Explore The Industrial Wireless RS485 Modbus Transmitter Capabilities
The NCD Industrial Wireless RS485 Modbus Transmitter (PR55-88F) transforms Modbus devices into seamless wireless nodes, enabling effortless integration into the NCD wireless network and eliminating the need for cumbersome wired connections. .
Instead of relying on a central gateway to constantly request data, the Industrial Wireless RS485 Modbus Transmitter operates as the “Master” of its own RS485 loop. It bridges the gap between legacy hardware and modern wireless networks by operating autonomously on a user-defined schedule.
Features:
- Industrial Grade IoT Modbus RS485 To Wireless Converter
- Works With VFD, PLC, SCADA systems
- Works With HVAC Control Systems
- Ideal For MODBUS-RTU Communication Over Wireless
- Convert any RS485 Sensor/Device into a Wireless Sensor/Device
- API communication over Wireless for Robust Reliability
- 5V-24VDC Input Voltage Range
Frame Structure
| 8 | 0x55 | |||
| 9 | 0x4E | |||
| 8 | 0x47 | |||
| 9 | 0x4D | |||
| 8 | 0x55 | |||
| 9 | 0x4D |
Run Mode Frame
| 7E 00 1C 90 00 13 A2 00 42 35 89 86 FF FE C2 7A 01 00 02 1B 00 00 52 55 4E 00 00 00 00 00 00 79 | Example frame | |
| 0x7E | 1 | Delimiter |
| 0x001C | 2 | Length |
| 0xFFFE | 2 | Reserved |
| 0xC2 | 1 | R. Option |
| 0x00 | 1 | Node ID |
| 0x00 | 1 | Separator |
| 0x021B | 2 | Sensor Type |
| 0x0000 | 2 | Separator |
| 0x79 | 1 | Checksum |
Configuration Mode Frame
| 7E 00 44 90 00 13 A2 00 42 35 89 86 FF FE C2 4F 00 00 19 07 02 1B 00 00 01 AF 55 88 00 7F FF 00 00 FF FF 00 00 00 03 84 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 07 D0 00 00 03 00 01 5F | Example frame | |
| 0x0044 | 2 | Length |
| 0x90 | 1 | Frame Type |
| 4F | 1 | Header |
| 0000 | 2 | Reserved |
| 17 | 1 | Core Engine Version |
| 0B | 1 | Firmware Version |
| 007F | 2 | Sensor Type |
| 00000001 | 4 | Tx Life Counter |
| 633D00 | 3 | Hardware ID |
| 7FFF | 2 | Network ID |
| 0000FFFF | 4 | Destination Address |
| 00 | 1 | Node ID |
| 0000000A | 4 | Report Rate |
| 01 | 1 | Register to Read |
| 00000000000000000000 00000000000000000000 00000000000000000000 00000000000000000000 00000000000000000000 00000000000000000000 00000000 | 32 | Modbus Registers Address |
| 00 | 1 | Baud Rate |
| 00 | 1 | Bootup Time |
| 01 | 1 | Slave Address ID |
| 00 01 | 2 | RS485 Rx Timeout |
| 01 | 1 | Sub Device Type |
| 01 | 1 | Number of Read Retries |
| 01 | 1 | Modbus Function Code |
| 00 | 1 | Parity Bit |
| 00 | 1 | Stop Bit |
| 5F | 1 | Checksum |
Factory Reset Mode Frame
| 7E 00 1C 90 00 13 A2 00 42 53 64 53 FF FE C2 7A 00 00 02 1B 00 00 50 55 4D 00 00 00 00 00 00 D1 | Example frame | |
| 0x7A | 1 | Header |
| 0x50554D | 3 | Mode Byte for Factory Reset Mode |
| 0xD1 | 1 | Checksum |
Sync Check In Frame
| 7E 00 44 90 00 13 A2 00 42 35 89 86 FF FE C2 6F 00 00 19 07 02 1B 00 00 01 AF 55 88 00 7F FF 00 00 FF FF 00 00 00 03 84 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 07 D0 00 00 03 00 01 | Example frame | |
| 0x00 | 1 | R. Option |
| 6F | 1 | Header |
| 0018 | 2 | Sensor Type |
| 00 | 1 | Node ID |
| 00 | 1 | Stop Bit |
| 5F | 1 | Checksum |
Sync Acknowledgment Frame
