- Device Overview
- Frame Structure
- Read Sleep Duration
- Read Sensor Network ID
- Appendix
Introducing NCD’s Long Range Industrial IoT Wireless 4-20mA Current Receiver, boasting up to a 2 Mile range using a wireless mesh networking architecture.  It incorporates a High resolution 16-bit ADC that samples 4-20mA analog inputs at user defined intervals and transmits the result to remote modems and gateways. Between samples, this device enters a ultra-low power sleep mode to minimize power consumption. This Industrial IoT Wireless 4-20mA Current Receiver has an additional feature of detecting change in current every 7 seconds (user configurable) and sending out ADC samples if the change in current is greater than 10% (user configurable). Both features work simultaneously to support multiple application areas in one package.
This Industrial IoT Wireless 4-20mA Current Loop Receiver has on board 16V buck boost power supply, thus eliminates requirement of external power supply. This power supply is used to power up the external 4-20mA sensor. This device can be used with any 2 wire 4-20mA sensor/device into a wireless nodes.
- Industrial Grade 4-20mA Current Loop Receiver
- Input Range 0-20mA with 15-bit Resolution
- On Board 16V Supply to Power up the external 4-20mA Devices
- Supports 2 and 3 Wire Devices
- Auto ADC Transmission on Analog Voltage Change Detection
- Converts 4-20mA devices into Wireless Nodes
Frame Structure
| 8 | 0x55 | |||
| 9 | 0x4E | |||
| 8 | 0x47 | |||
| 9 | 0x4D | |||
| 8 | 0x55 | |||
| 9 | 0x4D |
Run Mode Power Up Frame
| 0x7E | 1 | Delimiter |
| 0x001C | 2 | Length |
| 0xFFFE | 2 | Reserved |
| 0x00 | 1 | R. Option |
| 0x01 | 1 | Node ID |
| 0x00 | 1 | Separator |
| 0x0001 | 2 | Sensor Type |
| 0x0000 | 2 | Separator |
| 0x0B | 1 | Checksum |
| 0x0E | 1 | Checksum |
Sensor Data Frame
Run mode is the default mode of operation of this sensor. In this mode, the Machine Uptime sensor sends periodic packets with the sensor measurement data. During the time it is not sending it enters deep-sleep to conserve power. The sensor’s X-bee module operates in API mode and sends packets to the saved destination address on the network specified by the saved PAN ID. Figure 4 illustrates the API transmission/reception procedure.
The detail of Payload section of packet is shown in table below:
| Frame Field | Offset (Payload section) | Fixed Value (if any) | Description |
| Header | 0 | 0x7F | Header to differentiate various types of packets |
| Node ID | 1 | 0x00 (Factory Default) | Node ID to differentiate up to 256 nodes in a network. User configurable values |
| Firmware | 2 | - | Used to determine firmware version programmed in the device |
| Battery Voltage | MSB 3 | - | Battery Voltage = ((Battery Voltage MSB x 256) + Battery Voltage LSB) x 0.00322 V |
| LSB 4 | - | ||
| Packet Counter | 5 | - | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets |
| Sensor Type | MSB 6 | 0x2D | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end. |
| LSB 7 | 0x00 | Sensor type 45 | |
| Error/Reserved byte | 8 | 0x00 | For future use |
| Sensor Data | 9 / Data[0] | - | ADC 1 Counts ( Signed 16 bit int) |
| 10 / Data[1] | - | ADC Counts = (Data[0] x 256) + Data[1] | |
| Milliamps | 11 / Data[2] | - | Milliamps ( Signed 16 bit int) |
| 12 / Data[3] | - | Milliamps = ((Data[2] x 256) + Data[3] ) / 100 |
Configuration Mode Frame
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2CÂ Â
A. Node ID
0x01 (Byte 23)
B. New Delay Value
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78Â
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor PayloadÂ
C. Power Level
0x04 (data byte 23)
B. Complete Sensor PayloadÂ
C. Retries Number
0x0A (data byte 23)
Complete Payload
F7 06 00 00 00 05Â
Complete Payload
Appendix
Configuration Commands
| 15 | Set Change Detection Parameters | 0XF7 | 0x07 | E, PR, T0 MSB, T1, T2 LSB | Enable or disable the percentage change detection. E=1 (Enable), E=0 (Disable) PR is the percentage change detection at which the sensor will send a packet. The sensor sends a packet when two consecutive readings differ by PR percent T0, T1, T2 - This is the detection time after which the sensor periodically checks for PR percent change in sensor data from last sample |
| 16 | Read Change Detection Parameters | 0XF7 | 0x1A | - | Refer to Command 15 above for the explanation. |
Command Acknowledgement Data
| 14 | Set Encryption Key | 1 | 8 | 0xFF (OK) | |
| 15 | Set Change Detection Parameters | 1 | 8 | 0xFF (OK) | |
| 16 | Read Change Detection Parameters | 5 | 4 | E, PR, T0, T1, T2 | Detection time = (T0 x 65536) + (T1 x 256) + T2 |
Application Specific Commands
| COMMAND | COMMAND | SUB COMMAND | Reserve Byte | COMMAND CODE | ARGUMENT |
| Set ADC Calibration Point 1 | 0xF4 | 0x42 | 0x00,0x00,0x2D | 0x01000109CB | Set ADC Calibration Point 1 to 68043 |
| Set ADC Calibration Point 2 | 0xF4 | 0x42 | 0x00,0x00,0x2D | 0x02000105E3 | Set ADC Calibration Point 2 to 67043 |
| Set ADC Calibration Point 3 | 0xF4 | 0x42 | 0x00,0x00,0x2D | 0x03000107E4 | Set ADC Calibration Point 3 to 67556 |
| Get ADC Calibration Point 1 | 0xF4 | 0x43 | 0x00,0x00,0x2D | 0x01 | Get ADC Calibration Point 1 |
| Get ADC Calibration Point 2 | 0xF4 | 0x43 | 0x00,0x00,0x2D | 0x02 | Get ADC Calibration Point 2 |
| Get ADC Calibration Point 3 | 0xF4 | 0x43 | 0x00,0x00,0x2D | 0x03 | Get ADC Calibration Point 3 |
| Set Boot Time to 10 Seconds | 0xF4 | 0x44 | 0x00,0x00,0x2D | 0x0A | Set Boot Time to 10 Seconds |
| Get Boot Time | 0xF4 | 0x45 | 0x00,0x00,0x2D | - | Get Boot Time |
Error Code Descriptions
| 0x01 | Invalid command |
| 0x03 | Node ID mismatch |
Calculation for transmission
0x04
0xFF-0x04=0xFB
Calculation for reception
0xFF
