Industrial IoT Wireless CO2 Temperature Humidity Sensor API Overview
NCD’s Long Range Industrial IoT Wireless CO2 Temperature Humidity Sensor offers air quality monitoring with an integrated temperature and humidity sensor, featuring up to a 2-mile range using wireless mesh networking. It transmits accurate CO2 concentration, temperature, and humidity data at user-defined intervals. CMOSens® technology provides precise CO2 measurements, while NDIR technology and a high-quality humidity and temperature sensor enhance accuracy.
The sensor compensates for long-term drifts using a dual-channel design, and its compact size allows easy integration. It operates from -25°C to 85°C and 0-90% RH, powered by 6 AA batteries with up to 5 years of life, depending on use. Its range, accuracy, and battery life make it a cost-effective solution for industrial and consumer applications.
Feature
  • Industrial Grade CO2 Measurement Range 0 – 2’000 ppm
  • CO2 Measurement Accuracy ± (60 ppm + + 5% of reading)(25 °C, 400 – 2’000 ppm)
  • Repeatability 10 ppm and Temperature stability
  • NDIR measurement principle
  • Temperature compensation of CO2 sensor signal
  • Fully calibrated and linearized
  • Superior long-term stability With Built-in reference channel
  • Industrial Grade Sensor with 0 to 90% RH / -25°C [-13°F] to 85°C [185°F])
  • Resolution 0.4% RH/0.1°C Accuracy 6% RH/ 0.8°C
  • Includes Battery Level with Every Transmission
  • Encrypted Wireless Communications up to 2 Mile Range
Frame Structure
Figure 3: Communication Procedure - Power Up
Mode TypePAN ID set by Sensor (ASCII)Frame fieldOffset (Payload section)Value
RunID save by user / DefaultMode bytes70x52
80x55
90x4E
Configuration7BCDMode bytes70x50
80x47
90x4D
Factory Reset7FFFMode bytes70x50
80x55
90x4D
Run Mode Power Up Frame
FieldNumber of bytesDescription
7E 00 1C 90 00 13 A1 00 41 58 1C CB FF FE 00 7A 01 00 00 01 00 00 52 55 4E 00 00 00 00 00 00 0BExample frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type (Power Up)
0x0013A1004158C1CB8Source Address
0xFFFE2Reserved
0x001R. Option
0x7A1Header with Power Up value
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x52554E3Mode Byte for Run Mode
0x0000000000006Reserved
0x0B1Checksum
7E 00 1C 90 00 13 A1 00 41 58 1C CB FF FE 00 7A 01 00 00 01 00 00 50 47 4D 00 00 00 00 00 00 1CExample frame
0x7E1Delimiter
0x001C2Length
0xFFFE2Reserved
0x001R. Option
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x50474D3Mode Byte for Configuration Mode
0x0E1Checksum
0x7E1Delimiter
0x001C2Length
0xFFFE2Reserved
0x001R. Option
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x0E1Checksum
Sensor Data Frame
Figure 4: Communication Procedure - Run Mode
Data Payload
Field Offset (Payload Section)Value ( or Default )LengthDescription
Header07F1Header to differentiate various type of packets
Node ID1001User Defined ID
Firmware Version2011Device Firmware Version
Battery LevelMSB 3, LSB 4-2Sampled battery voltage of the device.
Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V
Packet Counter5-1It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets.
