- Device Overview
- Frame Structure
- Read Sleep Duration
- Read Sensor Network ID
- Appendix
Introducing NCD’s Long Range Industrial IoT Wireless CO2, Temperature, Humidity, and Particulate Matter Sensor for air quality monitoring. It features a range of up to 2 miles using wireless mesh networking, transmitting CO2 concentration, particulate size, mass, temperature, and humidity data at customizable intervals.
The sensor uses CMOSens® Technology for precise CO2 measurement, along with NDIR technology for CO2 detection. It includes a best-in-class humidity and temperature sensor, which compensates for external heat sources without additional components. The dual-channel design ensures long-term stability in CO2 measurement.
The particulate matter sensor measures PM1.0, PM2.5, PM4.0, and PM10.0 particles, which can cause serious health issues like asthma and cardiovascular disease. It uses laser scattering technology for precise measurements and includes a fan for automatic sensor cleaning every 10 transmissions.
The temperature sensor operates from -25°C to 85°C (-13°F to 185°F), while the humidity sensor handles 0-100% RH. Powered by 6 AA batteries, the sensor offers up to 3 years of battery life, with external power options available on request.
- Industrial Grade Sensor Mass Concentration Range 0-1000 μg/m^3
- Mass Concentration Resolution of 1 μg/m^3
- Mass Concentration Size Range PM1.0, PM2.5, PM4.0, PM10.0
- Number Concentration Range 0 to 3000 1/cm^3
- Number Concentration Size Range PM0.5, PM1.0, PM2.5, PM4.0, PM10.0
- Industrial Grade CO2 Measurement Range 0 – 5’000 ppm
- CO2 Measurement Accuracy ± (60 ppm + + 5% of reading)(25 °C, 400 – 2’000 ppm)
- Temperature compensation of CO2Â sensor signal
- Unique Long-Term Stability of up to 8 Years
- Laser-Based Scattering Principle and Advanced Algorithms
- Built-in Auto Cleaning Feature (internal fan) After Every 10 Transmissions
- Industrial Grade Sensor with 0 to 90% RH / -25°C [-13°F] to 85°C [185°F])
- Resolution 0.4% RH/0.1°C Accuracy 6% RH/ 0.8°C
- Encrypted Wireless Communications up to 2 Mile Range in open environments
Frame Structure
| 8 | 0x55 | |||
| 9 | 0x4E | |||
| 8 | 0x47 | |||
| 9 | 0x4D | |||
| 8 | 0x55 | |||
| 9 | 0x4D |
Run Mode Power Up Frame
| 0x7E | 1 | Delimiter |
| 0x001C | 2 | Length |
| 0xFFFE | 2 | Reserved |
| 0x00 | 1 | R. Option |
| 0x01 | 1 | Node ID |
| 0x00 | 1 | Separator |
| 0x0001 | 2 | Sensor Type |
| 0x0000 | 2 | Separator |
| 0x0B | 1 | Checksum |
| 0x0E | 1 | Checksum |
Sensor Data Frame
Data Payload
| Field | Offset (Payload Section) | Value ( or Default ) | Length | Description |
| Header | 0 | 7F | 1 | Header to differentiate various type of packets |
| Node ID | 1 | 00 | 1 | User Defined ID |
| Firmware Version | 2 | 01 | 1 | Device Firmware Version |
| Battery Level | MSB 3, LSB 4 | - | 2 | Sampled battery voltage of the device. Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V |
| Packet Counter | 5 | - | 1 | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets. |
| Sensor Type | MSB 6, MSB 7 | 00, 0x35 | 2 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
| Error/Reserve Byte | 8 | 00 | 1 | error code = 1 ( data was not ready) |
| Mass Concentration PM1.0 [µg/m³] | MSB 9/ Data[0], 10/ Data[1], 11/ Data[2], LSB 12/ Data[3] | - | 4 | Mass Concentration PM1.0 [µg/m³] PM1.0(usigned) = (((Data[0]<<24)+(Data[1]<<16)+(Data[2]<<8)+Data[3])/100.0) |
