- Device Overview
- Hardware Controls
- Wireless Gateway Nodes
- Wireless Device Nodes
- ncd-gateway-config Nodes
- Examples
During Power-Up, this vibration sensor learns “normal” base-line vibration from the monitored device. This base-line vibration is subtracted from regular sampled vibration readings to improve relevant vibration data. Ideally, the monitored device should be off while the sensor is learning. Once the sensor stabilizes and starts sending data, the device/machinery being monitored can be powered on.
This Industrial IoT Wireless Vibration Sensor samples 3-axis of Vibration and calculates RMS, Maximum, and Minimum vibration readings. This sensor combines these data with temperature data in a data packet, and transmits the result to modems and gateways within wireless range. Once transmission is complete, the vibration sensor goes back to sleep, thus minimizing power consumption.
- Calculates RMS, MAX, and MIN g Vibration
- Noise Removal using Low-pass Filter
- Frequency Range (Bandwidth) up to 1.56Hz ~ 3200Hz In Processed Mode
- Frequency Range (Bandwidth) up to 1.56Hz ~ 6400Hz In Raw Mode
- Sample Rate up to 25,600Hz
- Time Domain Data for FFT analysis
- Encrypted Communication with up to 2 Mile Wireless Range
- Vibration Probe Operating Temperature Range -40 to +125 °C
- Sensor Operating Temperature Range -40 to +60 °C
- Humidity Range 0-90%
- For Indoor and Outdoor Use
- Vibration Sensor with External Probe Option
- Up to 100,000 Transmissions from 6 AA Batteries
Hardware Controls
Power Switch
- Battery Power
- Off
- External Power
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
Default Configuration
Parameters | Default Value |
Destination Address | 00 00 FF FF (HEX) |
Network ID | 7F FF (HEX) |
Node ID | 0 |
Delay | 600 (DEC) seconds |
Power | +24 dBm |
Retries | 10 |
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
- nodeID
- firmware
- battery
- battery_percent
- counter
- sensor_type
- sensor_data
- sensor_name
- type
- addr
- received
- original
- modem_mac
"topic": "sensor_data",
"payload": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"battery_percent": "98.56",
"counter": 26,
"sensor_type": 80,
"sensor_data": {
"mode":0,
"odr":"12800Hz",
"temperature":23.67,
"x_rms_ACC_G":0.13,
"x_max_ACC_G":0.13,
"x_velocity_mm_sec":0.01,
"x_displacement_mm":0,
"x_peak_one_Hz":99.22,
"x_peak_two_Hz":225.99,
"x_peak_three_Hz":122.34,
"y_rms_ACC_G":0.042,
"y_max_ACC_G":0.012,
"y_velocity_mm_sec":0.03,
"y_displacement_mm":0,
"y_peak_one_Hz":3675,
"y_peak_two_Hz":4575,
"y_peak_three_Hz":1075,
"z_rms_ACC_G":0.042,
"z_max_ACC_G":0.012,
"z_velocity_mm_sec":0.03,
"z_displacement_mm":0,
"z_peak_one_Hz":3675,
"z_peak_two_Hz":4575,
"z_peak_three_Hz":1075,
"x_displacement_mm_sec":0.95
"sensor_name": "One Channel Vibration Plus",
"type": "sensor_data",
"received": 1721424191583,
"original": {...},
"time": 1721424191584,
"_msgid": "d7f3341ef39225df"
- mode
- The sensor works in one of 3 modes:
- 0 – Processed – FFT is performed by the sensor and the measurement data is presented in condensed form (both time and frequency parameters)
- 1 – RAW – the raw time domain data is gathered and transmitted and it is up to the client to perform the FFT if needed. This is a very large data packet.
