Industrial IoT Wireless Vibration Temperature Sensor V3 API Overview
During Power-Up, this vibration sensor learns “normal” base-line vibration from the monitored device.  This base-line vibration is subtracted from regular sampled vibration readings to improve relevant vibration data.  Ideally, the monitored device should be off while the sensor is learning.  Once the sensor stabilizes and starts sending data, the device/machinery being monitored can be powered on.
This Industrial IoT Wireless Vibration Sensor samples 3-axis of Vibration data and calculates RMS, Maximum, and Minimum vibration readings. This sensor combines these data with temperature data in a data packet, and transmits the result to modems and gateways within wireless range.  Once transmission is complete, the vibration sensor goes back to sleep, thus minimizing power consumption.
  • Industrial Grade 3-axis Vibration Sensor with ±16g Range
  • Calculates RMS, MAX, and MIN g Vibration
  • Noise Removal using Low-pass Filter
  • Frequency Range (Bandwidth) up to 1.56Hz ~ 3200Hz In Processed Mode
  • Frequency Range (Bandwidth) up to 1.56Hz ~ 6400Hz In Raw Mode
  • Sample Rate up to 25,600Hz
  • Time Domain Data for FFT analysis
  • Encrypted Communication with up to 2 Mile Wireless Range
  • Operating Temperature Range -40 to +60 °C
  • Humidity Range 0-90%
  • For Indoor and Outdoor Use
  • Vibration Sensor with External Probe Option
  • Up to 100,000 Transmissions from 6 AA Batteries
Frame Structure
Figure 3: Communication Procedure - Power Up
Mode TypePAN ID set by Sensor (ASCII)Frame fieldOffset (Payload section)Value
RunID save by user / DefaultMode bytes70x52
80x55
90x4E
Configuration7BCDMode bytes70x50
80x47
90x4D
Factory Reset7FFFMode bytes70x50
80x55
90x4D
Run Mode Power Up Frame
FieldNumber of bytesDescription
7E 00 1C 90 00 13 A1 00 41 58 1C CB FF FE 00 7A 01 00 00 01 00 00 52 55 4E 00 00 00 00 00 00 0BExample frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type (Power Up)
0x0013A1004158C1CB8Source Address
0xFFFE2Reserved
0x001R. Option
0x7A1Header with Power Up value
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x52554E3Mode Byte for Run Mode
0x0000000000006Reserved
0x0B1Checksum
7E 00 1C 90 00 13 A1 00 41 58 1C CB FF FE 00 7A 01 00 00 01 00 00 50 47 4D 00 00 00 00 00 00 1CExample frame
0x7E1Delimiter
0x001C2Length
0xFFFE2Reserved
0x001R. Option
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x50474D3Mode Byte for Configuration Mode
0x0E1Checksum
0x7E1Delimiter
0x001C2Length
0xFFFE2Reserved
0x001R. Option
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x0E1Checksum
Sensor Data Frame
Figure 4: Communication Procedure - Run Mode
As this sensor has two possible frame structures for the Processed and RAW mode, we are detailing each one below:
Processed Data Frame
Field Value ( or Default )PayloadLengthDescription
Header7F1API Data Header ( its not the API Header)
Node ID001User Defined ID
Firmware Version011Device Firmware Version
Battery Level03,FE2Battery Voltage = 0.00322*(03*FF+FE)
Packet CounterDE1Wireless Transmission Counter
Sensor Type00,0x512Sensor Type 80
Error/Reserve Byte001bit 0: OTF Ready (Ignored in this app as we do not depend on the common code for OTF)
bit 1: (Validity of Data for sensor 1 , 0 means data is valid, 1 means error in accessing sensor)
bit 2: (Validity of Data for sensor 2 , 0 means data is valid, 1 means error in accessing sensor)
bit 3: Sensor 2 indicator bit (only in dual probe) , if this bit is set it means the packet has data for sensor 2.
