Introducing NCD’s Condition Based Predictive Maintenance Sensor Gen4. Lightweight rugged and reliable for accurate asset monitoring and boasting up to a 2-mile range using a wireless mesh networking architecture & Incorporating a 16-bit Vibration and integrated Temperature sensor.
During Power-Up, this vibration sensor learns “normal” base-line vibration from the monitored device. This base-line vibration is subtracted from regular sampled vibration readings to improve relevant vibration data. Ideally, the monitored device should be off while the sensor is learning. Once the sensor stabilizes and starts sending data, the device/machinery being monitored can be powered on.
This sensor combines these data with temperature data in a data packet, and transmits the result to modems and gateways within wireless range. Once transmission is complete, the vibration sensor goes back to sleep, thus minimizing power consumption.
Features:
- Small & lightweight for ease of installation.
- IP65 rated sealed enclosure for dust & moisture protection.
- Metal probe housing for durability in harsh industrial environments.
- D-cell battery for long-lasting operation.
- A versatile user-configurable sample rate for slow or fast-running machines
- Integrated temperature sensor in base.
- In-Built Machine Learning optimizes power consumption.
- Asset On-Time Calculator automatically tracks operational status.
- Hardware Accelerator enhances vibration sampling accuracy.
- Configurable Sample Rate – 100Hz to 25.6KHz
- Available Frequencies – 900Mhz, 868Mhz, and 2.4Ghz
- Supports MESH networking via DigiMesh
- Fully open Node-RED library for configuration and data ingestion
Figure 1: Device Overview
| Height | 85mm | |||
| Base diameter | 48mm | |||
| Weight | 225g | |||
| Enclosure Rating | IP67 | |||
| Mounting | ¼-28 UNF thread Magnetic mount | |||
| Temperature Sensor Accuracy | ±1°C | |||
| Accelerometer Sampling Rate | 26.6 kHz | Vibration Sensor Data Rate | ||
| Accelerometer Bandwidth | 6.3 kHz | |||
| Accelerometer Full-Scale Range | -16g | +16g | ||
| Accelerometer Noise | 70 μg/ √Hz | |||
| Sample Duration | 1sec | 1sec | 10sec | Device will take readings for the set time and then send over wireless |
| Measure Current Range | 0A | 1000A | Depends on the particular probe chosen | |
| Measured Current Resolution | 50mA | 500mA | Depends on the particular probe chosen (Min measured current 1.5% of FSR) |
Enclosure Type 1
Enclosure Type 2
RF Module Specifications
Probes Specifications
Current Sensor
NCD offers several options for the current clamp for this sensor. Depending on which one you chose, the measurement range will be different, here are you options:
100 amp CT: 50mA resolution ( Min measured current 1.5% of FS)
200 amp CT: 100mA resolution ( Min measured current 1.5% of FS)
600 amp CT: 300mA resolution ( Min measured current 1.5% of FS)
Probe Configuration and Wiring
While changing the batteries:
- Turn off the sensor
- Only use a new D-cell battery (obtain one from NCD, as it has a built in supercapacitor, this is not a regular battery).
- Make sure to align the connector in the proper orientation (this will assure you match the polarity)
- The battery should not be replaced in fire-risky areas
- Do NOT install a rechargeable battery
Head to the NCD store if you want to purchase the Condition Based Predictive Maintenance Sensor Gen4.
