Introducing NCD’s IoT Industrial Wireless Absolute & Gauge Pressure and Temperature Sensor is the OEM piezo resistive pressure sensor with 316L stainless steel corrugated diaphragm and isolated oil-filling construction, boasting up to a 2 Mile range using a wireless mesh networking architecture. Incorporating a highly accurate Absolute & Gauge pressure sensor, transmits data at user-defined intervals. It measures Absolute & Gauge pressure and temperature with user configurable resolution at user defined intervals while sleeping during the time when it is not measuring or sending data.
Industrial Wireless Absolute & Gauge Pressure and Temperature Sensor is widely used for various liquid pressure measurement which is compatible with stainless steel and Viton®. The included sensor is rated for 0-100psi absolute pressure, 0-500psi gauge pressure sensor, 0-1000psi sealed gauge sensor with an accuracy of ±0.5%FS (pressure), and 0-5000psi sealed gauge sensor with an accuracy of ±0.5%FS (pressure) ±1.5℃ (Temperature). Easily interfaces using a standard 1/4″ NPT Male connection.
- Industrial Grade Sensor Long Range Wireless Pressure Temperature Sensor
- Operating Range 0 to 10,000psi, -40°C to +85°C (-40°F to 185°F)
- Industry Standard 1/4 inch NPT Male Connector
- Accuracy ±0.5%FS (pressure) ±1.5℃ (Temperature)
- Sampling Frequency 1.5ms
- Long Term Stability: ±0.3%FS/year
- Compatible Media – Gas, Liquid or Vapor
- Node-RED compatible – for configuration and displaying of data (NCD provided libraries)
- IP65 Rated Enclosure
- Improved reliability incorporating Retry feature in case of packet loss
- Real Time Battery Status
Frame Structure
Mode Type | PAN ID set by Sensor (ASCII) | Frame field | Offset (Payload section) | Value |
Run | ID save by user / Default | Mode bytes | 7 | 0x52 |
8 | 0x55 | |||
9 | 0x4E | |||
Configuration | 7BCD | Mode bytes | 7 | 0x50 |
8 | 0x47 | |||
9 | 0x4D | |||
Factory Reset | 7FFF | Mode bytes | 7 | 0x50 |
8 | 0x55 | |||
9 | 0x4D |
Run Mode Power Up Frame
Field | Number of bytes | Description |
7E 00 1C 90 00 13 A1 00 41 58 1C CB FF FE 00 7A 01 00 00 01 00 00 52 55 4E 00 00 00 00 00 00 0B | Example frame | |
0x7E | 1 | Delimiter |
0x001C | 2 | Length |
0x90 | 1 | Frame Type (Power Up) |
0x0013A1004158C1CB | 8 | Source Address |
0xFFFE | 2 | Reserved |
0x00 | 1 | R. Option |
0x7A | 1 | Header with Power Up value |
0x01 | 1 | Node ID |
0x00 | 1 | Separator |
0x0001 | 2 | Sensor Type |
0x0000 | 2 | Separator |
0x52554E | 3 | Mode Byte for Run Mode |
0x000000000000 | 6 | Reserved |
0x0B | 1 | Checksum |
7E 00 1C 90 00 13 A1 00 41 58 1C CB FF FE 00 7A 01 00 00 01 00 00 50 47 4D 00 00 00 00 00 00 1C | Example frame | |
0x50474D | 3 | Mode Byte for Configuration Mode |
0x0E | 1 | Checksum |
Sensor Data Frame
Run mode is the default mode of operation of this sensor. In this mode, the Machine Uptime sensor sends periodic packets with the sensor measurement data. During the time it is not sending it enters deep-sleep to conserve power. The sensor’s X-bee module operates in API mode and sends packets to the saved destination address on the network specified by the saved PAN ID. Figure 4 illustrates the API transmission/reception procedure.
