Introducing NCDās Industrial IoT Wireless AC Current Monitor Sensor, boasting up to a 2 Mile range using a wireless mesh networking architecture.Ā This sensor transmitter works together with a split core current sensor (included). It samples current at a high data rate and calculates the RMS Current value and sends a wireless transmission. This process is repeated at user defined timing interval while sleeping in between to minimize power consumption. The sensor comes with а 1.25 meter long split core current sensor which makes installation easy.
This Industrial IoT Wireless AC Current Monitor Sensor is capable of detecting change in current at user defined detection time intervals and sending out data if the current change is greater than user defined detection change percentage. This change detection feature can be enabled or disabled as needed. To minimize power consumption, the current sensor sleeps to preserve battery life. Both of these features work together to support multiple application areas in one package.
- Industrial Grade Wireless Current Monitor
- AC Current Range 0-100/200/600/1000A RMS Measurement (depending on the chosen probe)
- Auto Time Delay Based Data Sample Transmission
- Current Change Detection and Transmission
- Up to 2 Mile Line-of-Sight Range with On-Board Antenna
- Wireless Mesh Networking using DigiMeshĀ®
| Width | 3.54" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
| Probe Temperature | -40° C | 23° C | 85° C | As Tested by NCD Staff |
| Inputs | Current | |||
| Measured Current Range | 0 A | 1000 A | Depends on the particular probe chosen | |
| Resolution | 50 mA | 500 mA | Depends on the particular probe chosen (Min measured current 1.5% of FS) |
RF Module Specifications
| Networking Protocol | Digi XBeeĀ® DigiMeshĀ® | Digi XBeeĀ® DigiMeshĀ® | Digi XBeeĀ® DigiMeshĀ® |
Probes Specifications
Current Sensor
NCD offers several options for the current clamp for this sensor. Depending on which one you chose, the measurement range will be different, here are you options:
- 100 amp CT: 50mA resolution ( Min measured current 1.5% of FS)
- 200 amp CT: 100mA resolution ( Min measured current 1.5% of FS)
- 600 amp CT: 300mA resolution ( Min measured current 1.5% of FS)
- 1000 amp CT: 500mA resolution ( Min measured current 1.5% of FS)
Probe Configuration and Wiring
- External power supply (5-12 V DC) Current Requirement 250 mA (optional)
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
| Batteries | 2 | 4 | 4 | May be Powered by 2 or 4 AA Batteries |
| Battery Life 6 TPD (TPD Transmissions per Day) | 8 Years | Battery estimation is based on a 30 min interval | ||
| Battery Life 12 TPD (TPD Transmissions per Day) | 5 Years | Battery estimation is based on a 30 min interval | ||
| Battery Life 24 TPD (TPD Transmissions per Day) | 3 Year | Battery estimation is based on a 30 min interval |
Head to the NCD store if you want to purchase theĀ Industrial IoT Wireless AC Current Monitor Sensor.
If you already have the device and would like more information into its basic and advanced operations check out theĀ Quick Start GuideĀ andĀ User Manual.