Sensor TypeMSB 6, MSB 7 00, 0x2C2Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end
Error/Reserve Byte8001error code = 1 ( data was not ready)
CO2 Concentration in ppmMSB 9/ Data[0]-4CO2 Concentration in ppm
10/ Data[1]-CO2(usigned) = (((Data[0]<<24)+(Data[1]<<16)+(Data[2]<<8)+Data[3])/100.0)
11/ Data[2]-
LSB 12/ Data[3]-
Sensor DataMSB 13/ Data[4]-4Humidity data
14/ Data[5]-Humidity(usigned) = ((data[0] x 256) + data[5])/100
15/ Data[6]-Temperature data
LSB 16/ Data[7]-Temperature(signed) = (((data[2] x 256) + data[7])/100)°C
Configuration Mode Frame
Figure 5: Communication Procedure - Configuration Mode
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
Read Sensor Network ID
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
Read Sensor Destination Address​
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Set Sensor Destination to Broadcast ​
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Read Wireless Sensor Retries​
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep.  But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data.  If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep.  The Machine Uptime sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Set Wireless Sensor number of Retries ​
Complete Payload
F7 06 00 00 00 05
Complete Payload
5. In case you still can’t solve your issue head to our Community forum to get real time help from the NCD community of experts: https://community.ncd.io/
Appendix
Configuration Commands
1Set Broadcast Transmission 0XF70x01-0000FFFFThis will set the address to Broadcast mode. All the receiver with same ENY key and PAN ID will get the data packets
7Read Sleep Interval0XF70x15-0x00,0x02,0x58Reads the stored Sleep Interval value from the sensor
8Read Power0XF70x16-0x04Reads the stored RF Power value from the sensor
9Read Retries0XF70x17-0x0AReads the stored Retries value from the sensor
10Read Destination Address0XF70x18-00,00,FF,FFReads the stored Destination value from the sensor
11Read PAN ID aka Network ID0XF70x19-0x7FFFReads the PAN ID aka Network ID
12Enable Encryption 0XF20x01-0x01Enables the Encryption of the Frame Transmitted from the Sensor
13Disable Encryption 0XF20x02--Disables the Encryption of the Frame Transmitted from the Sensor
Command Acknowledgement Data
No.CommandData bytesReserved bytesDataCalculation (if any)
1Set Broadcast Transmission 180xFF (OK)
2Set ID and Sleep Interval180xFF (OK)
3Set Destination Address180xFF (OK)
4Set Power180xFF (OK)
5Set PAN ID aka Network ID180xFF (OK)
6Set Retries 180xFF (OK)
7Read Sleep Interval36D0 MSB, D1, D2 LSBDelay = (D0 x 65536) + (D1 x 256) + D2
8Read Power18PowerDEC value
9Read Retries18RetriesDEC value
10Read Destination Address45A0 MSB, A1, A2, A3
11Read PAN ID aka Network ID27ID0 MSB, ID1
12Enable Encryption 180xFF (OK)
13Disable Encryption 180xFF (OK)
14Set Encryption Key180xFF (OK)
Application Specific Commands
No.CommandSub CommandCommand CodeArgumentNote
Set Sensor Temperature Offset CoefficientF41E0x00, 0x0035 00 04Set the offset to 4 degrees
Set Sensor Altitude ValueF71C0x00, 0x0000 00 03 F6Set the Altitude to 03F6 {HEX] = 1014 DEC meters
Set Sensor Forced Calibration ValueF71F0x00, 0x0000 01 BDSet the force calibration value to 445
Error Code Descriptions
Error NumberDescription
0x01Invalid command
0x02Sensor Type mismatch
0x03Node ID mismatch
0x04Apply change command failed during X-bee parameter update
0x05Invalid API packet command response received after Apply change command
0x06Write command failed during X-bee parameter update
0x07Invalid API packet command response received after Write command
0x08Parameter change command failed during X-bee parameter update
0x09Invalid Parameter change command response packet received after Write command
0x0AInvalid/Incomplete packet received
0x0FInvalid parameter for setup/saving
Calculation for transmission
					0x04
					0xFF-0x04=0xFB
Calculation for reception
1.     Not including the frame delimiter and length, add all the bytes including the received checksum
2.     Keep only the last 8 bits
3.      If the result is 0xFF, the checksum is correct and the packet can be processed.
Consider the example for the command Set Broadcast shown in APPENDIX A and see that the received packet checksum verifies since the result is 0xFF.
					0xFF
