Industrial IoT Wireless 2-Channel RTD Temperature Sensor Quick Start Guide
This guide will cover the most basic setup instructions in order to see sensor data in Node-Red. It is intended for first time users of the product. If you are already familiar with the NCD sensor ecosystem, but require more detailed knowledge into this particular sensor you can find advanced configuration options and technical data in the User Manual and Datasheet.
  1. An Industrial IoT Wireless 2-Channel RTD Temperature Sensor
Enterprise Gateway Setup
  • 1 x Enterprise Gateway
  • 2 x WiFi Antennas
  • 1 x Digimesh Antenna
  • 1 x Din Rail Adapter
  • 1 x Power Supply
  • 1 x Two Position Terminal
  • 1 x Three Position Terminal
  • 1 x Eight Position Terminal
  2. Attach Antenna to the sensor’s RP-SMA connector
  3. Attach any probes you will use
  4. Open the lid of the sensor by removing the 4 screws on top
  5. Turn on the sensor
    • If using battery power set the power switch to ON BAT
    • If using external power set the power switch to ON EXT
    • See section Hardware Controls of the User Manual for more information
  6. Press the CFG Button to check for power
    • If the TEST LED lights up while the CFG button is held down the sensor is powered
    • If the TEST LED does not light check the batteries or power supply to the board
  7. Move the sensor to where it is at least 3 feet or 1 Meter from the gateway
Software Setup​
  5. Press the RESET Button on the Sensor Hardware
Final Steps
  1. Close the lid of your sensor using the 4 screws to attach the lid
