- Device Overview
- Frame Structure
- Read Sleep Duration
- Read Sensor Network ID
- Appendix
Introducing NCD’s Industrial Grade Bidirectional Differential Pressure Sensor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. It processes temperature and pressure data and transmits this information wirelessly. This whole process is repeated at user defined intervals with low power sleep mode activated in between.
Powered by just 6 AA batteries this sensor can last up to 10 years, especially if you utilize the sleep feature efficiently. It can be integrated into any end-user system utilizing the open NCD Node-RED libraries. No vendor lock, you own your data and you can configure the device and process your data at the edge or on a cloud server.
The range, price, accuracy, battery life and security features of Industrial Wireless Differential Pressure Sensor makes it an affordable choice which exceeds the requirements for most of the Industrial as well as consumer market applications.
Feature
- Industrial Grade Bidirectional Differential Pressure Sensor with Temperature output
- A selection of probes with different pressure range and sensitivity:
- AMS5812-0150-D-B Amplified Pressure Sensor -1034 to +1034 mbar -15 to +15 PSI
- AMS5812-0050-D-B Amplified Pressure Sensor -344.7 to +344.7 mbar -5 to +5 PSI
- AMS5812-0001-D-B Amplified Ultra Low Pressure Sensor -10.34 to +10.34 mbar -0.150 to +0.150 PSI
- AMS5812-0003-D-B Amplified Low Pressure Sensor -20.68 to +20.68 mbar -0.30 to +0.30 PSII
- Temperature resolution 0.01°C
- Default Factory setting Restore option
- Real time battery status
Frame Structure
| 8 | 0x55 | |||
| 9 | 0x4E | |||
| 8 | 0x47 | |||
| 9 | 0x4D | |||
| 8 | 0x55 | |||
| 9 | 0x4D |
Run Mode Power Up Frame
| 0x7E | 1 | Delimiter |
| 0x001C | 2 | Length |
| 0xFFFE | 2 | Reserved |
| 0x00 | 1 | R. Option |
| 0x01 | 1 | Node ID |
| 0x00 | 1 | Separator |
| 0x0001 | 2 | Sensor Type |
| 0x0000 | 2 | Separator |
| 0x0B | 1 | Checksum |
| 0x0E | 1 | Checksum |
Sensor Data Frame
Data Payload
| Field | Offset (Payload Section) | Value ( or Default ) | Length | Description |
| Header | 0 | 0F | 1 | Header to differentiate various type of packets |
| Node ID | 1 | 00 | 1 | User Defined ID |
| Firmware Version | 2 | 01 | 1 | Device Firmware Version |
| Battery Level | MSB 3, LSB 4 | - | 2 | Sampled battery voltage of the device. Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V |
| Packet Counter | 5 | - | 1 | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets. |
| Sensor Type | MSB 6, MSB 7 | 00, 0x15 | 2 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
| Error/Reserve Byte | 8 | 00 | 1 | error code = 1 ( data was not ready) |
| Pressure | 9/ Data[0] | 2 | Pressure Data (16 bit Signed Output) | |
| 10/ Data[1] | - | Pressure (PSI) = ((Data[0]<<8)+Data[1])/100 | ||
| Temperature | 11/ Data[0] | 2 | Temperature data (16 bit Signed Output) | |
| 12/ Data[1] | Temperature (°C) = ((Data[0]<<8)+Data[1])/100 |
Configuration Mode Frame
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2CÂ Â
A. Node ID
0x01 (Byte 23)
B. New Delay Value
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78Â
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor PayloadÂ
C. Power Level
0x04 (data byte 23)
B. Complete Sensor PayloadÂ
C. Retries Number
0x0A (data byte 23)
Complete Payload
F7 06 00 00 00 05Â
Complete Payload
Appendix
Configuration Commands
Command Acknowledgement Data
| 14 | Set Encryption Key | 1 | 8 | 0xFF (OK) |
Application Specific Commands
| No. | Command | Sub Command | Command Code | Argument | Note |
| Set Pressure Sensor Type | F4 | 40 | 0x15 | 0x00 = Type 0000-D 0x01 = Type 0001-D 0x02 = Type 0000-D-B 0x03 = Type 000-1-D-B 0x04 = Type 0003-D 0x05 = Type 0008-D 0x06 = Type 0015-D 0x07 = Type 0003-D-B 0x08 = Type 0008-D-B 0x09 = Type 0015-D-B 0x10 = Type 0030-D 0x11 = Type 0050-D 0x12 = Type 0150-D 0x13 = Type 0300-D 0x14 = Type 0600-D 0x15 = Type 1000-D 0x16 = Type 0030-D-B 0x17 = Type 0050-D-B 0x18 = Type 0150-D-B 0x19 = Type 0150-B 0x20 = Type 0150-A 0x21 = Type 0300-A | Defines the AMS 5812 pressure sensor type used for the sensor. |
| Get Pressure Sensor Type | F4 | 41 | 0x15 | - | Read pressure sensor type configured for the sensor |
Error Code Descriptions
| 0x01 | Invalid command |
| 0x03 | Node ID mismatch |
Calculation for transmission
0x04
0xFF-0x04=0xFB
Calculation for reception
0xFF
