Introducing NCD’s Long Range Industrial IoT Wireless 4-20mA Current Receiver, boasting up to a 2 Mile range using a wireless mesh networking architecture.  It incorporates a High resolution 16-bit ADC that samples 4-20mA analog inputs at user defined intervals and transmits the result to remote modems and gateways. Between samples, this device enters a ultra-low power sleep mode to minimize power consumption. This Industrial IoT Wireless 4-20mA Current Receiver has an additional feature of detecting change in current every 7 seconds (user configurable) and sending out ADC samples if the change in current is greater than 10% (user configurable). Both features work simultaneously to support multiple application areas in one package.
This Industrial IoT Wireless 4-20mA Current Loop Receiver has on board 16V buck boost power supply, thus eliminates requirement of external power supply. This power supply is used to power up the external 4-20mA sensor. This device can be used with any 2 wire 4-20mA sensor/device into a wireless nodes.
- Industrial Grade 4-20mA Current Loop Receiver
- Input Range 0-20mA with 15-bit Resolution
- On Board 16V Supply to Power up the external 4-20mA Devices
- Supports 2 and 3 Wire Devices
- Auto ADC Transmission on Analog Voltage Change Detection
- Converts 4-20mA devices into Wireless Nodes
| Width | 4.53" | |||
| Length | 3.56" | |||
| Height | 2.25" | |||
| Probe Temperature | -40° C | 23° C | 85° C | As Tested by NCD Staff |
| Probe connector | M8 |
RF Module Specifications
Probe specifications
- External power supply (5-12 V DC) Current Requirement 250 mA
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
| Battery Life 1 TPD | 8 Years | TPD Transmissions per Day | ||
| Battery Life 12 TPD | 5 Years | TPD Transmissions per Day | ||
| Battery Life 24 TPD | 3 Year | TPD Transmissions per Day |
Head to the NCD store if you want to purchase the Industrial IoT Long Range Wireless 4-20mA Current Receiver.
