Industrial IoT Wireless High Resolution 4-20mA Receiver Product Manual
  • Industrial Grade 1 Channel 16 bit ADC 4-20mA Reveiver
  • 15 bit 4-20mA Resolution
  • ±0.68uA Absolute Accuracy
  • Factory Default Option using a combination of hardware buttons
  • Power-efficient Built-in Sleep mode
    • Up to 500,000 Transmissions from 4 AA Batteries
  • Improved reliability incorporating Re try to feature in case of packet loss
  • Real time battery status
Introducing NCD’s IoT Industrial IoT Wireless High Resolution 4-20mA Receiver, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture.  It incorporates a 1 channel 16 bit ADC that samples analog inputs at user defined intervals while sleeping during the time it is not sending data to minimize power consumption. It has an additional feature of detecting change in voltage at user defined detection time intervals and sending out ADC samples if the change in voltage on any channel is greater than user defined detection change percentage. This change detection feature can be enabled or disabled by user. To minimize power consumption, it sleeps during the time it is not checking for change in analog voltage. Both of these features work in parallel to support multiple application areas in one package.
Powered by just 4 AA batteries and an operational lifetime of 500,000 wireless transmissions, a 10 years battery life can be expected depending on environmental conditions and the data transmission interval.  Optionally, this sensor may be externally powered.
The range, price, accuracy, battery life and security features of IoT Wireless Analog to Digital Converter makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
Note: This manual is shared with Industrial IoT  Wireless DC Voltage Monitor(0-10V), and IoT Long Range Wireless 0-24VDC Voltage Monitor as well.
M12 Connection (PR55-5) —
Blue    — 4-20mA +Ve
White — External Power Supply +ve
Brown — 4-20mA -Ve
Black — Ground
Gray — 16V Supply ( To power External Sensor)
1    — 4-20mA -Ve
2 — External Power Supply +ve
3 — 4-20mA +Ve
4– Ground
5 — 16V Supply ( To power External Sensor)
M12 Connection (PR55-48)
1 — External Power Supply -ve Input
2 — External Power Supply +ve Input
3 — 4-20mA +Ve
4 — Ground
5 — 16V Supply ( Test Point)
Blue    — 4-20mA +Ve
Brown — External Power Supply -ve
Black — Ground
Gray — 16V Supply ( Test Point)
  • Industrial Sensor monitoring
  • Analog Input To Digital Converter
  • PLC and Automation Application
  • Industrial Automation
wireless analog to digital converter
  • ADC type NCD IoT Wireless Sensor (with power source Battery Or External DC)
  • Zigmo/Router for PC (One Router will work with Multiple Sensors)
  • ·         PC/Laptop with an OS installed or Any IoT Embedded Device
  1. Power-up the Wireless Sensor and make sure its antenna is installed
3.Identify the serial port allocated to it by going into device manager (You can also find the serial port using Digi provided utility XCTU)
4. Install the Alpha Station utility for the sensor you are working with. Run this utility.
5.Press the port configure button and select the PORT you identified in step 3. Select baud rate of 115200 and press OK.
6. Press the Run button to visualize incoming data
One of the issues for unsuccessful communication can be a changed setting at the sensor end due to which the sensor and Zigmo are unable to establish a connection. You can resolve this problem by returning to the factory default settings provided in Table 1. Please refer to Figure 7 and follow steps shown in it for applying factory default settings.
  • Run Mode
  • Configuration Mode
Sensor Type 45 and 48
Wireless 1 Channel 4-20mA Receiver
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2–
Battery VoltageMSB 3–
LSB 4–
Packet Counter5–
Sensor TypeMSB 60x00
MSB 70x2D
Reserved80x00
For future use
Sensor Data9/ Data[0]–
ADC 1 Counts ( Signed 16 bit int)
          ADC Counts = (Data[0] x 256) + Data[1]
10/ Data[1]–
11/ Data[0]–
mA= ((Data[0] x 256) + Data[1])/100.00
12/ Data[1]–
Sensor Type 52
Wireless 2 Channel 4-20mA Receiver
(if any)
Header00x7F
Firmware2–
LSB 4–
Packet Counter5–
MSB 70x34
Reserved80x00
For future use
10/ Data[1]–
11/ Data[0]–
ADC 2 Counts ( Signed 16 bit int)
12/ Data[1]–
Sensor Type 56
Wireless 2 Channel 0-10VDC Receiver
(if any)
Header00x7F
Firmware2–
LSB 4–
Packet Counter5–
MSB 70x38
Reserved80x00
For future use
10/ Data[1]–
11/ Data[0]–
12/ Data[1]–
Sensor Type 75 and 76
Custom Wireless 1 Channel 4-20mA Receiver
The detail for API packet received at PC end can be read from the X-bee manual available from Digi. The detail of the Payload section of the packet is shown in Table 3.
