Getting Started with Losant and NCD Temperature Humidity Sensor
Recently I discovered this really cool company called Losant. They build Enterprise level IoT software solutions and their platform is so easy to use, supporting tons of hardware platforms. So I decided to give it a try. Losant is a great choice for Raspberry pi, ESP8266, Arduino, and Particle. In this article, I will be interfacing a temperature humidity sensor with Losant through an ESP8266. This is a simple application, but it will give us pretty good idea about how to use Losant with ncd.io hardware. It only took a few minutes to build this temperature/humidity sensing application using our plug-and-play hardware platform.
To build this weather station, I will be using following hardware:
To assemble the hardware plug the ESP8266 into the I2C shield and use the I2C cable to connect SHT25 temperature Humidity Sensor.
Losant Setup on ESP8266
You will need to install Losant Libraries in your ESP8266, these libraries and installation info can be found on the Losant Website over here.
All ncd.io hardware works in the same way, so using this setup, you can interface any device or sensor with Losant in just a few minutes.
Step 1: Create an Account on Losant. To learn more, checkout this blog post.
Step 2: Click “Applications” and create a new application. Here you can fill out the details like your application name and Description.
Step 3: Select Device Attributes
Attributes are the things which ESP8266 will send to Losant. In this case we will report humidity, temperature in °C and temperature in °F.
Selecting Attributes
Step 4: Create a Dashboard
Step 5 : Create Access Key : To create an access key, click on “Applications” and select “Security”. Here you can write your application name.
Make sure you save your access key and access secret keys.
Step 6 : Now its time to write the arduino lib for ESP8266. The Arduino lib can be found on github.
void reconnectMQTT(){
Serial.println("setting up mqtt");
while(!mqttCli.connected()){
if(mqttCli.connect("ESP8266Client123456789")==true){
Serial.println("connected");
String subTopic = String("channels/"+ String(channelID) + "/subscribe/json/" + String(readAPIKey));
int subTopicLength = subTopic.length()+1;
char subTopicBuffer[subTopicLength];
subTopic.toCharArray(subTopicBuffer,subTopicLength);
String pubMessage = "status=MQTTPUBLISH";
String pubTopic =String("channels/"+String(channelID)+"/publish/"+String(writeAPIKey));
int pubTopicLength = pubTopic.length()+1;
char pubTopicBuffer[pubTopicLength];
pubTopic.toCharArray(pubTopicBuffer,pubTopicLength);
//Publish to MQTT Broker
Serial.println(mqttCli.publish(pubTopicBuffer, pubMessage.c_str()) ? "Published" : "NotPublished");
//Subscribe to MQTT Broker
Serial.println(mqttCli.subscribe(subTopicBuffer) ? "Subscribed" : "Unsbscribed");
}else{
Serial.print("failed, rc=");
Serial.println(mqttCli.state());
delay(1000);
//----------WiFiCallback-----------//
void taskWiFiCallback(){
Serial.println("taskWiFiCallbackStarted");
Serial.print("timeout for this task: t");
Serial.println(tWiFi.getTimeout());
if(!mqttCli.connected()){
Serial.println("Client not connected");
reconnectMQTT();
String topicString ="channels/"+String(channelID)+"/publish/"+String(writeAPIKey);
int topicLength = topicString.length()+1;
char topicBuffer[topicLength];
topicString.toCharArray(topicBuffer,topicLength+1);
Serial.println(topicBuffer);
String dataString = String("field1="+ String(tempC,1) + "&field2=" + String(tempF,1) + "&field3=" + String(humid,1));
int dataLength = dataString.length()+1;
byte dataBuffer[dataLength];
dataString.getBytes(dataBuffer,dataLength);
mqttCli.beginPublish(topicBuffer,dataLength,false);
Serial.println(mqttCli.write(dataBuffer,dataLength) ? "published" : "published failed");
mqttCli.endPublish();
//mqttCli.loop();
Arduino Output on the Serial Monitor
Weather Station Data On Losant
Need a Long-Range Wireless temperature humidity sensor?  Here you can learn how to interface Industrial Long range wireless temperature humidity sensors with Arduino.