| 7E 00 44 90 00 13 A2 00 42 35 89 86 FF FE C2 5F 00 00 19 07 02 1B 00 00 01 AF 55 88 00 7F FF 00 00 FF FF 00 00 00 03 84 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 07 D0 00 00 03 00 01 D6 | Example frame | |
| 5F | 1 | Header |
| 02 1B | 2 | Sensor Type |
| 00 | 1 | Node ID |
| 00 | 1 | Stop Bit |
| 5F | 1 | Checksum |
Assertion Reason Frame
| 77 00 00 00 6E 00 00 00 08 C3 61 70 70 5F 73 74 61 72 74 5F 66 6C 79 5F 74 69 6D 65 72 00 00 00 00 00 00 00 00 00 | Example frame | |
| 0x77 | 1 | Delimiter |
| 0x00 | 2 | Node ID |
| 0x0000 | 2 | Reserved |
| 0x007F | 2 | Sensor Type |
| 0x000008C3 | 4 | Line Number |
| 0x00 | Function Name |
Run mode is the default mode of operation of this sensor. In this mode, the sensor sends periodic packets with the sensor measurement data. During the time it is not sending it enters deep-sleep to conserve power. The sensor’s X-bee Radio module operates in API mode and sends packets to the saved destination address on the network specified by the saved PAN ID. Figure 4 illustrates the API transmission/reception procedure.
Sensor Data Frame
| Sensor Type | MSB 6 | 0x02 | 2 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end. |
| LSB 7 | 0x1B | Sensor Type 539 | ||
| Error/Reserved byte | 8 | 0x00 | 1 | Bit 7: Reserved Bit 6: Reserved Bit 5: Reserved Bit 4: Reserved Bit 3: Reserved Bit 2: Reserved Bit 1: Reserved Bit 0: Reserved |
| Sub Device Type | 9/ Data[0] | - | 1 | |
| Number of Registers | 10/ Data[0] | - | 1 | |
| Register Status | 11/ Data[0] | - | ||
| 12/ Data[1] | - | |||
| 13/ Data[2] | - | |||
| 14/ Data[3] | - | 4 | Each bit describes status of a register (0 --> fail, 1-->success) | |
| Register Data | 15/ Data[0] | - | ||
| n/Data[n] | up to 64 Bytes | 2 bytes each register --> Total length 64 bytes |
To put an NCD.io wireless sensor into manual configuration mode, you can do the following:
Using Buttons
1. Press and release the RESET button
2. Immediately press and hold the CONFIGURATION button
3. Hold the CONFIGURATION button for about 5–8 seconds
4. Release the CONFIGURATION button
Sync/Config Mode
This specific device also supports SYNC mode, which allows you to configure the sensor without needing physical access to it (no need to press buttons or trigger a magnetic switch).
By default, the device automatically enters SYNC mode every hour and transmits a SYNC packet (described below). This packet serves two main purposes:
Current Settings: It includes all the active settings, allowing you to easily verify or read the sensor’s current configuration.
Configuration Window: It signals that the sensor is temporarily in configuration mode. During this brief time window, you can transmit a Master Command to update the settings.
Once the time window closes, the device automatically returns to its normal operation (Run mode).
Example Configuration Command
The following is an example on how to read and change some of the parameters that affect the operation of the NCD Sensor.
Master Command
The Master Command is a comprehensive command that allows you to configure all of the device’s settings in a single transmission.
Below, you will find the structure of the master command, along with a detailed payload description for each byte.