- 2 – on demand, sending Processed data regularly, with the option to request a RAW data packet
- odr
- This is the Vibration sample rate in Hz
- “temperature
- The temperature measured by the temperature sensor
- x_rms_ACC_G
- The RMS Acceleration over the X axis in G
- x_max_ACC_G
- The MAX Acceleration over the X axis in G
- x_velocity_mm_sec
- The Velocity over the X axis in mm/sec
- x_displacement_mm
- The Displacement over the X axis in mm
- x_peak_one_Hz
- The frequency at which the First Highest Energy/ Amplitude Peak occurs in Hz, over the X axis
- x_peak_two_Hz
- The frequency at which the Second Highest Energy/ Amplitude Peak occurs in Hz, over the X axis
- x_peak_three_Hz
- The frequency at which the Third Highest Energy/ Amplitude Peak occurs in Hz, over the X axis
- y_rms_ACC_G
- The RMS Acceleration over the Y axis in G
- y_max_ACC_G
- The MAX Acceleration over the Y axis in G
- y_velocity_mm_sec
- The Velocity over the Y axis in mm/sec
- y_displacement_mm
- The Displacement over the Y axis in mm
- y_peak_one_Hz
- The frequency at which the First Highest Energy/ Amplitude Peak occurs in Hz, over the Y axis
- y_peak_two_Hz
- The frequency at which the Second Highest Energy/ Amplitude Peak occurs in Hz, over the Y axis
- y_peak_three_Hz
- The frequency at which the Third Highest Energy/ Amplitude Peak occurs in Hz, over the Y axis
- z_rms_ACC_G
- The RMS Acceleration over the Z axis in G
- z_max_ACC_G
- The MAX Acceleration over the Z axis in G
- z_velocity_mm_sec
- The Velocity over the Z axis in mm/sec
- z_displacement_mm
- The Displacement over the Z axis in mm
- z_peak_one_Hz
- The frequency at which the First Highest Energy/ Amplitude Peak occurs in Hz, over the Z axis
- z_peak_two_Hz
- The frequency at which the Second Highest Energy/ Amplitude Peak occurs in Hz, over the Z axis
- z_peak_three_Hz
- The frequency at which the Third Highest Energy/ Amplitude Peak occurs in Hz, over the Z axis
Wireless Gateway RUN Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
- Timestamp of the message
"topic": "sensor_mode",
"payload": {
"type": 80,
"nodeId": 0,
"mode": "RUN",
"lastHeard": 1721424191056
"time": 1721424191056,
"_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 80,
"nodeId": 0,
"mode": "PGM",
"lastHeard": 1721424000999
"time": 1721424000999,
"_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 80,
"nodeId": 0,
"mode": "ACK",
"lastHeard": 1721424002052
"time": 1721424002052,
"_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 80,
"nodeId": 0,
"mode": "PUM",
"lastHeard": 1721424000789
"time": 1721424000789,
"_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 80,
"nodeId": 0,
"mode": "FLY",
"lastHeard": 1721424191766
"time": 1721424191767,
"_msgid": "5f6f01b6651b2f82"
- topic
- payload
- time
"topic": "modem_mac",
"time": 1721424259706,
"_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
- Name
- Serial Device*
- Serial Device Edit Icon
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
- topic
- data
- data.nodeID
- data.firmware
- data.battery
- data.battery_percentage
- data.counter
- data.sensor_type
- data.sensor_data
- data.sensor_name
- data.type
- data.addr
- data.received
- data.original
- data.modem_mac
- payload
- time
"data": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"counter": 26,
"sensor_type": 80,
"sensor_data": {
"mode":0,
"odr":"12800Hz",
"x_rms_ACC_G":0.13,
"x_max_ACC_G":0.13,
"original": {...},
"payload": {
"mode":0,
"odr":"12800Hz",
"x_rms_ACC_G":0.13,
"x_max_ACC_G":0.13,
"_msgid": "48e99332fc104565"
- mode
- odr
- “temperature
- x_rms_ACC_G
- x_max_ACC_G
- x_velocity_mm_sec
- x_displacement_mm
- x_peak_one_Hz
- x_peak_two_Hz
- x_peak_three_Hz
- y_rms_ACC_G
- y_max_ACC_G
- y_velocity_mm_sec
- y_displacement_mm
- y_peak_one_Hz
- y_peak_two_Hz
- y_peak_three_Hz
- z_rms_ACC_G
- z_max_ACC_G
- z_velocity_mm_sec
- z_displacement_mm
- z_peak_one_Hz
- z_peak_two_Hz
- z_peak_three_Hz
- topic
- payload
- payload.x
- time
- addr
"topic": "Config Results",
"payload": {
"sent": [...]
"sent": [...]
"sent": [...]
"network_id": true,
"reboot_sensor": {
"sent": [...]
"time": 1721424010563,
"_msgid": "c29c7695c93ae747"
- topic
- time
"payload": {
"config_enter_otn_mode": true
"time": 1721424530709,
"_msgid": "1014b31e53e5c7ac"
- Name
- Arbitrary name of this node
- Serial Device*
- Serial Device for Config
- Mac Address
- Sensor Type*
- Auto Config
- OTF Config
General Sensor Configurations
- Wait for Network Formation
- Destination Address
- Network ID
- Node ID and Delay
- Node ID
- Delay
- Node ID
- Power
- Retries
Mode
Select the mode of operation:
- Processed – only processed data is sent, as in the example in this document
- Raw – full time domain data is sent (very large not recommended for prolonged periods)
- Processed + Raw on demand – same as the first mode, but with the option to generate a Raw packet on demand
Output Data Rate (ODR)
The data rate of the output signal. This would determine how many samples the output data has, which is directly related to the highest frequency components that can be measured. In accordance with the Nyquist equation:
f_max = ODR/2.56 Hz
Serial Connection
- Name
- Modem Type
- Serial Port
- Baud Rate
- Network ID
- The default value is 7FFF
TCP Socket Connection
- Name
- Modem Type
- TCP Port
- IP Address
- Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
- Factory Reset the Sensor
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
- Import
- Expand Type 80 – One Channel Vibration Plus
- Click on Import
Example Flows
