NCD’s new C1D2-certified long-range wireless door open/closed detection sensors set an industry-first standard for IoT devices designed for hazardous environments. With C1D2 Group A, B, C, and D certification, these sensors are ideal for locations with explosive gases, dust, fibers, or flammable vapors, such as chemical plants, oil refineries, paint shops, mills, silos, and mining facilities. They support hazardous substances including Acetylene, Hydrogen, Ether, and Propane.
The sensor minimizes power usage by sleeping between transmissions and wakes every 15 minutes—or when a door or window state changes—to send updates. This design enables up to 10 years of battery life, depending on conditions and transmission intervals.
The sensor acts as a wireless push notification transmitter, detecting door/window states via a magnetic switch and sending alerts for open or closed conditions. With up to two detection probes on a 4.5-meter cable, it’s perfect for security applications requiring reliable, long-range communication. Alerts are sent when magnets move into or out of proximity with the sensors, making it ideal for monitoring doors, windows, gates, and other critical areas.
NCD offers a complete ecosystem of C1D2-certified long-range wireless sensors with open protocols for seamless software integration. Use an NCD Gateway with Node-RED to decode transmissions and connect to platforms like AWS®, Microsoft Azure®, or your own MQTT broker. The system ensures secure, private data handling while allowing integration with virtually any cloud platform.
Feature
- C1D2 Certified Vibration Sensor for Hazardous Locations
- Group A, B, C, and D Certification
- Industrial Long Range Wireless Door Sensor
- Detect Input State of up to Two Magnetic Door Sensors
- One or Two Inputs with Included Magnetic Door Sensors
- IP65 Box Ideal for Indoor or Outdoor Applications
- Encrypted Communication, 1000 ft indoor wireless range, approximately 2 miles in line of sight environments with onboard antenna
- Open Communication Protocol for Easy Software Integration,
| Width | 3.56" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
RF Module Specifications
Probe Specifications
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
| Battery Life 1 TPD (TPD Transmissions per Day) | 10 Years | Battery estimation is based on a 30 min interval | ||
| Battery Life 12 TPD (TPD Transmissions per Day) | 8 Years | Battery estimation is based on a 30 min interval | ||
| Battery Life 24 TPD (TPD Transmissions per Day) | 5 Year | Battery estimation is based on a 30 min interval | ||
| Battery Life 96 TPD (TPD Transmissions per Day) | 3 Year | Battery estimation is based on a 30 min interval |
C1D2 Industrial IoT Wireless Door Open Closed Sensor.
