- Device Overview
- Frame Structure
- Read Sleep Duration
- Read Sensor Network ID
- Appendix
NCD’s new C1D2-certified long-range wireless door open/closed detection sensors set an industry-first standard for IoT devices designed for hazardous environments. With C1D2 Group A, B, C, and D certification, these sensors are ideal for locations with explosive gases, dust, fibers, or flammable vapors, such as chemical plants, oil refineries, paint shops, mills, silos, and mining facilities. They support hazardous substances including Acetylene, Hydrogen, Ether, and Propane.
The sensor minimizes power usage by sleeping between transmissions and wakes every 15 minutes—or when a door or window state changes—to send updates. This design enables up to 10 years of battery life, depending on conditions and transmission intervals.
The sensor acts as a wireless push notification transmitter, detecting door/window states via a magnetic switch and sending alerts for open or closed conditions. With up to two detection probes on a 4.5-meter cable, it’s perfect for security applications requiring reliable, long-range communication. Alerts are sent when magnets move into or out of proximity with the sensors, making it ideal for monitoring doors, windows, gates, and other critical areas.
NCD offers a complete ecosystem of C1D2-certified long-range wireless sensors with open protocols for seamless software integration. Use an NCD Gateway with Node-RED to decode transmissions and connect to platforms like AWS®, Microsoft Azure®, or your own MQTT broker. The system ensures secure, private data handling while allowing integration with virtually any cloud platform.
Feature
- C1D2 Certified Vibration Sensor for Hazardous Locations
- Group A, B, C, and D Certification
- Industrial Long Range Wireless Door Sensor
- Detect Input State of up to Two Magnetic Door Sensors
- One or Two Inputs with Included Magnetic Door Sensors
- IP65 Box Ideal for Indoor or Outdoor Applications
- Encrypted Communication, 1000 ft indoor wireless range, approximately 2 miles in line of sight environments with onboard antenna
- Open Communication Protocol for Easy Software Integration,
Frame Structure
| 8 | 0x55 | |||
| 9 | 0x4E | |||
| 8 | 0x47 | |||
| 9 | 0x4D | |||
| 8 | 0x55 | |||
| 9 | 0x4D |
Run Mode Power Up Frame
| 0x7E | 1 | Delimiter |
| 0x001C | 2 | Length |
| 0xFFFE | 2 | Reserved |
| 0x00 | 1 | R. Option |
| 0x01 | 1 | Node ID |
| 0x00 | 1 | Separator |
| 0x0001 | 2 | Sensor Type |
| 0x0000 | 2 | Separator |
| 0x0B | 1 | Checksum |
| 0x0E | 1 | Checksum |
Sensor Data Frame
Data Payload
| Field | Offset (Payload Section) | Value ( or Default ) | Length | Description |
| Header | 0 | 7F | 1 | Header to differentiate various type of packets |
| Node ID | 1 | 00 | 1 | User Defined ID |
| Firmware Version | 2 | 01 | 1 | Device Firmware Version |
| Battery Level | MSB 3, LSB 4 | - | 2 | Sampled battery voltage of the device. Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V |
| Packet Counter | 5 | - | 1 | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets. |
| Sensor Type | MSB 6, MSB 7 | 0x00, 0x02 | 2 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
| Error/Reserve Byte | 8 | 0x00 | 1 | error code = 1 ( data was not ready) |
| Sensor Data | MSB 9/ Data[0] | Value of Input 1 | 3 | |
| 10/ Data[1] | Value of Input 2 | |||
| 11/ Data[2] | - | Reserved |
Configuration Mode Frame
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2CÂ Â
A. Node ID
0x01 (Byte 23)
B. New Delay Value
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78Â
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor PayloadÂ
C. Power Level
0x04 (data byte 23)
B. Complete Sensor PayloadÂ
C. Retries Number
0x0A (data byte 23)
Complete Payload
F7 06 00 00 00 05Â
Complete Payload
Appendix
Configuration Commands
Command Acknowledgement Data
| 14 | Set Encryption Key | 1 | 8 | 0xFF (OK) |
Application Specific Commands
| No. | Command | Sub Command | Argument | Note |
| Set Input Debounce Time | F4 | 42 | DT | Sets the debounce time in milliseconds on inputs. State changes to the input during this debounce time will be ignored. Generally recommended for mechanically triggered state changes such as button or relay/contactor outputs |
| Read Input Debounce Time | F4 | 43 | - | Get the debounce time value in milliseconds |
Error Code Descriptions
| 0x01 | Invalid command |
| 0x03 | Node ID mismatch |
Calculation for transmission
0x04
0xFF-0x04=0xFB
Calculation for reception
0xFF
