Explore the Industrial Wireless RS485 Modbus Transmitter Capabilities
The NCD Industrial Wireless RS485 Modbus Transmitter (PR55-88F) transforms Modbus devices into seamless wireless nodes, enabling effortless integration into the NCD wireless network and eliminating the need for cumbersome wired connections. .
Instead of relying on a central gateway to constantly request data, the Industrial Wireless RS485 Modbus Transmitter operates as the “Master” of its own RS485 loop. It bridges the gap between legacy hardware and modern wireless networks by operating autonomously on a user-defined schedule.
Features:
- Industrial Grade IoT Modbus RS485 To Wireless Converter
- Works With VFD, PLC, SCADA systems
- Works With HVAC Control Systems
- Ideal For MODBUS-RTU Communication Over Wireless
- Convert any RS485 Sensor/Device into a Wireless Sensor/Device
- API communication over Wireless for Robust Reliability
- 5V-24VDC Input Voltage Range
| Width | 2.50" | |||
| Length | 2.50" | |||
| Height | 0.90" | |||
| Probe Temperature | -40° C | 23° C | 85° C | As Tested by NCD Staff |
| Input Voltage Range | 5VDC | 32VDC | Works with either DC or AC |
Wiring Connections
RF Module Specifications
This device is has not been designed to run on batteries and can only work with an External power supply (5-32V AC/DC Power Input).