The typical response from the device in Run mode is shown in Figure 13 and Figure 14. The utility shown in Figure 14 can be downloaded from the website.
(if any)
Header00x7F
Node ID to differentiate up to 256 nodes in a network. User configurable values
Firmware2–
LSB 4–
Packet Counter5–
MSB 70x4B
Reserved80x00
For future use
10/ Data[1]–
11/ Data[2]–
mA( Signed 16 bit int) = ((Data[2] x 256) + Data[3])/100
Velocity ( UnSigned 16 bit int) = ((Data[4] x 256) + Data[5])/100
12/ Data[3]
13/ Data[4]
14/ Data[5]–
Sensor Type 89
2 Channel Ultrasound Vibration Sensor
Field Value ( or Default )PayloadLengthDescription
Header7F1API Data Header ( its not the API Header)
Node ID001User Defined ID
Firmware Version011Device Firmware Version
Battery Level03,FE2Battery Voltage = 0.00322*(03*FF+FE)
Packet CounterDE1Wireless Transmission Counter
Sensor Type00,0×592Sensor Type 89
Error/Reserve Byte001
ADC Channel 1 MSB,LSB0,12ADC Channel 1 = (MSB*FF+LSB)
mA Channel 1 MSB,LSB2,32mA Channel 1 = (MSB*FF+LSB)/100
Vibration dB Channel 1 MSB,LSB4,52dB Channel 1 = (MSB*FF+LSB)/100
ADC Channel 2MSB,LSB6,72ADC Channel 2 = (MSB*FF+LSB)
mA Channel 2MSB,LSB8,92mA Channel 2 = (MSB*FF+LSB)/100
Vibration dB Channel 2MSB,LSB10,112dB Channel 2 = (MSB*FF+LSB)/100
ncd.io 4-20mA Labview UI can be used to configure the Sensor. While using this UI select 45 as sensor type on left side.
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0003 F9
Set ID and Delay
Set ID and Delay
<!– [if gte mso 9]>
<![endif]–><!– [if gte mso 9]>
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
<![endif]–>
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:”Table Normal”;
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:””;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin-top:0in;
mso-para-margin-right:0in;
mso-para-margin-bottom:8.0pt;
mso-para-margin-left:0in;
line-height:107%;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:”Calibri”,sans-serif;
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:”Times New Roman”;
mso-bidi-theme-font:minor-bidi;}
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0003 0000 0004 F4
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0003 1234 5678 E3
Set Power
set-power
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0003 02F4
Set PANID
Command For COPY  7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0003 7CDE 9B
set retries 1
Set PANID
set retries
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0003 03F1
readdelay1-new
readdelay new
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0003 E5
getpower1 new
getpower new
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0003 E4
getretries1 new
getretries new
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0003 E3
getdestadd1 new
getdestadd new
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0003 E2
getpanid1 new
getpanid new
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0003 E1
encenable1 new
encenable new
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0003 FE
encdisable1 new
encdisable.-newpng
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0003 FD
Set Encryption Key
setkey new
Command For COPY: 7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0003 0011 2211 2211 2211 2233 4433 4433 4433 4454
set-change1
set-change
Command For COPY: 7E00 1810 0000 0000 0000 00FF FFFF FE00 00F7 0700 0003 0014 0000 0AD5
read-change1
read-change
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1A00 0003 E0
B. Appendix
  2. Keep only the last 8 bits
Change Device WarmUp time
Set wake Time — 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 45 00 00 00 01 B7 ( 01 set wake time to 1 sec)
Read Wake time — 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 46 00 00 00 00 B7
Share this on:
Facebook
Twitter
LinkedIn
Pinterest
Reddit
WhatsApp
Email
