version": 10,
      "sensor_type": 536,
      "hardware_id": {
     "node_id": 0,
     "report_rate": 900,
     // This is the setting we changed
     "baud_rate": "115200",
     "bootup_time": 0,
     "slave_address": 1,
     "read_retries": 0,
  "sent": [...],
  "packet_info": {
      "ack": 0,
      "broadcast": 0,
      "type": ""
Check Sensor Power
Press the CFG button on the sensor. If the TEST LED on the sensor lights up then the sensor has power. If the LED does not light up try swapping out the battery.
If the LED still doesn’t light up after changing the battery contact us for additional troubleshooting steps.
Factory Reset Sensor
  1. Factory Reset the Sensor
    • Factory reset by pressing and release the RESET button, wait for a second, then press and hold the CONFIGURATION button, hold the CONFIGURATION button for more than 15 seconds, release CONFIGURATION button, then Wait for 3-5 seconds, finally press and release the RESET button.
  2. You should receive a sensor_mode message with the mode of PUM and then a second sensor_mode message with the mode of RUN
Multiple Gateways
Move Devices Closer