In Raw mode/Raw on Rqst, this bit is set only when raw data is coming from sensor 2, if not , then it is coming from sensor 1
In Processed mode, this bit is set to indicate that the packet includes data from sensor 1 and 2
bit 4 - 7 : Unused
Mode Of Operation 000100- Processed
01- Raw
02 - On Demand
Data Rate0A11Vibration Sample Rate
Temperature MSB,LSB2,32Temp in C = (MSB*FF+LSB)/100
RMS ACC in X Axis in mgMSB,LSB4,52rms_acc_x_mg = MSB*FF+LSB
MAX ACC in X Axis in mgMSB,LSB6,72max_acc_x_mg = MSB*FF+LSB
RMS Velocity in X Axis in mm/secMSB,LSB8,92rms_vel_x_mm_sec = (MSB*FF+LSB)/100
RMS Displacement in X Axis in mmMSB,LSB10,112rms_disp_x_mm = (MSB*FF+LSB)/100
Frequency of Highest Peak in X directionMSB,LSB12,132X1_Hz = (MSB*FF+LSB)
Frequency of Second Highest Peak in X directionMSB,LSB14,152X2_Hz = (MSB*FF+LSB)
Frequency of Third Highest Peak in X directionMSB,LSB16,172X3_Hz = (MSB*FF+LSB)
RMS ACC in Y Axis in mgMSB,LSB18,192rms_acc_y_mg = MSB*FF+LSB
MAX ACC in Y Axis in mgMSB,LSB20,212max_acc_y_mg = MSB*FF+LSB
RMS Velocity in Y Axis in mm/secMSB,LSB22,232rms_vel_y_mm_sec = (MSB*FF+LSB)/100
RMS Displacement in Y Axis in mmMSB,LSB24,252rms_disp_y_mm = (MSB*FF+LSB)/100
Frequency of Highest Peak in Y directionMSB,LSB26,272Y1_Hz = (MSB*FF+LSB)
Frequency of Second Highest Peak in Y directionMSB,LSB28,292Y2_Hz = (MSB*FF+LSB)
Frequency of Third Highest Peak in Y directionMSB,LSB30,312Y3_Hz = (MSB*FF+LSB)
RMS ACC in Z Axis in mgMSB,LSB32,332rms_acc_z_mg = MSB*FF+LSB
MAX ACC in Z Axis in mgMSB,LSB34,352max_acc_z_mg = MSB*FF+LSB
RMS Velocity in Z Axis in mm/secMSB,LSB36,372rms_vel_z_mm_sec = (MSB*FF+LSB)/100
RMS Displacement in Z Axis in mmMSB,LSB38,392rms_disp_z_mm = (MSB*FF+LSB)/100
Frequency of Highest Peak in Z directionMSB,LSB40,412Z1_Hz = (MSB*FF+LSB)
Frequency of Second Highest Peak in Z directionMSB,LSB42,432Z2_Hz = (MSB*FF+LSB)
Frequency of Third Highest Peak in Z directionMSB,LSB44,452Z3_Hz = (MSB*FF+LSB)
RAW Data Frame
Field Description Comment
Header7FAPI Data Header ( its not the API Header)
Node ID00User Defined ID
Firmware Version01Device Firmware Version
Battery Level03,FEBattery Voltage = 0.00322*(03*FF+FE)
Packet CounterDEWireless Transmission Counter
Sensor Type00,0x51Sensor Type 80
01Mode Of Operation
0AODR
07Three MSB bit of the Axis byte to indicate FSR And 3 LSB bits indicates Axis
13Hour
0BMinute
00,00Device Temperature
77Total Number of RF Packets
01Current Packet Count value
01 DEX1-Axis RAW ACC DataX1= (01*0xFF+ 0xDE)*FSR coefficient
01 7AY1-Axis RAW ACC DataY1= (01*0xFF+ 0x7A)*FSR coefficient
3F 8BZ1-Axis RAW ACC DataZ1= (3F*0xFF+ 0x8B)*FSR coefficient
Configuration Mode Frame
Figure 5: Communication Procedure - Configuration Mode
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
Read Sensor Network ID
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
Read Sensor Destination Address​
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Set Sensor Destination to Broadcast ​
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Read Wireless Sensor Retries​
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep.  But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data.  If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep.  The Machine Uptime sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Set Wireless Sensor number of Retries ​
