During Power-Up, this vibration sensor learns “normal” base-line vibration from the monitored device. This base-line vibration is subtracted from regular sampled vibration readings to improve relevant vibration data. Ideally, the monitored device should be off while the sensor is learning. Once the sensor stabilizes and starts sending data, the device/machinery being monitored can be powered on.
This Industrial IoT Wireless Vibration Sensor samples 3-axis of Vibration data and calculates RMS, Maximum, and Minimum vibration readings. This sensor combines these data with temperature data in a data packet, and transmits the result to modems and gateways within wireless range. Once transmission is complete, the vibration sensor goes back to sleep, thus minimizing power consumption.
- Calculates RMS, MAX, and MIN g Vibration
- Noise Removal using Low-pass Filter
- Frequency Range (Bandwidth) up to 1.56Hz ~ 3200Hz In Processed Mode
- Frequency Range (Bandwidth) up to 1.56Hz ~ 6400Hz In Raw Mode
- Sample Rate up to 25,600Hz
- Time Domain Data for FFT analysis
- Encrypted Communication with up to 2 Mile Wireless Range
- Humidity Range 0-90%
- For Indoor and Outdoor Use
- Vibration Sensor with External Probe Option
- Up to 100,000 Transmissions from 6 AA Batteries
Wireless Technology
- Long range – up to 1000 feet in urban environments and 2 miles+ in open areas with the included antennas
Battery Life
The Truth About Battery Life
Applications & Use-cases
This sensor is designed to monitor vibration, frequency, and temperature in industrial environments. It provides valuable data that can be used for predictive maintenance, equipment monitoring, and overall operational efficiency.
Vibration Plus Applications
Advanced Predictive Maintenance for Rotating Equipment
The sensor can be strategically integrated into the maintenance programs for critical rotating machinery, including motors, pumps, compressors, and turbines. By continuously monitoring vibration, frequency, and temperature data, the sensor provides insights into the health of the equipment, detecting early signs of issues such as misalignment, imbalance, or bearing wear. This data-driven approach enables the scheduling of maintenance activities before the equipment fails, reducing unexpected downtime, minimizing repair costs, and extending the operational lifespan of machinery.
Comprehensive Structural Health Monitoring
The sensor can be deployed on infrastructure like bridges, buildings, towers, and dams to detect abnormal vibrations that may signal structural deficiencies or damage. For example, in a bridge, the sensor can track changes in vibration patterns caused by material fatigue, loose joints, or foundation shifts. With continuous monitoring, it is possible to identify and address potential risks well before they escalate into safety hazards, ensuring the long-term integrity and reliability of critical infrastructure.
Process Automation and Quality Control in Manufacturing
In manufacturing environments, the sensor can be installed on key equipment such as conveyors, CNC machines, or robotic arms. By monitoring vibration data in real-time, the sensor can detect when machinery is operating outside its optimal conditions, which may indicate tool wear, imbalance, or other mechanical issues. Integrating this data with a manufacturing execution system (MES) allows for automatic adjustments, immediate alerts, or even shutdowns to prevent defects in products, enhance process efficiency, and maintain consistent product quality.
Optimization of Energy Efficiency in Industrial Systems
The sensor can be applied to monitor vibration levels in energy-intensive equipment such as HVAC systems, large fans, generators, and industrial chillers. Abnormal vibration often correlates with inefficiencies like misalignment, unbalanced loads, or mechanical wear, leading to increased energy consumption and operational costs. By detecting these issues early, the sensor supports proactive maintenance that reduces energy waste, improves the performance of systems, and contributes to the overall sustainability goals of the organization.
Vibration Plus Use-cases
Proactive Wind Turbine Monitoring
Installed on the main shaft or gearbox of wind turbines, the sensor continuously monitors vibration levels to detect anomalies such as misalignment, gear tooth wear, or bearing degradation. Abnormal vibrations can trigger alerts for maintenance teams, allowing them to address issues before they lead to significant failures. This proactive approach not only minimizes turbine downtime but also helps in optimizing energy production, ensuring the reliability and profitability of the wind farm.
Railway Track Condition Assessment
The sensor is mounted on railway tracks to monitor vibrations caused by passing trains. Analyzing this data can reveal early signs of rail wear, track misalignment, or loose fastenings, which are critical for ensuring safe and efficient train operations. By enabling real-time condition monitoring, the sensor helps maintenance teams prioritize repairs, reducing the risk of accidents, service disruptions, and costly track replacements, ultimately enhancing the safety and reliability of the railway network.
Industrial Fan and Blower Performance Monitoring
In a large-scale industrial facility, the sensor is used to monitor the vibration of high-capacity fans, blowers, and ventilation systems. By detecting early indicators of imbalance, misalignment, or bearing failure, the sensor allows maintenance teams to intervene before minor issues escalate into major problems. Ensuring the optimal performance of these systems is crucial for maintaining air quality, temperature control, and overall operational efficiency in the facility, preventing costly downtime and ensuring regulatory compliance.
Conveyer Belt Monitoring
Industrial conveyer belt installation especially those of large size like for example at dig sites have multiple rotational components that are under a heavy load. Stress to these installation is high and so are vibrational levels. It is essential they are monitored in real time, as a fault could be very dangerous. Furthermore as these are often off-site from cities, it is difficult to perform maintenance if it is unexpected. Monitoring vibrations in real time for example at crucial bearings along the line or at the driver/gear box at multiple points could give insights on potential issues before they occur. This would essentially enable the implementation of a solid predictive maintenances strategy and increase reliability and operational efficiency (by reducing downtime).
