Industrial IoT Wireless Particulate Matter Sensor API Overview
Introducing NCD’s Long Range Industrial IoT Wireless Particulate Matter Sensor for Air Quality Monitoring, featuring temperature and humidity sensors with a 2-mile wireless range. It uses SPS30 and SHT30 sensors to transmit accurate particle size, mass concentration, temperature, and humidity data at user-defined intervals.
PM2.5 and PM10 particles are small pollutants dangerous to human health, linked to conditions like asthma and cardiovascular disease. The sensor measures PM1.0, PM2.5, PM4.0, and PM10.0, cleaning itself every 256 transmissions via an internal fan.
Laser scattering technology ensures accurate particle measurements over an eight-year lifetime.
The temperature sensor operates between -25°C and 85°C, while the humidity sensor handles up to 100% RH. Powered by 6 AA batteries, it lasts up to 5 years, with optional external power.
With an open communication protocol, this sensor integrates with various systems like PCs, Raspberry Pi, Microsoft Azure, AWS, and MQTT servers. Configurable transmission settings make it versatile for diverse applications.
Its long range, accuracy, affordability, and battery life make it ideal for industrial and consumer markets.
Feature
  • Industrial Grade Sensor Mass Concentration Range 0-1000 μg/m^3
  • Mass Concentration Resolution of 1 μg/m^3
  • Mass Concentration Size Range PM1.0, PM2.5, PM4.0, PM10.0
  • Number Concentration Range 0 to 3000 1/cm^3
  • Number Concentration Size Range  PM0.5, PM1.0, PM2.5, PM4.0, PM10.0
  • Unique Long-Term Stability of up to 8 Years
  • Laser-Based Scattering Principle and Advanced Algorithms
  • Inbuilt Auto Cleaning Feature  After Every 256 Transmissions
  • Industrial Grade Sensor with 0 to 100% RH / -25°C [-13°F] to 85°C [185°F])
  • Resolution 0.04% RH/0.025°C Accuracy 2% RH/ 0.3°C
  • Includes Battery Level with Every Transmission
  • Encrypted Wireless Communications up to 2 Mile Range
Frame Structure
Figure 3: Communication Procedure - Power Up
Mode TypePAN ID set by Sensor (ASCII)Frame fieldOffset (Payload section)Value
RunID save by user / DefaultMode bytes70x52
80x55
90x4E
Configuration7BCDMode bytes70x50
80x47
90x4D
Factory Reset7FFFMode bytes70x50
80x55
90x4D
Run Mode Power Up Frame
FieldNumber of bytesDescription
7E 00 1C 90 00 13 A1 00 41 58 1C CB FF FE 00 7A 01 00 00 01 00 00 52 55 4E 00 00 00 00 00 00 0BExample frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type (Power Up)
0x0013A1004158C1CB8Source Address
0xFFFE2Reserved
0x001R. Option
0x7A1Header with Power Up value
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x52554E3Mode Byte for Run Mode
0x0000000000006Reserved
0x0B1Checksum
7E 00 1C 90 00 13 A1 00 41 58 1C CB FF FE 00 7A 01 00 00 01 00 00 50 47 4D 00 00 00 00 00 00 1CExample frame
0x7E1Delimiter
0x001C2Length
0xFFFE2Reserved
0x001R. Option
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x50474D3Mode Byte for Configuration Mode
0x0E1Checksum
0x7E1Delimiter
0x001C2Length
0xFFFE2Reserved
0x001R. Option
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x0E1Checksum
Sensor Data Frame
Figure 4: Communication Procedure - Run Mode
Data Payload
Field Offset (Payload Section)Value ( or Default )LengthDescription
Header07F1Header to differentiate various type of packets
Node ID1001User Defined ID
Firmware Version2011Device Firmware Version
Battery LevelMSB 3, LSB 4-2Sampled battery voltage of the device.
Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V
Packet Counter5-1It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets.
Sensor TypeMSB 6, MSB 7 00, 0x202Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end
Error/Reserve Byte8001error code = 1 ( data was not ready)
Mass Concentration PM1.0 [µg/m³]MSB 9/ Data[0], 10/ Data[1], 11/ Data[2], LSB 12/ Data[3]-4Mass Concentration PM1.0 [µg/m³]
PM1.0(usigned) = (((Data[0]<<24)+(Data[1]<<16)+(Data[2]<<8)+Data[3])/100.0)
Mass Concentration PM2.5 [µg/m³]MSB 13/ Data[4], 14/ Data[5], 15/ Data[6], LSB 16/ Data[7] -4Mass Concentration PM2.5 [µg/m³]
PM2.5(usigned) = (((Data[4]<<24)+(Data[5]<<16)+(Data[6]<<8)+Data[7])/100.0)
Mass Concentration PM4.0 [µg/m³]MSB 17/ Data[8], 18/ Data[9], 19/ Data[10], LSB 20/ Data[11]-4Mass Concentration PM4.0 [µg/m³]
PM4.0(usigned) = (((Data[8]<<24)+(Data[9]<<16)+(Data[10]<<8)+Data[11])/100.0)
Mass Concentration PM10.0 [µg/m³]MSB 21/ Data[12], 22/ Data[13], 23/ Data[14], LSB 24/ Data[15] -4Mass Concentration PM10.0 [µg/m³]
PM10.0(usigned) = (((Data[12]<<24)+(Data[13]<<16)+(Data[14]<<8)+Data[15])/100.0)
Number Concentration PM0.5 [#/cm³]MSB 25/ Data[16], 26/ Data[17], 27/ Data[18], LSB 28/ Data[19]-4Number Concentration PM0.5 [#/cm³]
PM0.5(usigned) = (((Data[16]<<24)+(Data[17]<<16)+(Data[18]<<8)+Data[19])/100.0)