The detail of Payload section of packet is shown in table below:
Frame Field | Offset (Payload section) | Fixed Value (if any) | Description |
Header | 0 | 0x0F | Header to differentiate various types of packets |
Node ID | 1 | 0x00 (Factory Default) | Node ID to differentiate up to 256 nodes in a network. User configurable values |
Firmware | 2 | 01 | Used to determine firmware version programmed in the device |
Battery Voltage | MSB 3 | 03 | Battery Voltage = 0.00322*(03*FF+FE) |
LSB 4 | FE | Battery Voltage = ((Battery Voltage MSB x 256) + Battery Voltage LSB) x 0.00322 V | |
Packet Counter | 5 | - | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets |
Sensor Type | MSB 6 | 0x00 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end. |
LSB 7 | 0x1A | Sensor type 26 | |
Error/Reserved byte | 8 | 0x00 | For future use |
Pressure | 9/Data[0] | - | Pressure Data (16bit Signed Output) |
10/Data[1] | - | Pressure (PSI) = (Data[0]<<8) + Data[1])/100 | |
Temperature | 11/Data[0] | - | Temperature Data (16bit Signed Output) |
12/Data[1] | - | Temperature (C) = (Data[0]<<8) + Data[1])/100 |
Configuration Mode Frame
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
Read Sensor Network ID
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Set Sensor Destination to Broadcast
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Read Wireless Sensor Retries
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep. But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data. If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep. The Machine Uptime sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Set Wireless Sensor number of Retries
Complete Payload
F7 06 00 00 00 05
Complete Payload
Appendix
Configuration Commands
No. | Command | Header | Sub Command | Parameter Field | Default Value | Description |
1 | Set Broadcast Transmission | 0XF7 | 0x01 | - | 0000FFFF | This will set the address to Broadcast mode. All the receiver with same ENY key and PAN ID will get the data packets |
2 | Set ID and Sleep Interval | 0XF7 | 0x02 | NODE ID, D0 MSB,D1, D2 LSB | 0x00,0x00,0x02,0x58 | Sets the Device node ID and Data Transmission Interval. The node id value can go from 0-255 and The Data transmission value can go from 3-0xFFFFFF Seconds |
3 | Set Destination Address | 0XF7 | 0x03 | A0 MSB, A1, A2, A3 | 00,00,FF,FF | Sets the Destination Address of the sensor. The sensor will send Run mode Data packets to this Address |
4 | Set Power | 0XF7 | 0x04 | Power ( range 1-4) | 0x04 | Sets the RF power of the Sensor Radio |
5 | Set PAN ID aka Network ID | 0XF7 | 0x05 | ID0 MSB, ID1 LSB | 0x7FFF | Sets the PAN ID aka Network ID in the sensor. Only sensors, Gateway, and Modes with Same ID can communicate with each other |
6 | Set Retries | 0XF7 | 0x06 | Retries | 0x0A | Sets the number of Retries after unsuccessful transmission for the Sensor Radio |
7 | Read Sleep Interval | 0XF7 | 0x15 | - | 0x00,0x02,0x58 | Reads the stored Sleep Interval value from the sensor |
8 | Read Power | 0XF7 | 0x16 | - | 0x04 | Reads the stored RF Power value from the sensor |
9 | Read Retries | 0XF7 | 0x17 | - | 0x0A | Reads the stored Retries value from the sensor |
10 | Read Destination Address | 0XF7 | 0x18 | - | 00,00,FF,FF | Reads the stored Destination value from the sensor |
11 | Read PAN ID aka Network ID | 0XF7 | 0x19 | - | 0x7FFF | Reads the PAN ID aka Network ID |
12 | Enable Encryption | 0XF2 | 0x01 | - | 0x01 | Enables the Encryption of the Frame Transmitted from the Sensor |
13 | Disable Encryption | 0XF2 | 0x02 | - | - | Disables the Encryption of the Frame Transmitted from the Sensor |
14 | Set Encryption Key | 0XF2 | 0x03 | 00,K0 MSB, K1,K2,K3,K4,K5,K6,K7,K8,K9,K10,K11,K12,K13,K14,K15 | 55AA55AA55AA55AA55AA55AA55AA55AA | Sets the 128 bit AES Encryption Key |
Command Acknowledgement Data
No. | Command | Data bytes | Reserved bytes | Data | Calculation (if any) |
1 | Set Broadcast Transmission | 1 | 8 | 0xFF (OK) | |
2 | Set ID and Sleep Interval | 1 | 8 | 0xFF (OK) | |
3 | Set Destination Address | 1 | 8 | 0xFF (OK) | |
4 | Set Power | 1 | 8 | 0xFF (OK) | |
5 | Set PAN ID aka Network ID | 1 | 8 | 0xFF (OK) | |
6 | Set Retries | 1 | 8 | 0xFF (OK) | |
7 | Read Sleep Interval | 3 | 6 | D0 MSB, D1, D2 LSB | Delay = (D0 x 65536) + (D1 x 256) + D2 |
8 | Read Power | 1 | 8 | Power | DEC value |
9 | Read Retries | 1 | 8 | Retries | DEC value |
10 | Read Destination Address | 4 | 5 | A0 MSB, A1, A2, A3 | |
11 | Read PAN ID aka Network ID | 2 | 7 | ID0 MSB, ID1 | |
12 | Enable Encryption | 1 | 8 | 0xFF (OK) | |
13 | Disable Encryption | 1 | 8 | 0xFF (OK) | |
14 | Set Encryption Key | 1 | 8 | 0xFF (OK) |
Error Code Descriptions
Error Number | Description |
0x01 | Invalid command |
0x02 | Sensor Type mismatch |
0x03 | Node ID mismatch |
0x04 | Apply change command failed during X-bee parameter update |
0x05 | Invalid API packet command response received after Apply change command |
0x06 | Write command failed during X-bee parameter update |
0x07 | Invalid API packet command response received after Write command |
0x08 | Parameter change command failed during X-bee parameter update |
0x09 | Invalid Parameter change command response packet received after Write command |
0x0A | Invalid/Incomplete packet received |
0x0F | Invalid parameter for setup/saving |
Calculation for transmission
0x04
0xFF-0x04=0xFB
Calculation for reception
2. Keep only the last 8 bits
0xFF
