C1D2 Industrial IoT Wireless Linear Displacement Sensor Datasheet
Linear displacement sensors are typically used for structural monitoring applications, allowing movement and shift detection between two points.  Install this linear displacement sensor between footings and walls, or between walls and steel support structures.  Any movement (due to temperature, earthquakes, or structural failure) will be reported by this sensor.  Use this linear displacement sensor for measurement of distances between two points, such as positional control systems, lifting and spreader beam testing, hydraulic movement detection, and structural crack monitoring.  With pivot bearings included at each end, this sensor is capable of monitoring shifts in position that may not always be perfectly linear without damage to the sensor.  With a IP65 rating, this device is ideally suited for indoor or outdoor use.
This long range IoT wireless Linear Displacement Sensor incorporates a 1 channel 10-bit ADC that samples Linear Displacement at user defined intervals and sends a wireless transmission to remote gateways and modems. After sampling, this device goes to sleep to minimize power consumption and prolong battery life. This IoT Wireless Linear Displacement Sensor has an additional feature of detecting change in position every 7 seconds (user configurable) and sending out Displacement value if the change in Displacement is greater than 10% (user configurable). To minimize power consumption, it sleeps during the time it is not checking for change in Displacement level. Both of these features work together, supporting multiple application areas in one package.  This Wireless IoT Linear Displacement Sensor outputs a analog value. The value range is between 0 and 1023. An output value 1023 indicates that the displacement probe is fully extended while a value of 0 indicates the sensor is fully contracted.
  • Wireless Linear Displacement Sensor for Structural Monitoring
  • Industrial Grade IoT Displacement Sensor with Max Speed 5m/Sec
  • 10-bit Resolution & Linear Precision 2% FS
  • Auto ADC Sample Transmission on Level Change
  • Configurable 10% Analog Voltage Change Detection
  • NCD provides a compete set of Node-RED libraries
  • Includes Battery Level with Every Transmission
Figure 1: Device Overview
Width3.54"
Length4.52"
Height2.16"
Enclosure RatingIP65, NEMA 1,2,4,4X,12,13, UL-508
Mounting 1/4 NPT
1/4-28 UNF
Magnet Mount
Temperature Rating-40° C23° C85° CComponent Rating
Tested Temperature0° C23° C40° CAs Tested by NCD Staff
ParameterMinimumNominalMaximumNotes
Trace Width0.007 inch0.012 inch0.25 inchTrace Width depends on the Trace Type
Layer Count2L - RigidTop and Bottom Layer
Material TypeFR-4 TG170FR-4 TG170FR-4 TG180
Surface FinishENIG 2u"
IPC StandardIPC CLASS 2
Finished Copper Foil1.0/1.0 OZ
Finished Thickness0.062 inc
Fine line <4.0/4.0milNo
Blind & Burried ViasNo
Non-Conductive ResinNo
Conductive ResinNo
Figure 3: Mechanical Drawing
RF Module Specifications
Parameter868MHz900MHz2.4GHz
Frequency Band863 MHz to 870 MHz902 to 928 MHzISM 2.4 GHz
Transmitter PowerUp to 13 dBm ERPUp to 24 dBmUp to 8 dBm
Receiver Sensitivity-106 dBm at 80 Kbps-101 dBm at 200 Kbps-103 dBm at 250 Kbps
Range (dense urban)~1000ft~1000ft~300ft
Range (line of sight)~2 miles~2 miles~1 mile
Data Rate80 Kbps200 Kbps250 Kbps
Networking ProtocolDigi XBee® DigiMesh®Digi XBee® DigiMesh®Digi XBee® DigiMesh®
Encryption128-bit AES128-bit AES128-bit
Reliable Packet DeliveryRetries/acknowledgementsRetries/acknowledgementsRetries/acknowledgements
IDsPAN ID and addresses, cluster IDs and endpoints (optional)PAN ID and addresses, cluster IDs and endpoints (optional)PAN ID and addresses, cluster IDs and endpoints (optional)
CertificationCE/RED, ROHS CompliantFCC (America), IC (Canada), C-Tick (Australia), Anatel (Brazil), IDA (Singapore)FCC (America), IC (Canada), RCM (Australia), Anatel (Brazil), Teleck MIC (Japan), KCC (South Korea)
  1. Powered by AA batteries (NCD recommends Energizer L91 batteries)
  2. External power supply (5-12 V DC) Current Requirement 250 mA (optional)
While changing the batteries:
  1. Turn off the sensor
  2. Only use new L91 batteries
  3. Checkout the polarity marking on the battery holder and batteries
  4. Replace all six batteries with new L91 batteries. Do not mix old and new batteries
  5. Batteries should not be replaced in fire-risky areas
  6. Do NOT install rechargeable batteries
Batteries266May be Powered by 2 or 6 AA Batteries
Battery Life 1 TPD (TPD Transmissions per Day)10 YearsBattery estimation is based on a 30 min interval
Battery Life 12 TPD (TPD Transmissions per Day)8 YearsBattery estimation is based on a 30 min interval
Battery Life 24 TPD (TPD Transmissions per Day)5 YearBattery estimation is based on a 30 min interval
Battery Life 96 TPD (TPD Transmissions per Day)3 YearBattery estimation is based on a 30 min interval
Store and Documentation
Head to the NCD store if you want to purchase the C1D2 Industrial IoT Wireless Linear Displacement Sensor.