Complete Payload
F7 06 00 00 00 05
Complete Payload
5. In case you still can’t solve your issue head to our Community forum to get real time help from the NCD community of experts: https://community.ncd.io/
Appendix
Configuration Commands
1Set Broadcast Transmission 0XF70x01-0000FFFFThis will set the address to Broadcast mode. All the receiver with same ENY key and PAN ID will get the data packets
7Read Sleep Interval0XF70x15-0x00,0x02,0x58Reads the stored Sleep Interval value from the sensor
8Read Power0XF70x16-0x04Reads the stored RF Power value from the sensor
9Read Retries0XF70x17-0x0AReads the stored Retries value from the sensor
10Read Destination Address0XF70x18-00,00,FF,FFReads the stored Destination value from the sensor
11Read PAN ID aka Network ID0XF70x19-0x7FFFReads the PAN ID aka Network ID
12Enable Encryption 0XF20x01-0x01Enables the Encryption of the Frame Transmitted from the Sensor
13Disable Encryption 0XF20x02--Disables the Encryption of the Frame Transmitted from the Sensor
Command Acknowledgement Data
No.CommandData bytesReserved bytesDataCalculation (if any)
1Set Broadcast Transmission 180xFF (OK)
2Set ID and Sleep Interval180xFF (OK)
3Set Destination Address180xFF (OK)
4Set Power180xFF (OK)
5Set PAN ID aka Network ID180xFF (OK)
6Set Retries 180xFF (OK)
7Read Sleep Interval36D0 MSB, D1, D2 LSBDelay = (D0 x 65536) + (D1 x 256) + D2
8Read Power18PowerDEC value
9Read Retries18RetriesDEC value
10Read Destination Address45A0 MSB, A1, A2, A3
11Read PAN ID aka Network ID27ID0 MSB, ID1
12Enable Encryption 180xFF (OK)
13Disable Encryption 180xFF (OK)
14Set Encryption Key180xFF (OK)
Application Specific Commands
No.CommandSub CommandCommand CodeArgument
Set Output Data RateF44F0x00100sps (Range 1.56 – 25 Hz) 0x07
200sps (Range 3.125 – 50 Hz) 0x08
400sps (Range 6.25 – 100 Hz) 0x09
800sps (Range 12.5 – 200 Hz) 0x0A
1600sps (Range 25 – 400 Hz) 0x0B
3200sps (Range 50 – 800 Hz) 0x0C
6400sps (Range 100 – 1600 Hz) 0x0D
12800sps (Range 200 – 3200 Hz) 0x0E
25600sps (Range 400 – 6400 Hz) 0x0F
NOTE: These are based on Default Filter Setting. LOW and HIGH PASS Filters Can be used to Change These Ranges
Get Output Data RateF44F0x01100sps (Range 1.56 – 25 Hz) 0x07
Set Sampling DurationF44F0x02Period of samples in seconds
must be > 0
Sample duration value is multiple of 50mS i.e. setting sample duration to 1 will set the duration time to 50mSec, setting duration to 2 will set sample duration time to 100msec and so on
Get Sampling DurationF44F0x03
Set Axes EnableF44F0x04Bit 0 ---> X-axis
Bit 1 ---> Y-axis
Bit 2 ---> Z-axis
Bit Set – Axis enabled
Bit Cleared – Axis disabled
Get Axes EnableF44F0x05
Set Sampling IntervalF44F0x06Every 5 minutes 0x0
Every 10 minutes 0x01
Every 15 minutes 0x02
Every 20 minutes 0x03
Every 30 minutes 0x04
Every 60 minutes 0x05
Every 120 minutes 0x06
Get Sampling IntervalF44F0x07
Set RTCF44F0x08Byte 1 : Hours
Byte 2 : Minutes
Byte 3 : Seconds
Set Operation ModeF44F0x090x00 -- Processed Mode
0x01 -- Raw mode
0x02 -- Processed +Raw on Request
Get Operation ModeF44F0x0A
Set Full-scale RangeF44F0x0B+/- 2g 0x00
+/- 4g 0x01
+/- 8g 0x02
+/- 16g 0x03
Get Full-scale RangeF44F0x0C+/- 2g 0x00