| Mass Concentration PM2.5 [µg/m³] | MSB 13/ Data[4], 14/ Data[5], 15/ Data[6], LSB 16/ Data[7] | - | 4 | Mass Concentration PM2.5 [µg/m³] PM2.5(usigned) = (((Data[4]<<24)+(Data[5]<<16)+(Data[6]<<8)+Data[7])/100.0) |
| Mass Concentration PM4.0 [µg/m³] | MSB 17/ Data[8], 18/ Data[9], 19/ Data[10], LSB 20/ Data[11] | - | 4 | Mass Concentration PM4.0 [µg/m³] PM4.0(usigned) = (((Data[8]<<24)+(Data[9]<<16)+(Data[10]<<8)+Data[11])/100.0) |
| Mass Concentration PM10.0 [µg/m³] | MSB 21/ Data[12], 22/ Data[13], 23/ Data[14], LSB 24/ Data[15] | - | 4 | Mass Concentration PM10.0 [µg/m³] PM10.0(usigned) = (((Data[12]<<24)+(Data[13]<<16)+(Data[14]<<8)+Data[15])/100.0) |
| Number Concentration PM0.5 [#/cm³] | MSB 25/ Data[16], 26/ Data[17], 27/ Data[18], LSB 28/ Data[19] | - | 4 | Number Concentration PM0.5 [#/cm³] PM0.5(usigned) = (((Data[16]<<24)+(Data[17]<<16)+(Data[18]<<8)+Data[19])/100.0) |
| Number Concentration PM1.0 [#/cm³] | MSB 29/ Data[20], 30/ Data[21], 31/ Data[22], LSB 32/ Data[23] | - | 4 | Number Concentration PM1.0 [#/cm³] PM1.0(usigned) = (((Data[20]<<24)+(Data[21]<<16)+(Data[22]<<8)+Data[23])/100.0) |
| Number Concentration PM2.5 [#/cm³] | MSB 33/ Data[24], 34/ Data[25], 35/ Data[26], LSB 36/ Data[27] | - | 4 | Number Concentration PM2.5 [#/cm³] PM2.5(usigned) = (((Data[24]<<24)+(Data[25]<<16)+(Data[26]<<8)+Data[27])/100.0) |
| Number Concentration PM4.0 [#/cm³] | MSB 37/ Data[28], 38/ Data[29], 39/ Data[30], LSB 40/ Data[31] | - | 4 | Number Concentration PM4.0 [#/cm³] PM4.0(usigned) = (((Data[28]<<24)+(Data[29]<<16)+(Data[30]<<8)+Data[31])/100.0) |
| Number Concentration PM10.0 [#/cm³] | MSB 41/ Data[32], 42/ Data[33], 43/ Data[34], LSB 44/ Data[35] | - | 4 | Number Concentration PM10.0 [#/cm³] PM10.0(usigned) = (((Data[32]<<24)+(Data[33]<<16)+(Data[34]<<8)+Data[35])/100.0) |
| Typical Particle Size [µm] | MSB 45/ Data[36], 46/ Data[37], 47/ Data[38], LSB 48/ Data[39] | - | 4 | Typical Particle Size [µm] Typical Particle Size(usigned) = (((Data[36]<<24)+(Data[37]<<16)+(Data[38]<<8)+Data[39])/100.0) |
| Sensor Data | MSB 49/ Data[40], 50/ Data[41] | - | 2 | Humidity data Humidity(usigned) = ((data[0] x 256) + data[1])/100 |
| 51/ Data[42], LSB 52/ Data[43] | - | 2 | Temperature data Temperature(signed) = (((data[2] x 256) + data[3])/100)°C |
| MSB 53/ Data[44], 54/ Data[45], 55/ Data[46], LSB 56/ Data[47] | - | 4 | CO2 Concentration in ppm CO2(usigned) = (((Data[44]>>24)+(Data[45]>>16)+(Data[46]>>8)+Data[47])/100.0) |
Configuration Mode Frame
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2CÂ Â
A. Node ID
0x01 (Byte 23)
B. New Delay Value
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78Â
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor PayloadÂ
C. Power Level
0x04 (data byte 23)
B. Complete Sensor PayloadÂ
C. Retries Number
0x0A (data byte 23)
Complete Payload
F7 06 00 00 00 05Â
Complete Payload
Appendix
Configuration Commands
Command Acknowledgement Data
| 14 | Set Encryption Key | 1 | 8 | 0xFF (OK) |
Application Specific Commands
| No. | Command | Sub Command | Command Code | Argument |
| Force Sensor Clean | F7 | 1A | 0x00, 0x00 | 00 |
Error Code Descriptions
| 0x01 | Invalid command |
| 0x03 | Node ID mismatch |
Calculation for transmission
0x04
0xFF-0x04=0xFB
Calculation for reception
0xFF
