C1D2 Industrial IoT Wireless Water Detect Sensor API Overview
NCD’s C1D2 certified long-range wireless water detection sensors are the first designed specifically for hazardous environments. Certified for C1D2 Groups A, B, C, and D, they are suited for areas with explosive gases, dust, fibers, or flammable vapors, including substances like Acetylene, Hydrogen, Gasoline, and Methanol. These sensors are ideal for use in chemical plants, oil refineries, paint shops, mills, and other facilities handling flammable materials.
Featuring an integrated antenna and up to a 2-mile range, the sensor uses a 900MHz 128-Bit AES encrypted transceiver to send data at customizable intervals. It sleeps between transmissions to save power, waking every 15 minutes or when a wet/dry condition is detected. This ensures regular updates and immediate alerts, with a battery life of up to 10 years depending on conditions and settings.
The sensor includes a 4.5-meter probe cable, transmitting wet or dry status changes for applications like water leak detection. It is ideal for preventing water damage in buildings or monitoring drainage in critical areas. Applications include detecting floods, leaks from water heaters, frozen pipes, or low-water conditions in sensitive areas like factory floors and machinery.
NCD’s sensor ecosystem integrates seamlessly with platforms like AWS®, Microsoft Azure®, or private MQTT brokers using Node-RED. This allows secure, private data handling or cloud integration with minimal effort, making it one of the most versatile and reliable solutions on the market.
Feature
  • C1D2 Certified Temperature Sensor for Hazardous Locations
    • Group A, B, C, and D Certification
  • Industrial Long Range Wireless Water Detect Sensor
  • Detect Water Presence or non- presence
  • IP65 Box Ideal for Indoor Outdoor Applications
  • 4.5 Meter Long Connecting Wire Water Detection Probe
  • Encrypted Communication, 1000 ft indoor wireless range, approximately 2 miles in line of sight environments with onboard antenna
  • Supports Wireless Mesh Networking
  • Open Communication Protocol for Easy Software Integration,
  • NO Monthly Fee or Locked Proprietary Protocols, Open Node-RED library for ease of configuration and data processing
Frame Structure
Figure 3: Communication Procedure - Power Up
Mode TypePAN ID set by Sensor (ASCII)Frame fieldOffset (Payload section)Value
RunID save by user / DefaultMode bytes70x52
80x55
90x4E
Configuration7BCDMode bytes70x50
80x47
90x4D
Factory Reset7FFFMode bytes70x50
80x55
90x4D
Run Mode Power Up Frame
FieldNumber of bytesDescription
7E 00 1C 90 00 13 A1 00 41 58 1C CB FF FE 00 7A 01 00 00 01 00 00 52 55 4E 00 00 00 00 00 00 0BExample frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type (Power Up)
0x0013A1004158C1CB8Source Address
0xFFFE2Reserved
0x001R. Option
0x7A1Header with Power Up value
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x52554E3Mode Byte for Run Mode
0x0000000000006Reserved
0x0B1Checksum
7E 00 1C 90 00 13 A1 00 41 58 1C CB FF FE 00 7A 01 00 00 01 00 00 50 47 4D 00 00 00 00 00 00 1CExample frame
0x7E1Delimiter
0x001C2Length
0xFFFE2Reserved
0x001R. Option
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x50474D3Mode Byte for Configuration Mode
0x0E1Checksum
0x7E1Delimiter
0x001C2Length
0xFFFE2Reserved
0x001R. Option
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x0E1Checksum
Sensor Data Frame
Figure 4: Communication Procedure - Run Mode
Data Payload
Field Offset (Payload Section)Value ( or Default )LengthDescription
Header07F1Header to differentiate various type of packets
Node ID1001User Defined ID
Firmware Version2011Device Firmware Version
Battery LevelMSB 3, LSB 4-2Sampled battery voltage of the device.
Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V
Packet Counter5-1It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets.
Sensor TypeMSB 6, MSB 7 0x00, 0x022Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end
Error/Reserve Byte80x001error code = 1 ( data was not ready)
Sensor DataMSB 9/ Data[0]Value of Input 13
10/ Data[1]Value of Input 2
11/ Data[2]-Reserved
Configuration Mode Frame
Figure 5: Communication Procedure - Configuration Mode
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
Read Sensor Network ID
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
Read Sensor Destination Address​
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Set Sensor Destination to Broadcast ​
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Read Wireless Sensor Retries​
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep.  But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data.  If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep.  The Machine Uptime sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Set Wireless Sensor number of Retries ​
Complete Payload
F7 06 00 00 00 05
Complete Payload
5. In case you still can’t solve your issue head to our Community forum to get real time help from the NCD community of experts: https://community.ncd.io/
Appendix
Configuration Commands
1Set Broadcast Transmission 0XF70x01-0000FFFFThis will set the address to Broadcast mode. All the receiver with same ENY key and PAN ID will get the data packets
7Read Sleep Interval0XF70x15-0x00,0x02,0x58Reads the stored Sleep Interval value from the sensor
8Read Power0XF70x16-0x04Reads the stored RF Power value from the sensor
9Read Retries0XF70x17-0x0AReads the stored Retries value from the sensor
10Read Destination Address0XF70x18-00,00,FF,FFReads the stored Destination value from the sensor
11Read PAN ID aka Network ID0XF70x19-0x7FFFReads the PAN ID aka Network ID
12Enable Encryption 0XF20x01-0x01Enables the Encryption of the Frame Transmitted from the Sensor
13Disable Encryption 0XF20x02--Disables the Encryption of the Frame Transmitted from the Sensor
Command Acknowledgement Data
No.CommandData bytesReserved bytesDataCalculation (if any)
1Set Broadcast Transmission 180xFF (OK)
2Set ID and Sleep Interval180xFF (OK)
3Set Destination Address180xFF (OK)
4Set Power180xFF (OK)
5Set PAN ID aka Network ID180xFF (OK)
6Set Retries 180xFF (OK)
7Read Sleep Interval36D0 MSB, D1, D2 LSBDelay = (D0 x 65536) + (D1 x 256) + D2
8Read Power18PowerDEC value
9Read Retries18RetriesDEC value
10Read Destination Address45A0 MSB, A1, A2, A3
11Read PAN ID aka Network ID27ID0 MSB, ID1
12Enable Encryption 180xFF (OK)
13Disable Encryption 180xFF (OK)
14Set Encryption Key180xFF (OK)
Application Specific Commands
No.CommandSub CommandArgumentNote
Set Input Debounce TimeF442DTSets the debounce time in milliseconds on inputs. State changes to the input during this debounce time will be ignored. Generally recommended for mechanically triggered state changes such as button or relay/contactor outputs
Read Input Debounce TimeF443-Get the debounce time value in milliseconds
Error Code Descriptions
Error NumberDescription
0x01Invalid command
0x02Sensor Type mismatch
0x03Node ID mismatch
0x04Apply change command failed during X-bee parameter update
0x05Invalid API packet command response received after Apply change command
0x06Write command failed during X-bee parameter update
0x07Invalid API packet command response received after Write command
0x08Parameter change command failed during X-bee parameter update
0x09Invalid Parameter change command response packet received after Write command
0x0AInvalid/Incomplete packet received
0x0FInvalid parameter for setup/saving
Calculation for transmission
					0x04
					0xFF-0x04=0xFB
Calculation for reception
1.     Not including the frame delimiter and length, add all the bytes including the received checksum
2.     Keep only the last 8 bits
3.      If the result is 0xFF, the checksum is correct and the packet can be processed.
Consider the example for the command Set Broadcast shown in APPENDIX A and see that the received packet checksum verifies since the result is 0xFF.
					0xFF
