Primarily utilized for monitoring structural displacements, the C1D2 Industrial IoT Wireless Structural Monitoring Sensor detects movements and shifts at various structural points. Ideal for installation between footings and walls or alongside steel supports, this sensor reports any alterations in distance due to its spring-loaded cable mechanism. It is perfect for applications such as positional control, beam testing, hydraulic movement detection, and structural shift monitoring. The sensor is secured with two screws, plus an additional screw for the retractable cable, which provides analog position feedback during length changes.
Featuring a single-channel 10-bit ADC, the sensor periodically samples and wirelessly transmits data, entering a low-power sleep mode between transmissions to extend battery life. It can detect positional changes every 7 seconds (configurable), updating the cable length data if displacement varies by more than 10% (configurable). This energy-efficient operation, combined with a broad application spectrum, ensures its versatility. The sensor outputs an analog value from 0 to 1023, indicating full extension or retraction of the displacement cable.
The sensor uses a 50cm retractable wire cable, actively pulling to retract, and provides readings from 0 to 1023 as the cable extends. It should be mounted to track movements between two points, detecting linear shifts without assessing angular changes. Optimal functionality is achieved with the cable partially extended, allowing for precise detection of any length variation. However, it does not measure angular shifts, focusing solely on linear movements.
- Wireless Structural Monitoring Sensor for Structural Monitoring
- Industrial Grade IoT Displacement Sensor
- 10-bit Resolution & Precision ±0.5% FS
- Auto ADC Sample Transmission on Level Change
- Configurable 10% Analog Voltage Change Detection
- Interface with Popular Cloud Platforms:
- Amazon® AWS®, Microsoft® Azure®
- Temboo, MQTT, Losant, Node-Red
| Width | 3.54" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
RF Module Specifications
- External power supply (5-12 V DC) Current Requirement 250 mA (optional)
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
| Battery Life 1 TPD (TPD Transmissions per Day) | 10 Years | Battery estimation is based on a 30 min interval | ||
| Battery Life 12 TPD (TPD Transmissions per Day) | 8 Years | Battery estimation is based on a 30 min interval | ||
| Battery Life 24 TPD (TPD Transmissions per Day) | 5 Year | Battery estimation is based on a 30 min interval | ||
| Battery Life 96 TPD (TPD Transmissions per Day) | 3 Year | Battery estimation is based on a 30 min interval |
Head to the NCD store if you want to purchase the C1D2 Industrial IoT Wireless Structural Monitoring Sensor.