7E 00 38 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 6C 00 00 7F FF 00 00 FF FF 00 00 00 00 3C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 01 07 D0 00 00 03 00 01 C9
Complete Payload
Master Command Payload Description
| Byte | Size (bytes) | Setting | Valid Options | Description |
| 6C | 1 | Header | ||
| 00 00 | 2 | Reserved | ||
| 7F FF | 2 | Network ID | 0x00 -- 0x7FFF | Network ID Valid Range: 0-0x7FFF. |
| 00 00 FF FF | 4 | Destination Address | Default value: 0000FFFF for Broadcast Mode Example of targeted address: 41D5EC37 | Sets the Destination Address of the sensor. The sensor will send Run mode Data packets to this Address |
| 00 | 1 | Node ID | 0x00 -- 0xFF | Sets the Device node ID and Data Transmission Interval. The node id value can go from 0-255 and The Data transmission value can go from 3-0xFFFFFF Seconds |
| 00 00 00 3C | 1 | Report Rate | Valid Range: 0x01 -- 0xFFFFFFFF | Sets the Data Transmission Interval |
| 00 | 1 | Register to Read | Valid Range: 0x01 -- 0x20 | Set the total number of registers to read on interval in the Register Reads field. Set the individual Registers to read below in the correspond Register field. |
| 00000000000000000000 00000000000000000000 00000000000000000000 00000000000000000000 00000000000000000000 00000000000000000000 00000000 | 64 | Modbus Registers | the Modbus Register Address (0-based offset). | |
| 04 | 1 | Baud Rate | 0x00 -- 4800 0x01 -- 9600 0x02 -- 19200 0x03 -- 38400 0x04 -- 115200 | |
| 00 | 1 | Bootup Time | Valid Range: 0x01 -- 0xFF | Sets the delay interval (in seconds) that the NCD transmitter waits after powering on the connected Modbus device before issuing the first command. This delay ensures the external Modbus device has sufficient time to complete its internal initialization sequence before the transmitter begins polling. |
| 01 | 1 | Slave address | Valid Range: 0x01 -- 0xFF | |
| 07D0 | 2 | Response Timeout (in milliseconds) | Valid Range: 0x01 -- 0xFFFF | Sets the maximum time (in milliseconds) that the device will wait to receive a response from the RS485 field device via the serial port after it sends command. |
| 00 | 1 | Slave ID | Valid Range: 0x01 -- 0xFF | Configures the unique Slave Modbus device address (Slave ID) for the transmitter. |
| 00 | 1 | Number of Read Retries | Valid Range: 0x01 -- 0x03 | Sets the maximum number of attempts the device will make to perform a Modbus RTU register query. |
| 03 | 1 | Modbus Function Code. | 0x03 -- Read Holding Register (0x03) 0x04 -- Read Input Register (0x03) | |
| 00 | 1 | Set Parity | 0x00 -- None 0x01 -- Even 0x02 -- Odd | |
| 01 | 1 | Set Stop Bit | 0x00 -- Half 0x01 -- 1 bit 0x02 -- 1.5 bit 0x03 -- 2 bit |
Read Sensor Settings
Sync
By using the SYNC packet, you can easily check the current settings configured on your sensor. The SYNC message includes the exact bytes that correspond to your active configuration values (you can find an example of a SYNC packet at the beginning of this document).
If you ever need to manually trigger a SYNC message, simply press the reset button. When you do this, the sensor will respond by sending a quick sequence of three messages: RUN, followed by sensor_data, and finally SYNC.
Additionally, the sensor will automatically transmit a SYNC message every hour by default to keep everything updated.
Read Sensor Power Command:
A. Sensor MAC Address
00 13 A2 00 41 91 1B 83
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Read Wireless Sensor Retries
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep. But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data. If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep. The Machine Uptime sensor will wake up after the predefined sleep time and will try again.
B. Complete Sensor Payload
C. Retries Number
0x0A (data byte 23)
Error Code Descriptions
| 0x01 | Invalid command |
| 0x03 | Node ID mismatch |
Calculation for transmission
0x04
0xFF-0x04=0xFB
Calculation for reception
2. Keep only the last 8 bits
0xFF
