During Power-Up, this vibration sensor learns “normal” base-line vibration from the monitored device. This base-line vibration is subtracted from regular sampled vibration readings to improve relevant vibration data. Ideally, the monitored device should be off while the sensor is learning. Once the sensor stabilizes and starts sending data, the device/machinery being monitored can be powered on.
This Industrial IoT Wireless Vibration Sensor samples 3-axis of Vibration data and calculates RMS, Maximum, and Minimum vibration readings. This sensor combines these data with temperature data in a data packet, and transmits the result to modems and gateways within wireless range. Once transmission is complete, the vibration sensor goes back to sleep, thus minimizing power consumption.
- Calculates RMS, MAX, and MIN g Vibration
- Noise Removal using Low-pass Filter
- Frequency Range (Bandwidth) up to 1.56Hz ~ 3200Hz In Processed Mode
- Frequency Range (Bandwidth) up to 1.56Hz ~ 6400Hz In Raw Mode
- Sample Rate up to 25,600Hz
- Time Domain Data for FFT analysis
- Encrypted Communication with up to 2 Mile Wireless Range
- Humidity Range 0-90%
- For Indoor and Outdoor Use
- Vibration Sensor with External Probe Option
- Up to 100,000 Transmissions from 6 AA Batteries
| Width | 3.54" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
| X Vibration Range | -64g | +64g | ||
| Y Vibration Range | -64g | +64g | ||
| Z Vibration Range | -64g | +64g | ||
| X Velocity Range | 0 | 655 mm/s | ||
| Y Velocity Range | 0 | 655 mm/s | ||
| Z Velocity Range | 0 | 655 mm/s | ||
| X Displacement Range | 0 | 655 mm/s | ||
| Y Displacement Range | 0 | 655 mm/s | ||
| Sample Rate | 100hz | 1600hz | 12.8Khz | Vibration Sensor Data Rate |
| Frequency Range ( Processed Mode) | 1.56hz | 400hz | 3200hz | Freq range should be equal or greater than machine RPM |
| Frequency Range ( Time Domain Mode) | 0.56hz | 800hz | 8,000hz | |
| Sample Duration | 1sec | 1sec | 10sec | Device will take readings for the set time and then send over wireless |
RF Module Specifications
Probes Specifications
The probe is made of steel. It contain the Vibration sensor and the temperature Sensor. It comes with 3 mounting option such as 1/4 NPT, 1/4-28 UNF and magnetic Mount. The sensor cable length is 2 meter and its shielded twisted pair wire cable.Â
Probe Configuration and Wiring​
- External power supply (6-18 VDC) Current Requirement 250 mA
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
Head to the NCD store if you want to purchase the Industrial IoT Wireless Vibration Temperature Sensor V3.