Number Concentration PM1.0 [#/cm³]MSB 29/ Data[20], 30/ Data[21], 31/ Data[22], LSB 32/ Data[23] -4Number Concentration PM1.0 [#/cm³]
PM1.0(usigned) = (((Data[20]<<24)+(Data[21]<<16)+(Data[22]<<8)+Data[23])/100.0)
Number Concentration PM2.5 [#/cm³]MSB 33/ Data[24], 34/ Data[25], 35/ Data[26], LSB 36/ Data[27]-4Number Concentration PM2.5 [#/cm³]
PM2.5(usigned) = (((Data[24]<<24)+(Data[25]<<16)+(Data[26]<<8)+Data[27])/100.0)
Number Concentration PM4.0 [#/cm³]MSB 37/ Data[28], 38/ Data[29], 39/ Data[30], LSB 40/ Data[31]-4Number Concentration PM4.0 [#/cm³]
PM4.0(usigned) = (((Data[28]<<24)+(Data[29]<<16)+(Data[30]<<8)+Data[31])/100.0)
Number Concentration PM10.0 [#/cm³]MSB 41/ Data[32], 42/ Data[33], 43/ Data[34], LSB 44/ Data[35]-4Number Concentration PM10.0 [#/cm³]
PM10.0(usigned) = (((Data[32]<<24)+(Data[33]<<16)+(Data[34]<<8)+Data[35])/100.0)
Typical Particle Size [µm]MSB 45/ Data[36], 46/ Data[37], 47/ Data[38], LSB 48/ Data[39]-4Typical Particle Size [µm]
Typical Particle Size(usigned) = (((Data[36]<<24)+(Data[37]<<16)+(Data[38]<<8)+Data[39])/100.0)
Sensor DataMSB 49/ Data[40], 50/ Data[41]-2Humidity data
Humidity(usigned) = ((data[40] x 256) + data[41])/100
51/ Data[42], LSB 52/ Data[43]-2Temperature data
Temperature(signed) = (((data[42] x 256) + data[43])/100)°C
Configuration Mode Frame
Figure 5: Communication Procedure - Configuration Mode
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
Read Sensor Network ID
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
Read Sensor Destination Address​
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Set Sensor Destination to Broadcast ​
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Read Wireless Sensor Retries​
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep.  But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data.  If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep.  The Machine Uptime sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Set Wireless Sensor number of Retries ​
Complete Payload
F7 06 00 00 00 05
Complete Payload
5. In case you still can’t solve your issue head to our Community forum to get real time help from the NCD community of experts: https://community.ncd.io/
Appendix
Configuration Commands
1Set Broadcast Transmission 0XF70x01-0000FFFFThis will set the address to Broadcast mode. All the receiver with same ENY key and PAN ID will get the data packets
7Read Sleep Interval0XF70x15-0x00,0x02,0x58Reads the stored Sleep Interval value from the sensor
8Read Power0XF70x16-0x04Reads the stored RF Power value from the sensor
9Read Retries0XF70x17-0x0AReads the stored Retries value from the sensor
10Read Destination Address0XF70x18-00,00,FF,FFReads the stored Destination value from the sensor
11Read PAN ID aka Network ID0XF70x19-0x7FFFReads the PAN ID aka Network ID
12Enable Encryption 0XF20x01-0x01Enables the Encryption of the Frame Transmitted from the Sensor
13Disable Encryption 0XF20x02--Disables the Encryption of the Frame Transmitted from the Sensor
Command Acknowledgement Data
No.CommandData bytesReserved bytesDataCalculation (if any)
1Set Broadcast Transmission 180xFF (OK)
2Set ID and Sleep Interval180xFF (OK)
3Set Destination Address180xFF (OK)
4Set Power180xFF (OK)
5Set PAN ID aka Network ID180xFF (OK)
6Set Retries 180xFF (OK)
7Read Sleep Interval36D0 MSB, D1, D2 LSBDelay = (D0 x 65536) + (D1 x 256) + D2
8Read Power18PowerDEC value
9Read Retries18RetriesDEC value
10Read Destination Address45A0 MSB, A1, A2, A3
11Read PAN ID aka Network ID27ID0 MSB, ID1
12Enable Encryption 180xFF (OK)
13Disable Encryption 180xFF (OK)
14Set Encryption Key180xFF (OK)
Application Specific Commands
No.CommandSub CommandCommand CodeArgumentNote
Force Sensor CleanF71A0x00, 0x0000Force the self-cleaning procedure before the 256 transmission counter has expired
Error Code Descriptions
Error NumberDescription
0x01Invalid command
0x02Sensor Type mismatch
0x03Node ID mismatch
0x04Apply change command failed during X-bee parameter update
0x05Invalid API packet command response received after Apply change command
0x06Write command failed during X-bee parameter update
0x07Invalid API packet command response received after Write command
0x08Parameter change command failed during X-bee parameter update
0x09Invalid Parameter change command response packet received after Write command
0x0AInvalid/Incomplete packet received
0x0FInvalid parameter for setup/saving
Calculation for transmission
					0x04
					0xFF-0x04=0xFB
Calculation for reception
1.     Not including the frame delimiter and length, add all the bytes including the received checksum
2.     Keep only the last 8 bits
3.      If the result is 0xFF, the checksum is correct and the packet can be processed.
Consider the example for the command Set Broadcast shown in APPENDIX A and see that the received packet checksum verifies since the result is 0xFF.
					0xFF