+/- 4g 0x01
+/- 8g 0x02
+/- 16g 0x03
Set FiltersF44F0x0D0x01 -- Enable
0x00 -- Disable
Get FiltersF44F0x0E
Set Measurement ModeF44F0x0F0x00 -- Device will send processed data, acc in mg, velocity in mm/sec and displacement in mm
0x01 -- Device will send processed data, acc in ms^2, velocity in inch/sec and displacement in milli
Get Measurement ModeF44F0x10
Set On Request TimeoutF44F0x11Value Range -- 0-20sec. Device will decide how long device will stay awake and wait for raw time domain request from command
Get On Request TimeoutF44F0x12
Set Dead Band Value in mgF44F0x29Value Range -- 0-255mg. default value is 35mg. Sensor will not consider acc values below dead band values as noise
Get Dead Band Value in mgF44F0x29
Extend OTF Configuration TimeF432Extend OTF on time by 30sec
Exit OTF Configuration TimeF433
Set INT Threshold F43C0x08 The sensor will wake up and take samples when vibration goes above this threshold(Set threshold 400mg, Multiple of 50mg)
Get INT Threshold F43D
Set Acceleration Alert Threshold F43E0x08RED Alert Led Will Blink If the RMS acceleration readings go above this threshold(Set threshold 400mg, Multiple of 50mg)
Get Acceleration Alert Threshold F43F
Set Velocity Alert Threshold F4400x0ARED Alert Led Will Blink If the RMS Velocity readings go above this threshold(Set threshold 20mm/sec, Multiple of 2mm/sec)
Get Velocity Alert Threshold F441
Set Alert Mode to Acceleration F4420x00Alert LED will blink if readings go above set Acceleration threshold
Set Alert Mode to Velocity F4430x01Alert LED will blink if readings go above set Velocity threshold
REQUEST Raw Data from One Channel SensorF44F0x13Once Sensor Receives This command it will Send RAW data to Requester
Low Pass FilterF43400Set this value to set LPF cut off freq. The range of this parameter is 0-9.
If its set to 0, it will set the LPF freq to ODR/4
set to 1 LPF freq = ODR/8
set to 2 LPF freq = ODR/16
set to 9 LPF freq = ODR/2048
High Pass FilterF43600Set this value to set HPF cut off freq. The range of this parameter is 0-9.
If its set to 0, it will set the HPF freq to ODR/4
set to 1 HPF freq = ODR/8
set to 2 HPF freq = ODR/16
set to 9 HPF freq = ODR/2048
Error Code Descriptions
Error NumberDescription
0x01Invalid command
0x02Sensor Type mismatch
0x03Node ID mismatch
0x04Apply change command failed during X-bee parameter update
0x05Invalid API packet command response received after Apply change command
0x06Write command failed during X-bee parameter update
0x07Invalid API packet command response received after Write command
0x08Parameter change command failed during X-bee parameter update
0x09Invalid Parameter change command response packet received after Write command
0x0AInvalid/Incomplete packet received
0x0FInvalid parameter for setup/saving
Calculation for transmission
					0x04
					0xFF-0x04=0xFB
Calculation for reception
1.     Not including the frame delimiter and length, add all the bytes including the received checksum
2.     Keep only the last 8 bits
3.      If the result is 0xFF, the checksum is correct and the packet can be processed.
Consider the example for the command Set Broadcast shown in APPENDIX A and see that the received packet checksum verifies since the result is 0xFF.
					0xFF
